Alternate Brake M/C ? - Defender Source
Old August 21st, 2015, 10:57 AM
Ignotus
gene
1960 109, w/200TDI
I have been having leaking with 2 brake master cylinders, the leak occurs between the washers holding the reservoir to the MC. I am using Girling DOT4 fluid. A full res will now be MT in about 30 hours. I had the original MC replaced and the new one started leaking in 3 months. I am using a s3 servo and dual brake system.
So can any one tell me if the MC # NRC8690 (currently installed and leaking) can be replaced with the MC# 90577520?
The NRC 8690 has the roll pins holding the res on and the 905****** might be metric fittings?
Or is there and integrated res cast into the body option?
Gene
1960 109
1960 88 Ignotus
Blog;
brake
Seeking Alternate Part # - RTC5868 Firemanshort Series Technical Discussions 1 June 15th, 2015 01:09 PM
Alternate Parts List javelinadave Defender Technical Discussions 4 November 7th, 2014 07:16 PM
Alternate to new M998 LED tail lights for the trailer ezzzzzzz Smaller Projects 1 April 25th, 2014 01:23 PM
Have we sunk so low? (alternate version) ontheway Misc. Chit-Chat 1 August 29th, 2012 03:36 PM
Adding a Side Tank - Alternate Filler Method JimC Misc. Chit-Chat 6 October 25th, 2004 12:29 PM
