Back flap chains - Defender Source
Old July 5th, 2015, 01:06 PM
Etienne's Avatar
Etienne
Etienne
Tdi 2500 diesel Defender 1985
Back flap chains
Has anybody an idea how to get rid of the chains/replace with what, that get caught in the back load flap when you close it. Please help.
Old July 5th, 2015, 01:16 PM
I've seen chains sheathed in clear PVC tubing from Hardware stores. Others have sheathed steel wire.
Old July 5th, 2015, 01:49 PM
It should not be a chain to begin with..... It should be a sheathed cable.
RRC5539, http://www.thexmod.com/item_detail.asp?id=1073
Old July 5th, 2015, 01:58 PM
87 D110 (Ruby)
Chains on Series trucks....they are sheathed in a leather cover x2 ea side
Old July 5th, 2015, 03:46 PM
The OP shows a Defender as his vehicle. Can't see any reason not to use the Defender cable on a Series. Same tailgate.
Old July 5th, 2015, 05:58 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Personally I prefer the chains.
Maybe it's not an issue on a Land Rover, never tried the cables, but I have cables on my F-250 and I hate them. They get caught and over time get damaged and break. Which sucks when you have a load on the tailgate.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old July 5th, 2015, 09:59 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Its an 85 and in South Africa maybe was a CKD difference or just being an 85 they were still using chains.
Old July 6th, 2015, 01:31 PM
Etienne's Avatar
Etienne
Etienne
Thanks guys. It is a UK import 110. I checked the serial and found it actually an '86 build/registration. Totally original with 132000 miles. I don't want to modify anything but these chains are very annoying. If I made folding flap holders from 25mm flatbar would I be out of line. The flap still has the pigtail hooks on for the chain. Will just keep these in case of resale.
Old July 6th, 2015, 01:35 PM
87 D110 (Ruby)
dude - your truck do what you like. The RRC came with such a setup - but you will have to ensure that there is enough room - then you are drilling holes in the tailgate and the tub...
ac
TWO RESTORED- ONE SPARE- 110/90 Rear Mud Flap Brackets NashvilleRover For Sale - Parts 1 November 4th, 2009 10:46 AM
Wanted: Defender 110 Front Mud Flap Brackets NashvilleRover Wanted 2 October 5th, 2008 11:45 PM
Front Vent Flap Seals Flagg Defender Technical Discussions 14 February 20th, 2006 05:14 PM
Rear Mud Flap Mounting questions - it's a 110 but I assume same applies for 90's solihul Defender Technical Discussions 2 March 8th, 2005 04:21 PM
rear seat belts flap in wind ONDROX Defender Technical Discussions 14 August 19th, 2004 11:56 PM
