BFG AT tire size for Series 15" rims - Defender Source
Old December 23rd, 2010, 12:05 AM
Been down in VA away from the Series IIA since August, but heading back next week to wake it from it's slumber. It's time for a new set of rubber, what sizes are generally recommended? I'm on 15" factory steel rims, and I'm planning to go with BFG ATs.
Old December 23rd, 2010, 11:31 AM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
I'm not sure about the 15" equivalent but I have always run 235/85/16 on my series rigs and they are great.
Cheers,
Daniel
Old December 24th, 2010, 12:30 AM
Daniel:
Any chance you could post a pic of those?
Old December 24th, 2010, 01:12 AM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
Daniel:
Sure here is an older pic with my soft top truck cab.
Old December 24th, 2010, 09:40 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Remember they don't work for you unless you buy some 16" wheels.
Old December 24th, 2010, 09:47 AM
I know, just wanted an idea of how they looked...then I can use the ratios to do calcs on the 15s. Right now leaning towards 235/75-15s.
Old December 24th, 2010, 12:12 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
That would be a pretty small tire on a series, the AT is available in 30x9.50-15 which would look better.
Old December 24th, 2010, 12:42 PM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
I would think a 31/10.5/15 would be a great choice as just about all the usual tires are available in that size. Not sure if they are too wide for a series wheel but I bet they would fit. Good luck.
Daniel
Old December 24th, 2010, 01:19 PM
I'm a little leary of going too wide, as with the stock 15" rims I've heard things can get sloppy when turning/etc. But I think the 30x9.5-15 may just work...I hadn't realized BFG did that size, but I do see it on tirerack.
Old December 25th, 2010, 07:07 PM
Gentlemen:
Another stupid question: what the heck is the rim width measurement on the factory 15"? I know the 16" rims are 5.5" wide, is that the same for the 15s? If so...30x9.5 may not work, looks like min width needed is 6.5.
Ps - I'd measure myself but won't be at the Series until next week.
bfg, rims, series, tire
What is biggest tire size I can get on stock rims? Birdman Defender Technical Discussions 10 November 21st, 2009 11:09 PM
MTR Tire Size for OME lift??? TurkD90 Defender Technical Discussions 14 December 5th, 2004 08:44 PM
tire size mfreeman17 Defender Technical Discussions 8 April 18th, 2004 12:16 PM
yet another tire ? / opinion BFG januconn92 Defender Technical Discussions 18 April 8th, 2004 10:23 AM
maximum tire size snuffer Defender Technical Discussions 14 November 13th, 2003 09:15 PM
