2A clutch/brake reservoir fittings - Defender Source
Old January 12th, 2014, 11:43 AM
I'm replacing my clutch master on my 88" after a disappointingly short life, and while I'm at it I figured it would be a good time to replace the non-stock plastic reservoir with cracked cap I currently have with a stock unit that is surplus from my 109". It cleaned up nicely (have not painted it yet).
ID:	87760 Click image for larger version
However I took the reservoir apart about a year ago to clean/refurb it and don't seem to have taken any pictures and so have a couple of questions
1. Which fitting goes in the bottom (inside the inner clutch tube)? The one on the right has a bigger washer that just fits inside the tube so I am guessing that one, although maybe the one with the side hole is to allow sediment to fall to the bottom of the reservoir and not go down the tube?
2. Was there any gasket or just the soft washer shown? I want to say no gasket but not sure. Damn what I'd give for a decent memory.
3. Where can I find these fittings in case I can't smooth out the pits on the end of one of them? I have searched my my goggle foo is weak this morning.
tia,
charles
Originally Posted by pendy
I'm here for the D's
Old January 12th, 2014, 12:03 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
The original config of that can is comprised of 2 hydraulic reservoirs.
One feeds from the side and is called the "outside" and one that sits inside the can with an open cylinder called the "inside" reservoir. The fitting with the open slot at the top fits in the bottom of the inside can.
In that way a clutch failure does not rob all the fluid from the brakes and vise versa.
You'll need to clean up the threads with a thread file or find replacement fittings.
There are seals for the fittings and reservoirs.
I don't see the inside reservoir in your picture.
RDavisinVA
Old January 12th, 2014, 12:13 PM
I have the inside reservoir thanks. #1 and #2 answered thanks! So any idea what kind of material the seals are, or where I can get these fittings and seals?
Despite being pitted the threads engage very nicely so I think I am fine there. Just the tip (tm) of the mating surface needs smoothing out, which I will try with some sandpaper. But if I can get new fittings I'd rather do that.
Oh, and I need to clean out the inside of the tube as well. Will try various solvents and see if I can find some pipe cleaners.
Old January 12th, 2014, 12:21 PM
Btw, here is a picture of the complete set of parts sans seals
Old January 12th, 2014, 12:48 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
They were made of a thin "doughnut" of buna, but I would go to a rubber supply and have then cut some out of viton.
RDavisinVA
Old January 12th, 2014, 12:57 PM
Thanks, I'll look into getting some viton. I should be able to laser cut some. I managed to get the pitting out of the end with some 600 grit sand paper and a drill, so seals should be all I need.
Old January 12th, 2014, 01:32 PM
Robert, how thin is thin? Would 1/32 be too thin? Viton is pretty pricey!
Old January 12th, 2014, 01:50 PM
Actually I think I'll try this 1/16" stuff I found cheap on ebay since I am waiting on a heater core fix
http://www.ebay.com/itm/Viton-Rubber...57773#shpCntId
Old January 12th, 2014, 02:15 PM
99% sure mine has just copper washers to seal the fittings which I got from a local parts store's bin of copper washers.
Old January 12th, 2014, 05:14 PM
I will try see if someone else can verify this Ron, but I tend to agree. If there was a washer I needed I would have taken a picture to remind me. Mine has what look like aluminum washers which I think do the same job, but I guess I could find copper ones as well. I just found out I can't laser cut viton (it has chloride in it) so making my own is going to be harder than I thought.
Old January 12th, 2014, 05:39 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
1/32 is too thin.
Go with 1/16, 3/32, or 1/8.
RDavisinVA
Old January 12th, 2014, 06:00 PM
Aluminium should work fine too. I know mine were shot so I found replacements. You could always smear some brake fluid resistant silicone on them when you fit them.
Old January 12th, 2014, 08:30 PM
61rover's Avatar
61rover
John Crouse
I painted my reservoir with this and I thought it turned out nice.
http://www.eastwood.com/ew-brake-gra...sol-13-oz.html
Old January 12th, 2014, 10:42 PM
I didn't event think about brake fluid resistant paint, thanks!
brake, clutch
Power steering reservoir leak - '84 110 cgalpin Defender Technical Discussions 7 December 26th, 2007 06:48 PM
Clutch Reservoir Cap texasdefender110 Defender Technical Discussions 2 January 26th, 2006 10:00 AM
brake reservoir jimmy salmon Defender Technical Discussions 4 November 10th, 2005 06:08 PM
Zerk Fittings on Drive Shafts ronward Defender Technical Discussions 15 January 23rd, 2005 11:27 AM
Lube Fittings Dfndr90 Defender Technical Discussions 4 October 14th, 2004 08:12 AM
