79 ex-MOD 109 2.25L Dead Ignition - Defender Source
Old April 16th, 2013, 08:37 PM
Bricktop's Avatar
Bricktop
Jon Paulikonis
1998 Discovery
Got my 79 towed out to my folk's house the other day. This thing has the most reliable 2.25L petrol I've ever seen..well, until I intervened. 20 degrees for two weeks? Pull the choke, and she starts right up.
So, I started her up, pulled her up on the rollback. Got there, rolled it off the tow truck in neutral - dead in all key positions.
No red charge light. Now, I know it wasn't the tow guy - he just secured the tires on the rig, and I followed him. I rolled the truck off without it running, and like a doof, I didn't unlock the steering. So, I think that's it. I must've jiggered something in the steering column.
We could get her to turn with my Discovery jumper cables hooked up. She'd start to fire and die.
I wasn't sure if some kind of freak other issue popped up, so that's why I tried the jumper cables. When holding the starter, it would act like it's running. Didn't do this much, as I didn't want to fry the starter.
Hopefully I didn't dork something up. Any advice is appreciated.
Old April 16th, 2013, 09:01 PM
I would check for a short in the wires to the ignition switch. Real easy to access.
Old April 17th, 2013, 07:52 AM
LRover's Avatar
LRover
J. Michael McCaig
If the engine turns over normally with the jumper cables attached but dies when you take them off I would guess it's something simple like a loose ground cable. Are the headlights bright when you turn them on?
Old April 17th, 2013, 09:13 PM
Bricktop's Avatar
Bricktop
Jon Paulikonis
1998 Discovery
Hi Mike - I did not try the headlights. Next time I'm out, I plan on checking the grounds, and I will add your input to the checklist.
109, mod
Removing Faulty Ignition Switch - It's STUCK rijosho Defender Technical Discussions 20 March 29th, 2017 12:54 PM
1966 SIIA 109 Pickup Ex MOD leafsprung For Sale - Vehicles 4 December 30th, 2008 04:48 PM
ex MOD 109 Series 2a fuel tank cellulararrest Series Technical Discussions 11 June 1st, 2007 11:56 AM
Thinking about "Defendering" a MOD 109 pickup - some questions for any.... solihul Defender Technical Discussions 1 May 19th, 2005 01:12 PM
