Are OME shocks worth it? - Defender Source
Old October 30th, 2014, 03:39 PM
MexLuna's Avatar
MexLuna
Jared
1972 Series III
I recently purchased a 1972 S3.As expected it is a rough ride but I think it is time for some new shocks. I can pick up a new basic set for about $100 but is it worth the extra money to upgrade to OME shocks?
Also, how do I know when I should replace the springs? I have no idea how old the current springs are but if I change out the shocks should I do the springs at the same time? If so do I stay with the standard leaf springs or go with parabolic springs?
Thanks!
Old October 30th, 2014, 03:43 PM
There is no reason to ever replace springs. They don't wear out. OME shocks are nothing spectacular. I doubt it really matters much with stock leaf springs. One thing you can do to help out the rough ride is to open the leafs up, clean the surfaces and get a bit of lube in there. When not used off road a lot, they tend to rust together and not slide, which makes them quite stiff.
Old October 30th, 2014, 04:03 PM
MexLuna's Avatar
MexLuna
Jared
1972 Series III
By the way, I have a S3 88.
Old October 30th, 2014, 04:19 PM
LRover's Avatar
LRover
J. Michael McCaig
Leaf springs will go flat or will load up with rust and actually cause the leaves to break. Usually happens if the vehicle is left to sit for long periods. There should be a slight arch to the spring with no visible rust between the leaves.
Old October 30th, 2014, 04:25 PM
MexLuna's Avatar
MexLuna
Jared
1972 Series III
Thanks Red90! Any special lube you would use?
Old October 30th, 2014, 04:38 PM
MexLuna's Avatar
MexLuna
Jared
1972 Series III
Here are some photos so you can see what I have to work with:
Old October 30th, 2014, 04:54 PM
MexLuna's Avatar
MexLuna
Jared
1972 Series III
More
Old October 30th, 2014, 05:47 PM
the rover shop
shayne young
Slap a new set of parabolic springs under her and it will improve the ride greatly..
Old October 30th, 2014, 07:34 PM
Contractor's Avatar
Contractor
Will
1969 IIA
I have both parabolics and leafs on two different trucks. At the end of the day it's still a Series, leaf sprung truck.
2 leaf Rocky Mountains front and back with either OME shocks or the Pro Comp shocks give the truck a nice ride and a great stance.
I have not experienced any sagging from the parabolics long term, but others have. On the next truck, I will likely try a nice set of custom leafs.
It kinda boils down to how much you want to spend, I don't think OME shocks alone are going to blow your mind.
Old October 30th, 2014, 10:04 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
I know you dont have coil but for those new guys...coil springs do wear out, either through load or defect don't discount the possibility when diagnosing a problem. IMO, OME are worth the expense.
------ Follow up post added October 30th, 2014 09:05 PM ------
X2...
Old October 30th, 2014, 10:23 PM
I installed parabolics on a Series, and I thought it was a night a day difference. It still rode like shit, but a huge improvement.
Old November 1st, 2014, 08:54 PM
MexLuna's Avatar
MexLuna
Jared
1972 Series III
Thanks everyone for the help! I took it off road for the first time today and forced the springs to flex and move. It was probably the first time in who knows how long they've actually had to. The ride is a bit better now but I'm interested in those Rocky Mountain parabolics. I'll start saving. Cheers!
D2 Fender Flares, OME Shocks and OME 762 Springs KyleT For Sale - Parts 0 August 30th, 2014 12:33 AM
Koni Heavy Track Shocks +2 - Land Rover - 4 New Shocks JohnC The Vendors Loft 7 April 13th, 2010 09:34 AM
OME 761 & 764 OME Sprins /Shocks for Sale SafariHP For Sale - Parts 6 December 12th, 2007 09:34 PM
OME Springs and shocks Seanh Wanted 3 June 14th, 2004 10:13 AM
OME shocks are too long on rear axle... wicks Defender Technical Discussions 5 October 6th, 2003 02:39 PM
