Brakes dragging - Page 2 - Defender Source
Old April 22nd, 2012, 05:13 PM
Not unless I am forced to pull the front drums to get the noise to stop
The short version for 88" series with 10" drums all round is this:
1. The bottom spring needs to be behind the shoes. Trickier to fit but seems to make a difference
2. The top spring has the spring offset to one side. The non-spring side needs to go onto the stud on the leading shoe that touches the snail cam, but the spring must go behind the snail cam, as well as oriented with the hook upward so the spring itself is as low as it could be, and then the other end hooks onto the stud on the backing plate.
Originally Posted by pendy
I'm here for the D's
brake
weak rear brakes? redrover Defender Technical Discussions 12 April 28th, 2006 09:24 AM
Wheelies and brakes! TwisteD90 Defender Technical Discussions 7 January 10th, 2006 10:31 AM
Tapping sound from brakes? Cyborg Defender Technical Discussions 7 August 1st, 2004 08:57 PM
Brakes: Slotted & Drilled or Not mhansen Defender Technical Discussions 2 March 29th, 2004 03:06 PM
Need rear brakes...DIY?? P1CR Defender Technical Discussions 17 March 6th, 2004 03:46 AM
