Anyone know what this deposit is - Defender Source
Old July 10th, 2013, 12:58 AM
cdb
Clark Bowen
This is an inside shot of the block of my 2.25 litre motor with the pan off.
The white substance is mainly below the crank at the front of the motor (inside the block).
It comes off with a finger and is black and oily underneath and white and cracked on top.
Feels gritty and oily when rubbed between my fingers.
This is a Turner re-build with 25 - 30,000 miles on it.
It runs fine I just wanted to sand blast the pan and this is what I saw when I removed it.
2011 RR HSE -
2001 GMC 2500 4wd
Old July 10th, 2013, 06:40 AM
It's oil and water emulsified gunk. The water is normal more or less as condensation. Doesn't appear to be much there, so likely not indicating a problem other than maybe your breather system may need to be unclogged. If you had a cracked block there would be gobs of that stuff.
Old July 10th, 2013, 08:09 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
Bill is probably right. However, the "gritty" part is what would bother me.
Old July 10th, 2013, 08:49 AM
Pull the oil filter and valve cover to see if you find any more of that stuff there.
Old July 10th, 2013, 04:24 PM
cdb
Clark Bowen
Valve cover was spotless.
I'll check the oil filter housing next.
Thanks for the help.
2011 RR HSE -
2001 GMC 2500 4wd
Old July 10th, 2013, 07:39 PM
gchinsr's Avatar
gchinsr
Greg Chin Sr
1996 Discovery 5 Speed
Most likely concentration of Calcium from evaporation of moisture in the crankcase.
Old July 11th, 2013, 12:14 AM
cdb
Clark Bowen
It looks like calcium and that would account for the grittiness.
2011 RR HSE -
2001 GMC 2500 4wd
Contact to buy Slotted Bushings from AUS? LRNAD90 Defender Technical Discussions 8 September 20th, 2013 12:51 PM
I'm an idiot and so can you! akfisher Misc. Chit-Chat 4 June 5th, 2013 01:54 PM
Did someone here just deposit an $18.5M check?? LagunaDallasD90 Misc. Chit-Chat 9 September 29th, 2012 01:11 PM
Frame off Restored NAS Defender 90 300 tdi lrnasd90 For Sale - Vehicles 24 October 12th, 2007 09:32 AM
window leaks artm Defender Technical Discussions 10 May 5th, 2004 11:34 PM
