Aftermarket heater blower - Defender Source
Old April 4th, 2014, 05:18 PM
I have run into space constraints with my electric 109 and need to find a smaller blower motor for my heater. I plan to use a Mark IV distribution box on the inside which can house the heating elements so all the under hood side needs is a blower. Does anyone have any experience with these and or better ideas?
I am thinking I need something like this:
http://thmotorsports.com/spal/spal_c.../i-520405.aspx
However in an idea world the intake will be on the opposite side as shown and have a flange that I can connect a tube to. 3 speed preferred, and as powerful or more powerful than the original .
Another very similar one:
http://www.ebay.com/itm/3-Speed-Scro...W/291115448543
Originally Posted by pendy
I'm here for the D's
Old April 4th, 2014, 05:51 PM
Use a blower fan from a RRC aircon unit. I have a couple. I can bring you one at HH if you want. Fan speed is determined by a resistor. Use a generic AC Delco three speed one they have 1/4 inch spade connectors.
There are also in line 3" bilge blower fans, 3" vent blower fans and the mac daddy PAR/Jabsco 4" blower. Those are available flange mount or freestanding with hose barb in and out.
Spal makes a nice single squirrel cage fan.
Old April 4th, 2014, 05:53 PM
Seen this used on LR: http://www.jegs.com/i/JEGS-Performan...rentProductId=
Old April 4th, 2014, 06:03 PM
Do you have a picture of the RRC aircon blower? It would certainly be fitting to have one from an RRC!
Is it like this? http://www.landroversonly.com/forums...-burned-48960/
I have seen lots like that but was ignoring them. I guess I can make a custom box myself and use any of these.
Will search for the others thanks. I looked a few weeks back but wasn't getting great hits.
Originally Posted by Rocky View Post
Thanks but I should have mentioned i'll be using ceramic elements for the heater portion and I can fit that inside the inner parts. My coolant shouldn't be hot enough to use for heat.
So just need the blower in format that I can fit in the engine compartment side of the footwell with a big ass battery box limiting the size and position.
Old April 4th, 2014, 11:22 PM
Greg S
Greg Sutfin
1986 90
Are you planning on using electric resistance heating elements? If so, I suggest you do some calculations about how many Amps you're going to need for heating. Much better to go to diesel or even fire wood.
Old April 5th, 2014, 08:25 AM
Yes all electric. I have 800W (60A) at my disposal for 12V which should be plenty and it has very low draw from anything else on the 12V side. I have considerably more at higher voltages
Old April 5th, 2014, 09:15 AM
The RRC one is a self contained flange mount blower. Does not need a box.
Old April 5th, 2014, 11:37 AM
Greg S
Greg Sutfin
1986 90
800 wats will give you about 2700 BTU of heat. Pretty pathetic IMHO. A standard heater on a vehicle puts out ten times that much heat. Even more in many cases.
Old April 5th, 2014, 11:54 AM
I'd be willing to be a dollar that Charles will not drive the EV when it's balls cold weather.
Old April 5th, 2014, 01:55 PM
Keep in mind it really doesn't get that cold here, and it will be wearing a pickup cab in the winter, so not a lot of area to heat. The bar is pretty low in terms of the original heat, and really I just need to make sure I can defrost the windows (for safety). Everything else is gravy.
Bill, why do you think I won't drive it in the cold? I drive my 88" in the cold, and the defender too, both of which have larger areas to heat and marginal heaters.
I can't make happy hour this month. Could I bother you for some pics and dimensions? I don't want to wait a month and find I need a different plan.
Old April 5th, 2014, 03:10 PM
heated windscreen glass, heated mirrors, heated seats, plug-in heated snowmobile suit.
heater
Heater blower and broken 02 sensor for 94 d90 budz Wanted 0 November 12th, 2009 08:47 PM
replacement heater blower motor grnrvrs Defender Technical Discussions 4 March 5th, 2009 09:08 PM
1983 RHD Heater Blower Switch Part Number newfD90 Defender Technical Discussions 5 November 20th, 2008 02:38 PM
Need help with heater blower motor! Firefighter2904 Defender Technical Discussions 27 October 15th, 2007 09:51 AM
NAS 110 Heater/AC Combo Blower COSteve Wanted 2 July 27th, 2005 02:50 PM
