3.9l swap - SIIa 109 Coiler - Defender Source
Old February 24th, 2015, 11:57 AM
WildBoar's Avatar
WildBoar
Derek Borror
109 withdrawals filled by a 110
And so the odyssey starts here...
I am sourcing the bits for the 3.9l conversion for my SIIa 109. The goal is to have the conversion completed by summer.
The plan is for a 3.9l/r380/lt230 combo to replace the existing 2.25l/SIII gearbox/transfer case/Fairey overdrive. The existing frame is a Designa Chassis coiler sitting on D1 axles w/disc brakes. No power steering at this time. And I am heavily leaning toward running a carb for simplicity.
I have searched and found some dated posts by a couple folks who did something similar. Hopefully they are still around to chime in throughout my process.
Let the bloody knuckles begin...
"I think we are good...its still dripping"
Old February 24th, 2015, 12:09 PM
TeriAnn's Avatar
TeriAnn
Teriann Wakeman
1960 Dormobile
About the only thing that comes to mind at the moment is make sure you get a r380 with the short Defender bell housing. If the 3.9 will be rebuilt, specify the "top hat" liners.
Are you planning to use a V8 Defender front clip & radiator?
TeriAnn
Old February 24th, 2015, 12:20 PM
Of what year?
Iain makes a nice chassis. So you have the regular size spring perches on the rear?
Depends on how detailed you wish to be. If you get into refurbishing every part count on a couple years to complete. Good luck and happy wrenching.
Old February 24th, 2015, 12:25 PM
The tranny is out of a 95' Defender 90, so should be correct.
We're hoping for a straight forward swap, after all we completely disassembled it, painted, and did the interior and put it back together in about 4 months last time (which include a new SIII tranny mated to the fairey and the original engine.
95' D90 - daily driver..
Old February 24th, 2015, 12:35 PM
WildBoar's Avatar
WildBoar
Derek Borror
The R380 is a "long stick" which is the short bell housing (hi-lo) behind the gear lever. I was thinking about using the Chevy style radiator (part # 1-25241) that you had referenced in an older post on another thread. Was going to try to set it on top of the cross member as I want to keep my bugeye fenders.
------ Follow up post added February 24th, 2015 12:42 PM ------
Originally Posted by o2batsea View Post
Of what year?
awe come on...how hard can it be?
I believe they are regular size perches as it is sitting on D1 coils right night. Sound right?
Refurbishing every part? Neh, I don't think so. I will go to level of ensuring that the engine is a solid runner (to include the top hat liners), the R380 is rebuilt, and the LT230 is solid.
Old February 24th, 2015, 07:24 PM
cdb
Clark Bowen
Do you really need Top Hat liners on a 3.9l. I thought they were to solve the problems on the later 4.0 and 4.6 blocks.
The cost for top hat liners is quite stiff too.
2011 RR HSE -
2001 GMC 2500 4wd
Old February 24th, 2015, 07:33 PM
phoenix37's Avatar
phoenix37
john
Derek let me know when you are back in Ponte Vedra so you can drive the LS conversion…it might change your mind about power plant choices… I think i got air at the top of the palm valley bridge
Old February 25th, 2015, 09:07 AM
WildBoar's Avatar
WildBoar
Derek Borror
John, I will be down there sometime next month and I would like to swing by to check that LS conversion out. Will let you know when the timing gets sorted out.
As far as getting air going over the Palm Valley bridge....now that sounds like fun! I could only pull a cool 30mph over that bridge with a very long head start from Publix!
Old February 25th, 2015, 09:14 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
Dereck I would highly recommend sourcing a 94/95 disco/RRC for all you parts. Ie wiring harness, ecu, engine mounts, acc's, manifold pretty much everything you will need. Then rebuild the motor to your desire, it's gonna cost a small fortune to buy everything individually. The radiator will not fit along with a few other things. Just so we are clear this is not a straight forward install, but it will be a fun one for sure.
Old February 25th, 2015, 09:55 AM
phoenix37's Avatar
phoenix37
john
sounds good…shoot me a text when you are headed down.. Trust me truck wouldn't do much better than 30 before the swap..
This is going over the bridge after the conversion…little loud without the trans cover in place but you get the idea.
Old February 25th, 2015, 10:12 AM
WildBoar's Avatar
WildBoar
Derek Borror
Brian, completely understand, definitely not a plug-in-play swap. Not looking forward to the initial fit of the engine and transmission getting the mounts right, but after that I think it will certainly be a fun swap. I will give you a call to talk about your thoughts on the mounts.
The actual parts are beginning to pile up...need to get the r380 rebuilt like we discussed. Would like to get that started more sooner than later.
------ Follow up post added February 25th, 2015 10:13 AM ------
Sounds good John! Shoot me some pics of your 110.
Old February 25th, 2015, 10:33 AM
WildBoar's Avatar
WildBoar
Derek Borror
Holy cow! That is pretty impressive!
Old March 6th, 2015, 01:55 PM
WildBoar's Avatar
WildBoar
Derek Borror
Almost in the right spot!
Going in the garage tonight for a bit of "refreshing"
ID:	115390   Click image for larger version
Old March 6th, 2015, 02:08 PM
phoenix37's Avatar
phoenix37
john
Let the good times roll! good luck
109, coil
BlueBoy 109 coiler for sale via ECR evilfij The Flea Market 61 March 8th, 2011 03:16 PM
1967 SIIA 109 5 door leafsprung For Sale - Vehicles 0 December 30th, 2008 07:43 PM
1966 SIIA 109 Pickup Ex MOD leafsprung For Sale - Vehicles 4 December 30th, 2008 04:48 PM
SIIA 109 Dormobile FS CL ECR The Flea Market 4 February 1st, 2008 03:40 PM
109 IIA Station Wagon 4.6 Coiler jbacon For Sale - Vehicles 21 May 31st, 2007 12:45 PM
