Any chance the PO switch the front/real coils? - Defender Source
Old March 5th, 2015, 01:59 PM
WildBoar's Avatar
WildBoar
Derek Borror
109 withdrawals filled by a 110
Looking at the stance of my 109 coiler the nose is definitely higher than the rear. Is it physically possible that the PO inadvertently swapped the front and rear suspension coils during the conversion to the Designa chassis? I know the coils are different sizes and with other things I have found I would not be surprised that he did this.
ID:	115317   Click image for larger version
"I think we are good...its still dripping"
Old March 5th, 2015, 02:01 PM
It depends if they use 6" or 7" springs in the back. More likely it just needs heavier rear springs. Are there any markings on the springs?
Old March 5th, 2015, 02:12 PM
WildBoar's Avatar
WildBoar
Derek Borror
No, the springs don't have any markings. Probably need to just replace them along with the shocks.
Old March 5th, 2015, 02:18 PM
Problem is you really need to figure out what is in there and measure up how they are sitting to be able to choose springs that will suit what you need. Otherwise you will be buying and swapping a lot of springs.
Old March 5th, 2015, 02:21 PM
santana109
david
1983 santana 109
110s run wider springs in the back, so if you springs are the same width as the front that might be the problem.
Old March 5th, 2015, 02:33 PM
It is not a 110 though... It is a 109 on a custom chassis.... One "assumes" it uses 110 spring mounts, but never assume.
Anywho. Takes some photos of the springs. Measure the outside diameter of the springs and measure the height of the springs when parked on a flat surface. With that info, advice can be offered.
Old March 5th, 2015, 02:51 PM
WildBoar's Avatar
WildBoar
Derek Borror
Thanks guys. I take them off and measure to see what is really going on.
Old March 5th, 2015, 02:54 PM
Make sure you measure height on the truck first. You need that to figure out weights. Being a non-standard build, you need as much information as possible.
Old March 5th, 2015, 03:45 PM
WildBoar's Avatar
WildBoar
Derek Borror
Will do. Thanks again.
Old March 5th, 2015, 05:30 PM
You don't have to remove anything to measure. Just stick a tape measure in and measure the diameter. It will be obvious if they are not the same size.
Now, if you like the way it rides right now, just get some spacers for the front and be done with it!
Originally Posted by pendy
I'm here for the D's
Old March 5th, 2015, 06:38 PM
WildBoar's Avatar
WildBoar
Derek Borror
Gotcha, understand, thanks!
Old March 6th, 2015, 01:59 AM
Seems easy enough of a fix. I bet the rears are either shot or the wrong spec. A picture and measure the width of the coils and also measure axle spring perch to frame spring perch and we can get a close guess to get her back to a stock stance.
------ Follow up post added March 6th, 2015 02:00 AM ------
Some steel wheels 5.5" with 235 85 r16 or 7.50 16 tires would look great.
Old March 6th, 2015, 07:32 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by evilfij View Post
seems easy enough of a fix. I bet the rears are either shot or the wrong spec. A picture and measure the width of the coils and also measure axle spring perch to frame spring perch and we can get a close guess to get her back to a stock stance. ------ follow up post added march 6th, 2015 02:00 am ------ some steel wheels 5.5" with 235 85 r16 or 7.50 16 tires would look great.
. X2
Old March 6th, 2015, 08:07 AM
87 D110 (Ruby)
What year model is your truck? I have never seen a 110 CSW with a tropical roof, nor a cream colored steeing wheel and a split front window?
Belay that...just saw your sig! Uber is an understatement me thinks...
Old March 6th, 2015, 09:01 AM
WildBoar's Avatar
WildBoar
Derek Borror
Jonesy,
I am getting ready to dial up the uber with when I ditch the 2.25l for a 3.9l/R380/LT230 here in the near term.
Maybe I need to update my sig block to SIIa 109.5 when it is complete. Pretty soon I will have 3 different decades of parts on this thing.
Old March 11th, 2015, 11:46 AM
WildBoar's Avatar
WildBoar
Derek Borror
I should have done more research.
The front springs are 6"
The rear springs are 7"
Looks like I need heavier duty springs on the rears.
Thanks all!
ID:	115839   Click image for larger version
Old March 11th, 2015, 12:45 PM
Front shocks are upside down.
Old March 11th, 2015, 12:49 PM
6.5 coils on the rear springs? Not sure what those are.
Old March 11th, 2015, 01:56 PM
WildBoar's Avatar
WildBoar
Derek Borror
No, the rears are 7 inches.
Good catch on the fronts being upside down.
Old March 11th, 2015, 02:03 PM
No, I'm talk about the number of coil turns, which looks to be 6.5. Can't be genuine springs, AFAICT.
coil, switch
Rear Defrost Switch, Rear Wiper Switch, and Rear Wipe/Wash Switch bradfordish For Sale - Parts 5 January 26th, 2014 12:30 PM
Genuine Front and Rear Springs Coils from NAS 90 SMac For Sale - Parts 7 October 26th, 2013 01:24 PM
Head light switch repair - Is this 4 real? paulb Defender Technical Discussions 11 March 17th, 2010 02:53 PM
Deal of the week (last chance) 94 D-90ST dante18 For Sale - Vehicles 2 November 23rd, 2004 07:50 AM
Chance Meeting mlepisto Misc. Chit-Chat 0 February 6th, 2004 01:44 PM
