Air-conditioner box doesn't drain properly in my 97 NAS - Defender Source
Old June 28th, 2013, 08:47 AM
rd10014's Avatar
rd10014
Ronnie
1993 NAS D110
Issue, it's not the drain tube this is clear. Its the actual black box that needs to be resealed and put back together. The water drains from all areas especially when I make a sharp left turn the water then pours out of the bottom right hand side.
Question, I would like to open the air-codntioner box and clean, reseal and fix any hairline cracks, is this a big job?
Its NOT the drain tube that drains outside, it never even makes it to the tube.
Air blows very cold, would like it to drain properly.
Has anyone ever taken the air-codntioner box off, if so do you have the steps involved.
Old June 28th, 2013, 12:46 PM
I have not taken mine apart, but mine leaked quit a bit from where the refridgerant lines go in and out. finally sealed it with window sealant from Home Depot and it leaks no more. Was a pita to do. had to use a hand irror to get it in there. unfortunately, the mirror was my daughters princess hand mirror-glad nobody saw me
Mark Kellgren
KM4BOR
97, drain, nas
WTB: Defender 300tdi air box assembly and mount Mike Sandone Wanted 1 February 13th, 2012 11:34 AM
R380 in an NAS 97 D90 Conversion? GYM Defender Technical Discussions 19 November 5th, 2008 07:21 PM
WTB 97 NAS D90 AC system ECR Wanted 7 July 16th, 2008 07:58 AM
97 NAS 90 Owner's Manual dnewman9 Wanted 3 January 20th, 2004 12:50 AM
Tuffy console '97 NAS 90 with Auto ronward Defender Technical Discussions 5 October 7th, 2003 09:39 PM
