Anyone install air conditioning? - Defender Source
Old March 19th, 2013, 12:24 AM
Wildduke
Dean
Series 3 defender
Anyone install air conditioning in their series 3? Any advice on brands and what you used?
Old March 19th, 2013, 06:07 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Amy of the hot rod AC places like Vintage Air can help piece together a kit. Your biggest issue will be mounting a compressor to your engine, but it's just a matter of fabbing up a bracket. Finding something that works with your dash might be hard too.
Semper Fi!
Old March 19th, 2013, 08:49 AM
Viggen's Avatar
Viggen
Jarrod
none
I think the brackets will be easy. I had a friend with a IIa and wanted a/c. The hardest part was figuring out where the stuff that would typically live under the dash would go. There are a lot of places, like Vintage Air, with the pieces you need. Youll have to do some cutting to find room for it all though.
Old March 19th, 2013, 09:12 AM
winn442's Avatar
winn442
Winn Bearden
Shouldn't be too hard, if you've got a SIII dash then a UD-140 from nostalgic air should fit under the dash....fab up a compressor mount on the engine and a condensor up front and you should be in business
Winn Bearden
Old March 19th, 2013, 11:12 AM
scrubs
henery
1974
LRX. has a set up for sale
Old March 20th, 2013, 03:03 PM
blueleader
Doug Shipman
67 hybrid
In the good ole days, when driving the series down to Calif and other 100deg places, we just boughttwo bags of ice. Put one on each floor, and as it melted, no water to worry about, it just drained out on it's own. A good $2 AC that never took horsepower and never failed.....untill it all melted.
Old March 20th, 2013, 03:10 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Interesting. First post I've seen here from PNG. Are there lots of Land Rovers there? Sorry for the thread-jack.
Old March 22nd, 2013, 10:46 AM
gambrinus
Russ Wilson
1965 Dormobile
Local resto / hot rod shop that is a client of mine has put vintage air units in everything under the sun... If you want air in your rig, it can be done.
Old March 23rd, 2013, 02:43 AM
Wildduke
Dean
Series 3 defender
Thanks guys for the info. I'll certainly keep it for the next project, but I have decided not on to restore a series 3. It's a necessary vehicle, but I want something bigger. Thinking of either a 2 door 110 project or a 2 door range rover classic.
I might use your advice for either of those projects.
To chris,
There are quite a few land rovers in PNG. Most are newer defenders. I know of 2 series 3's, one restored one not. There are a couple of range rovers around too.
Old March 23rd, 2013, 07:49 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Just for reference there was a write up some on the RN forum. Typing on the phone so if I'm repeating then cool.
Old May 6th, 2013, 11:28 AM
Explorer0863's Avatar
Explorer0863
Tony Q
1957 Series I V8
While driving on the north side of the island of Puerto Rico 2 days ago, saw this '67 IIA for sale at a classic cars dealer.
It was interesting to me the fact that it had an after market A/C that was installed at a local shop. BTW, the guy was asking $29K.
ID:	71635   Click image for larger version
ID:	71639   Click image for larger version
ID:	71641   Click image for larger version
Tony
Current:
1957 SI 88" 3.9L V8
1999 Disco 2 White Gold
Previous:
1999 Disco 2 Rioja Red
1994 RRC LWB
1991 RRC SWB
1995 RRC SWB
1969 IIA Sta Wgn 109" NADA #798/811
Old May 6th, 2013, 11:55 AM
The Dro
Dro
1988 Ninety
AC only:
http://www.nostalgicairparts.com/air...r-only-101.php
With heater:
http://www.nostalgicairparts.com/air...r-unit-102.php
Old May 7th, 2013, 07:45 PM
The Dro
Dro
1988 Ninety
The compressor is a Sanden SD5H09. It has the double groove v-belt clutch.
But I think you can get away with one belt. You can see it in the picture from the PR truck.
Old May 11th, 2013, 10:19 AM
gambrinus
Russ Wilson
1965 Dormobile
Think outside the "box". Go to a car show and hang out with some of the hot rod guys and look at some of the set ups they use... you can get some good ideas if you're open to going "non stock".
Air Conditioning Parts Question for 1995 D-90 Retrofit Heath Defender Technical Discussions 2 May 25th, 2005 02:54 PM
Air conditioning scottheise Defender Technical Discussions 4 October 8th, 2004 10:13 AM
Air Conditioning azdefender Wanted 2 March 8th, 2004 01:41 AM
ARB air lockers install mhansen Defender Technical Discussions 1 December 29th, 2003 11:38 AM
