200TDi swap; cooling options - Defender Source
Old March 27th, 2014, 01:14 PM
east high's Avatar
east high
Gerad Davis
1967/s2a 88 200Tdi
I'll be installing a 200tdi into my 88" soon and I'm working through my options. I've read that the series radiator is sufficient to cool the tdi with the turbo blanked off. This makes me think it will also work with the turbo as long as the intercooler and oil cooler are used. My question to you guys is, what do you think about using an aftermarket oil cooler kit? This seems like my only option if I want to keep the series rad and run the turbo. Thoughts?
Old March 27th, 2014, 11:34 PM
gambrinus
Russ Wilson
1965 Dormobile
http://www.rondavisradiators.com/custom.htm
Aluminum... any size you want.
Oil cooler is NEVER a bad idea.
Not using the turbo on the 200Tdi is just an "interesting" choice. Others have commented on other boards etc... it's your truck, but that's one I'd think long and hard about.
You'll be pretty close to 2.5 power after doing a full "conversion"
Old March 28th, 2014, 01:06 AM
Pretty sure the turbo engine without the turbo is more of a dog than the 2.5 natural if thats possible.
Please read Bills thread here http://www.defendersource.com/forum/...eferrerid=3511
Before making any decisions you will kick yourself for later.
Old March 28th, 2014, 01:18 AM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
I'll trade you my 2.5 na for your 200tdi and I'll pay shipping both ways.
Old March 28th, 2014, 10:40 AM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
I think an aftermarket oil cooler would work fine. However, I would use a 200tdi radiator with the integrated oil cooler in order to free up some room for the intercooler.
The downside is that you would have to fabricate the mount and an expansion tank, but in the end I think you'll end up with a tidier install.
This is probably the nicest "200tdi radiator in an Series" that I've seen.
http://www.tinshackrestoration.com/2...adiator-mount/
Old March 28th, 2014, 10:59 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
ECR did a 300 install in a SIII years ago.
I've seen it up close and personally as the truck is here in VA now.
Pretty neat.
http://www.eastcoastrover.com/SIIITdi.html
Rent my
Old March 28th, 2014, 11:35 AM
east high's Avatar
east high
Gerad Davis
1967/s2a 88 200Tdi
I'm planning on running the turbo. I also have a Disco radiator to fall back to if my series rad doesn't work out. As of now I'm thinking I might try the series radiator with a military oil cooler off a 2.5 diesel.
From what I've read more Disco 200tdi, with the underslung turbo, are used in conversions simply because they are more plentiful than the Defender type. Getting the underslung turbo to fit between the frame rails, especially on a 109, is why most folks opt to blank it off and run without.
My tdi has the Defender high turbo setup.
Old March 28th, 2014, 12:04 PM
scrubs
henery
1974
RHD or LDH?
HUGE differences for the install.
Can be done if your decitaded to it.
If you like send ab PM with email address and some finished pictures of a LHD can be fowarded.
Old March 28th, 2014, 12:37 PM
east high's Avatar
east high
Gerad Davis
1967/s2a 88 200Tdi
Originally Posted by scrubs View Post
RHD or LDH?
Left hand. I'll PM you, thanks.
Old March 28th, 2014, 06:53 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I could have an aluminum rad for you to fit the series but with oil cooler integrated.
Legend in My Own Mind.
Old March 28th, 2014, 08:36 PM
Cool then you are golden. Randy/Tdiguy can hook you up with Allisport goodness.
200tdi, tdi
Alternator Replacement Options for Disco 200tdi isleofbones Defender Technical Discussions 7 February 23rd, 2013 03:27 PM
Auto transmission swap cooling options? Broncoduecer Defender Technical Discussions 39 September 24th, 2011 01:12 AM
Options for re-wiring a 200tdi alastair Defender Technical Discussions 23 May 25th, 2010 01:07 PM
Complete 200tdi, hoses, cooling etc.. JPBrown Wanted 5 February 21st, 2010 11:46 AM
Cooling options. ajh Defender Technical Discussions 0 March 3rd, 2009 02:31 PM
