Alternator Question - Page 2 - Defender Source
Old December 6th, 2011, 01:11 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Urban legend boys. In principle, you would think, but it's a pretty common diagnosis tool. My alt didn't do shite when I disconnected it.
Been taking readings at the battery.
We can debate all day, either way I am getting a new alt.
Semper Fi!
Old December 6th, 2011, 02:14 PM
Originally Posted by Wolf Fabrication View Post
Urban legend boys.
Says the guy with the fubared alternator.
Old December 6th, 2011, 02:45 PM
Wolf Fabrication
Sterling Archer
'08 D3
Here's the offender. Mounting tabs look wider apart than the correct RTC5083 Alernator.
Semper Fi!
Old December 6th, 2011, 04:00 PM
Originally Posted by o2batsea View Post
Your battery should be reading 14.2-14.4 when the alternator is actually producing current. At 13.5 it's doing zippo. That's resting voltage for a fully charged battery. In addition a dash mounted gauge will be suffering some amount of voltage drop due to the wire resistance. Only when you put a multimeter across the battery terminals will you get a proper reading.
Wrong again.
12.7 is the battery voltage with no charging happening AND fully charged. Any voltage above that and the battery is charging. 14.2 Volts is the alternator control point and it will do that when possible.
My gauge is wired directly to the battery.......
Old December 6th, 2011, 04:32 PM
Correct for what?
Old December 6th, 2011, 04:40 PM
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by Ren Ching View Post
Correct for what?
The upgrade to alternator from the genny on early Series trucks, or so sez RN and RDS.
At this point I don't care what goes in the truck, it just needs to fit and charge. Truck is sold....
Semper Fi!
Old December 6th, 2011, 08:45 PM
Cool. I did not know there was an option like that for the series 1 motors.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old December 6th, 2011, 09:01 PM
Wolf Fabrication
Sterling Archer
'08 D3
Not really an option per se, you have to fab up some brackets. Although the LR one is different from my Argentine special, so I'll have to make it work.
Semper Fi!
Old December 6th, 2011, 09:45 PM
Originally Posted by Red90
Wrong again.
Yo dat shiz'dope yo!
Old December 7th, 2011, 09:14 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I still disagree that a motor idling is running off the battery (my logic point), as a motor is supposed to run by itself if you disconnect the battery. Am I off base on that? I've always diagnosed engine electrics that way.
If you've done any diagnosis on this engine doing that then the likely problem is your alternator, you've probably fried the diodes.
Disconnecting the battery on a generator equipped vehicle (while the engine is running) is ok, but should never be done on an alternator equipped one.
I see Ren beat me too it, but apparently it bears repeating as it's not urban legend.
For a Series that still has the generator brackets, the easiest conversion is an AC Delco 10si
http://www.lrfaq.org/Series/FAQ.S.alt_alternators.html
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old December 7th, 2011, 09:38 AM
Wolf Fabrication
Sterling Archer
'08 D3
Got it. Regardless, I've done it tons of times on old cars with no issue and didn't fry anything. I've never let the car run without the battery for more than a spilt second and never saw a spike in voltage from an out of control alternator. But I concede your point. Maybe I've just been one of the "lucky" ones.
I'm good on bracketry.
Semper Fi!
Old December 8th, 2011, 06:40 PM
Wolf Fabrication
Sterling Archer
'08 D3
Got the new LR alternator. On the back it has two terminals sharing a +, and one marked IND. What's IND? Field? Or is this a true one wire internally regulated alternator?
ID:	44549   Click image for larger version
Semper Fi!
Old December 8th, 2011, 06:44 PM
Wolf Fabrication
Sterling Archer
'08 D3
Hmmm. IND appears to be indicator light.
------ Follow up post added December 8th, 2011 06:47 PM ------
...and I no longer need a voltage regulator?
Semper Fi!
Old December 8th, 2011, 08:12 PM
It is for the battery light wire. That accepts the standard alternator connector. They are available in the UK for a couple of bucks. Voltage regulator is built in. I've got a few at home if you want one.
edit: here - http://www.autosparks.co.uk/product_...oducts_id=1218
How exactly is your truck wired up now? Having the correct battery light wiring is essential for the alternator to work. This is how it knows to turn on and will not work without it.
Old December 9th, 2011, 06:04 AM
Wolf Fabrication
Sterling Archer
'08 D3
Truck is wired with an external voltage regulator. That VR simply gets power from a keyed ignition source, then it had one wire going to the Field terminal on the alt. I think the alternator charge wire goes to the starter solenoid where it meets the battery, or might run to the ammeter, I need to double check.
Whats the easiest way to make this work?
Semper Fi!
Old December 9th, 2011, 07:05 AM
Factory setup for a Series III using the same alternator would probably be the closest thing to the load requirements of your truck. I just double checked the diagram to be sure- it goes like this:
Heavy gauge #8 (factory used brown) or so probably sufficient for the loads your vehicle will impose on the alternator. Run this directly from the large spade furthest away from the small IND spade to the same large solenoid or switch post that the main battery cable goes to.
Run another wire smaller gauge say #12 or so (also brown if you care) from the other large spade to the same terminal on the solenoid.
Run a third wire (factory used brown with a yellow trace directly (actually there were a few connectors in there) to the charge light on the dash. There should be a white wire coming off the other side of the charge light going to the ignition-switched side of the fuse box. Make the brown/yellow wire the same or similar gauge as the white wire.
I'll email you the diagrams.
Old December 9th, 2011, 09:27 AM
So, if the bulb in the charge light burns out you have no voltage sense current?
Old December 9th, 2011, 10:57 AM
The wiring schematic shows that stock Defenders have a resistor in parallel with the light, so it will still function with a dead bulb. I've never looked at what is physically installed.
Old December 9th, 2011, 11:24 AM
Wolf Fabrication
Sterling Archer
'08 D3
That was my question too.
So in theory, why not just run the IND to a switched power source?
Semper Fi!
Old December 9th, 2011, 11:31 AM
yes that is the case on the SIII's. As John says there is a resistor on the 90's to deal with that problem. Interesting, John, I did not know that until you pointed it out. Checked the diagram to see it myself. Though, have not had that issue with any of my Series vehicles.
FYI Jonathan, saw this in the 90 shop manual:
attery not being charged
AUTION: The vehicle
attery must never be
isconnected while the
mgine is running
alternator
