Chassis number on military 2A - Defender Source
Old November 22nd, 2014, 03:16 PM
andy110
Andy Bard
1986 110 CSW
I have an ex-Canadian military 2A 109, no number plate on the bulkhead, can't find the chassis number above any of the spring hangers. What other locations could it be in? Could be that it has rusted over been patched over, what then?
Old November 22nd, 2014, 06:01 PM
LRover's Avatar
LRover
J. Michael McCaig
not sure if it's the same on the military series but on the other 2a's its on the right front spring hanger about 3 inches above the bolt. Try cleaning it really well with a wire brush on a grinder
Old November 22nd, 2014, 06:21 PM
andy110
Andy Bard
1986 110 CSW
Thanks, I did that today, I used a large grinder with a wire brush down to the bare metal everywhere I thought a chassis number could be. About two feet all around all four spring perches, and motor mounts. And found nothing.
Old November 22nd, 2014, 07:46 PM
post photos
Old November 22nd, 2014, 07:57 PM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
Both my 2a and s3 ex mods had them on the seat box. I never looked for it on the frame.
Old November 23rd, 2014, 12:43 AM
andy110
Andy Bard
1986 110 CSW
I looked all over the seat box and nothing.
------ Follow up post added November 23rd, 2014 12:43 AM ------
post photos
I'll do that on Monday.
Old November 23rd, 2014, 12:59 PM
leachy
Daniel Leach
9 LHD 300 CSWs 2017 Range Rover
Try inside on the bulkhead were the fuse box cover would be on defender.
Old November 23rd, 2014, 01:14 PM
andy110
Andy Bard
1986 110 CSW
Nothing there:
Old November 27th, 2014, 04:26 PM
andy110
Andy Bard
1986 110 CSW
Right spring hanger area, and seat box.
ID:	107700   Click image for larger version
Old December 4th, 2014, 03:03 AM
Greg S
Greg Sutfin
1986 90
You have posted a photo of an unmodified military chassis. That section that looks like a repair piece is actually a factory installed piece on the military chassis that provides the extended spring hanger with the two spring mounting locations. I have the same on my 109 SW.
You have cleaned off the frame horn looking for the number. You are in the wrong spot!!!!! (Bang head against wall.)
Spring Hanger is where you want to be. About four inches below and forward of where you've been cleaning. Just about the area that looks a bit yellow in the photo. In fact a bit above that. When I look closely at your photo there are two spots that look like they might have numbers stamped. The one just above the yellow area and another between your cleaned off area and the point of metal on the right (bumper bracket?).
If there was an identity plate on the seat box, it is mounted on the side of the box, staring you in the face when you open the drivers door. There should also be one on the passengers side of the bulkhead at the parcel shelf. Stares the passenger straight in the face when you don't have the "glove box" full of stuff. Look for a set of four drilled holes where one might have been removed.
What adds more value: early original chassis or galvanized chassis? nathanwind Misc. Chit-Chat 25 December 7th, 2012 09:49 AM
Part number for 300tdi D90 steering wheel? dmarchand Misc. Chit-Chat 12 June 22nd, 2004 10:28 AM
Part number for genuine roof rack? wicks Defender Technical Discussions 13 March 3rd, 2004 06:34 PM
Phone number. TwisteD90 Misc. Chit-Chat 15 January 14th, 2004 02:22 PM
Part Number Cross Reference Database mlepisto Misc. Chit-Chat 8 December 19th, 2003 12:52 AM
