Circuit Diagram 10-N - Defender Source
Old September 8th, 2013, 05:34 PM
The Dro
Dro
1988 Ninety
Has anyone converted this PDF to CAD?
Old September 8th, 2013, 09:18 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
It doesn't really work that way.
What is your final plan with a CAD file?
Old September 13th, 2013, 07:12 AM
The Dro
Dro
1988 Ninety
Poor choice of words... I mean if someone has gone through the trouble of drawing the diagram in CAD. Not a conversion...
The plan is to have an accurate wiring diagram for my trucks. I rewired both trucks, 88 and 109, and having the diagram is a good idea to have.
The one I have right now I did by hand.
Old September 13th, 2013, 10:09 AM
Cz with a CAD file it is easy to add and edit circuits. PDF is not editable.
Old September 13th, 2013, 02:05 PM
robertf
Robert F
1995 Discovery
If you are capable of adding or editing circuits, it should take you no more than an hour to reproduce that diagram in autocad.
I also don't see any point, unless you go all out with autocad electrical linked to an inventor model and plan on doing nailboards for repro harnesses. but someone already does that
Old September 14th, 2013, 09:46 AM
The Dro
Dro
1988 Ninety
What will a CAD version do for you that a PDF wont? Its a wiring diagram...
-Jeff
I can modify it accordingly. I improved it...
I'll probably to it... Looks like no one has done it in CAD.
Old September 14th, 2013, 12:09 PM
Ya a 2A has two fuses but uses only one, really. Since the wire they used is fairly fat for the runs, fusing isn't really necessary. Fuses protect the wire, not the thing at the end of the wire.
Old September 14th, 2013, 03:28 PM
The Dro
Dro
1988 Ninety
I fused everything on my truck.
I want to slap the engineer who designed the 2 fuse block on the Series.
95 D90- A/C WIRING DIAGRAM (Davia) --> norros Defender Technical Discussions 30 July 7th, 2010 03:38 PM
Tdi electrical diagram artm Defender Technical Discussions 2 January 13th, 2006 08:52 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
A/C wiring diagram Shane@EVS Defender Technical Discussions 3 August 20th, 2004 08:46 AM
300tdi Wiring Diagram? JimC Defender Technical Discussions 20 April 7th, 2004 09:39 AM
» Defender Registry
Domino
Tripod
D 90
TommyB
Add your Defender
