Brass nuts on exhaust manifold - Defender Source
Old October 15th, 2011, 09:41 AM
kjva
Ken Jackson
1985 110 Wagon
Saw this on the Guns and Rovers forum. I always use brass nuts on the flange from the exhaust manifold makes them much easier to remove. When I called around I got the impression that it was not that common. I find when removing and fitting a series starter if I take of the exhaust manifold nuts a can move the exhaust pipe just enough to make working on the starter much easier.
Old October 15th, 2011, 12:55 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Yup, been using brass nuts on them for decades. They can still be difficult to turn sometimes so I only use 6pt sockets on them.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old October 15th, 2011, 03:11 PM
aka rover's Avatar
aka rover
ed angel
95 D90
I second brass nuts you thank yourself 5 years down the road when you need to service it again.
Old October 16th, 2011, 02:11 AM
Third brass nuts - we used brass flange nuts on our turbo hondas and they never seized, both on the exhaust studs and the turbo.
Old October 16th, 2011, 06:52 PM
red64chevelle
Daniel Smith
86 110 300TDI,16 Disco Sport
Fourth - it's a trend. We use them on VW's both turbo and regular exhaust manifolds.
Old October 16th, 2011, 11:06 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Local machine shop has re-done the exhaust studs on a few manifolds for me over the years, every time I get them back it has a bronze stud and a long brass nut on it.
Makes my life so much easier in the long run, well worth the cost and time to track the stuff down.
-Hans
My oil line fix
My 100k stopped odometer fix
exhaust
exhaust manifold temp? MUDSUX Defender Technical Discussions 4 November 19th, 2009 08:43 AM
300Tdi exhaust manifold problems crown14 Defender Technical Discussions 12 July 8th, 2009 11:38 AM
Whistle noise from exhaust manifold? markurski Defender Technical Discussions 11 November 27th, 2007 08:39 PM
Cracked Exhaust Manifold jamieh64 Defender Technical Discussions 9 November 22nd, 2005 01:04 PM
exhaust manifold bolts scoloco Defender Technical Discussions 9 June 1st, 2005 08:57 PM
