5 speed gearbox on a series 3 Land Rover with a 2.25 stock petrol engine? - Defender Source
Old November 19th, 2011, 08:29 PM
gabrielochoa's Avatar
gabrielochoa
gabriel ochoa
SERIES III 1983
Hello I want to improve the performance on my series Land Rover and would like to change the gearbox from the standard to a r380 or something like it.....
I have looked into overdrive options but still have that idea that a 5 speed would be even better.
I would appreciate any thoughts on this matter.
Thanks a lot,
Gabriel
Old November 19th, 2011, 08:37 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Thanks a lot,
Gabriel
An overdrive would give you 8 forward speeds and a heck of a lot easier to instal! I have a series and wouldn't even consider a 5 speed behind a 2.25.
Semper Fi!
Old November 19th, 2011, 11:40 PM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
An overdrive is a very easy install and RDS sells them at a good price. Probably the way to go.
Having said this, if you are willing to do a bit of work on the 2.25 gas motor a LT 77 will work and fit really nice. It is a super upgrade for a series motor IMHO
My last series motor was 2.25 built 30 over with a 2.5 cam. 2 barrel Weber with a Pierce manifold and 2 1/2" headers. It was a real blast and nice daily driver. Chris Laws at Badger Coachworks actually runs this combo.
A lot more work than a simple OD install but well worth the effort.
Best of luck
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
1995 Range Rover Classic 300 Tdi SoftDash (My Son's)
"Be the person your dog thinks you are"
Old November 20th, 2011, 02:17 AM
headdamage's Avatar
headdamage
Andrew
exmod 90 2.5na and a 93/RRC 200tdi
If you want to hook an LT77 to a series t-case Ashcroft makes the kit to do it:
http://www.ashcroft-transmissions.co...loads/lr77.jpg
http://www.ashcroft-transmissions.co...d&productId=83
Old November 20th, 2011, 10:15 AM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
How is your engine? I'd think you'd want more power than the stock engine if you really want to make use of 5th gear. As I recall most 5 speed conversions I've seen also had the engine swapped for something more powerful or a new turner engine installed.
Other considerations to think about might include the length of propshafts possibly changing and the e-brake linkage. I would assume the r380 and lt77 are both longer than the stock series gearbox.
When I added an overdrive to my series it was a wonderful improvement. I used it almost exclusively for the freeway, but there were a few times cruising off road where it was nice too.
Daniel
Old November 20th, 2011, 11:05 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
The R380 1st is a lower ratio than the Series III 1st, 3.321:1 vs 3.68:1, so in that respect performance will decline, IMO.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 20th, 2011, 11:38 AM
roverx's Avatar
roverx
Scott Preston
Andrew, totally forget about the Ashcroft setup. I have driven that and it is really sweet.
As for the length of the LT 77 . It has a short bell housing and is a direct bolt in to the 2.25 and 2.5 gas an 2.5 NA 2.5 turbo diesel.
The R380 has a longer longer bell housing because LR moved the 300 Tdi forward in the engine bay. You can fit a shorter bell housing to a R380. Ashcroft has the parts and sell this kit as well.
If you have an old tired motor this is probably not the best route. I would suggest a rebuild before going down this road. 30 or 40 over pistons and a 2.5 cam make it a really nice driver. The down side is I never got more than 18 mpg highway and usually 15mpg around town. Usually less, as I have a heavy foot I had to install an extra tank to have any kind of range.
Scott Preston
engine, series
2.25 / 2.5 gas engine for 110 kjva Wanted 6 February 3rd, 2011 07:01 PM
1966 series II deisel engine needed shamptonrover Wanted 6 January 22nd, 2011 12:09 PM
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
???still can't get the trany unbolted from the engine???? kit Defender Technical Discussions 4 October 23rd, 2003 03:20 PM
