Any turbo experts here? - Defender Source
Old June 6th, 2015, 12:32 AM
Ignotus
gene
1960 109, w/200TDI
I am having my turbo rebuilt and there are some cracks in it. Are they serious? The shop doesnt' seem to think so. Oh yea, it's the exhaust housing.
ID:	122387   Click image for larger version
Gene
1960 109
1960 88 Ignotus
Blog;
Old June 6th, 2015, 12:41 AM
Gene,
You may want to read thru this before spending any money on a rebuild.
http://www.defendersource.com/forum/...rbo-61900.html
Old June 6th, 2015, 01:01 AM
Ignotus
gene
1960 109, w/200TDI
Thanks Dave,
Was following that thread until yesterday. I have the T2 turbo, a rebuild is some $300 less than a new, by the time shipping from the UK is factored in. Now I am at the "how much is the not having to worry about it falling apart on a trip" worth point. Hopefully it is the last thing to sort out before my project is done.
Gene
1960 109
1960 88 Ignotus
Blog;
Old June 6th, 2015, 01:05 AM
If you have a friend who is talented with a TIG torch he may be able to fix the cracks but I'm not sure what it is actually made of so that may not even be an option. I too would be worried about those cracks. Lets see what the now sleeping east coast brain trust has to say when they roll out of bed in a few hours.
Old June 6th, 2015, 01:11 AM
Ignotus
gene
1960 109, w/200TDI
Cast iron. I do know a welder who can weld it but this is pretty tricky and involves airflow and waste gate. Got all weekend to listen......
Gene
1960 109
1960 88 Ignotus
Blog;
Old June 6th, 2015, 09:30 AM
Scottyoh's Avatar
Scottyoh
Enigma RnR
'87 127"
That looks bad to me. I've got plenty of turbo experience in the import tuner world. Typically cracks in the turbine housing cause boost lag. That large crack through the wastegate flapper seat would for sure cause that. Although it could be welded, depending on your costs you'd be closer to a new turbo. Cast iron has to be pre-heated, back flow purged, and done extremely slow. After that the wastegate flapper seat would need to be machined flat again to ensure a proper seal. There is a good chance that it would crack in the same spots again due to it's brittle nature. Maybe someone has a good turbine housing laying around?
Pres - Florida Land Rover Club
Rovers 'n' Racing
407-720-9450
Old June 6th, 2015, 09:36 AM
To me, it wouldnt be worth wondering after repair if/when it was going to blow. Every road trip would be a gamble. Piece of mind for a few hundred more makes sense.
Mark Kellgren
KM4BOR
Old June 9th, 2015, 08:37 PM
i am with the folks who say the hotside is done. also check center shaft for bluing indicative of overheat. my guess is that bearings are bad as well.
my opinion: time for a new turbo. even an unrebuilt used unit would be better.
Old June 14th, 2015, 02:50 PM
carlosz's Avatar
carlosz
Carlos
try defenders north west, a customer sourced a new t2 for less than a grand, while purchasing from the paddock, shipping to the us and customs would have put a singe unit in about 1500 dollar range.
that crack looks small but when you add the heat from the exhaust it grows, thus impeding failure.
in third world countries I have seen welding of said fails but only because sourcing such parts is akin to pulling teeth with out pain killers.
good luck.
Old June 14th, 2015, 04:01 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Pull a KKK out of old Porsche 930...that mill won't know what hit it...
All joking aside, could you find a similar Garret that may have been more prevalent in the US and thus cheaper...with a manual boost adjustment isnt that the main issue..boost pressure?
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old June 14th, 2015, 05:07 PM
BlackField's Avatar
BlackField
Oscar
D110
Turbos are sensitive to a lot of configurations, they all don't pump out boost in any car in any condition. Wheel sizing, A/R ratio and Trim need to be tailored to the application.
Old June 14th, 2015, 05:09 PM
Best use for that is to be melted down and recast into something else. With all the heat and pressure, you're risking catastrophic failure.
Replace.
Old June 14th, 2015, 07:33 PM
t2 rebuild kits are less than $100. I see 1200-1300 degree's on my egt gauge daily. Once a crack starts in cast iron the 1000 plus degree heating and cooling cycles will accelerate it quickly . YMMV
Old June 14th, 2015, 08:00 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
I figured there was some technical aspects, but wasn't exactly sure...thx
Old June 14th, 2015, 09:07 PM
carlosz's Avatar
carlosz
Carlos
pardon my spell check it is meant to have read "impending failure", not impeding.
Any RRC value experts? knab The Flea Market 37 April 25th, 2016 06:00 PM
Turbo Diesel or Diesel Turbo? Paul K Misc. Chit-Chat 11 April 11th, 2013 11:59 PM
Any Air Conditioning Experts? Wolf Fabrication Defender Technical Discussions 8 September 15th, 2012 08:25 AM
Off Road Training weekend - Overland Experts in CT 3/29 & 3/30 pmd Trips, Trails and Events 2 March 19th, 2008 08:05 AM
Overland Experts - winter drving.... dmarchand Trips, Trails and Events 5 October 2nd, 2007 05:02 PM
» Defender Registry
Lloyd
rtcgb
Meh-Teh
thewap
Add your Defender
