200TDi into series: engine brackets? - Defender Source
Old December 23rd, 2015, 02:34 PM
east high's Avatar
east high
Gerad Davis
1967/s2a 88 200Tdi
The engine I have doesn't have mounting brackets. I did find new rubber mounts in the stash of parts that were included in the deal. What do I need to bolt the 200TDi block to the series frame? I'm finding different info on the web. Will the stock series brackets work, or do I need something else?
Old December 23rd, 2015, 02:49 PM
Stock series brackets will work. Though, the Defender one for the LH side allows for a bigger donut to absorb all those diesel vibes.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old December 23rd, 2015, 03:16 PM
east high's Avatar
east high
Gerad Davis
1967/s2a 88 200Tdi
Dang, that bracket is expensive.
It looks like a little cutting and welding here and there on the series bracket would give me more room for a bigger bush too.
Old December 27th, 2015, 09:38 AM
LRover's Avatar
LRover
J. Michael McCaig
The left side frame mount is ok, the right side frame mount you have to modify. I cut mine off and basically turned it upside down and welded it back on after aligning it up with new rubbers.
Old December 28th, 2015, 01:32 PM
transientmechanic's Avatar
transientmechanic
1972 SIII
Do you have a Defender or Discovery 200?
Old December 28th, 2015, 03:23 PM
east high's Avatar
east high
Gerad Davis
1967/s2a 88 200Tdi
I have a Disco 200 with Defender intake and exhaust. It's my understanding that the one good thing about the Disco into a Series swap is that the timing cover is in a better position than the Defender setup.
Old December 30th, 2015, 09:02 AM
? Better how? It's still tight in there no matter how you slice it.
Old December 30th, 2015, 11:34 AM
transientmechanic
1972 SIII
The disco timing case allows you to use the standard 2.25 brackets and frame mounts (no chassis welding).
However the Defender turbo and Series steering box will still want to occupy the same space.
Old December 30th, 2015, 08:01 PM
east high's Avatar
east high
Gerad Davis
1967/s2a 88 200Tdi
Defender turbo is on top. You might be thinking of the Disco turbo which hangs below the intake.
Defender:
Discovery:
Old December 30th, 2015, 11:05 PM
gambrinus
Russ Wilson
1965 Dormobile
Another tip that will make your life easier.. remove the turbo exhaust outlet. Cut it.. Turn the bottom to exit in a better location ( not at your steering ) Re-Weld. This welding job removes the need to do a power steering conversion. It's a specialist welding job, but worth it. I think I paid $50 for the welding job.
Old December 31st, 2015, 09:57 AM
transientmechanic
1972 SIII
No I am definitely thinking of the Defender 200Tdi manifold fouling the steering box. I wrestled with it on mine and just decided to go P38 power steering.
If its a RHD vehicle then there's no issue.
Old December 31st, 2015, 11:19 AM
east high's Avatar
east high
Gerad Davis
1967/s2a 88 200Tdi
You have details on this steering conversion?
Old December 31st, 2015, 11:21 AM
transientmechanic
1972 SIII
not on mine personally, its well documented throughout the web though.
basic details, I used a Defender steering column, custom bracketry to hold it in place, P38 steering box on the frame rail, and custom shaft connecting the two.
Converting a series Land Rover to power steering
Old January 1st, 2016, 10:15 AM
LRover's Avatar
LRover
J. Michael McCaig
I converted mine in preparation for swapping the engine. I'm glad I did because once the engine was in place there was no room for even the old throttle linkage. I used a P38 box and modified the Series column. Also some more info here:
http://www.defendersource.com/forum/...ect-58412.html
Old January 3rd, 2016, 11:25 AM
east high's Avatar
east high
Gerad Davis
1967/s2a 88 200Tdi
That looks pretty slick. This project seems straightforward enough except for keeping the Series steering wheel. I think I need more pictures for that part. Mounting the p38 box and fabbing a new lower shaft looks basic enough.
Old January 4th, 2016, 04:45 PM
east high's Avatar
east high
Gerad Davis
1967/s2a 88 200Tdi
That looks like a steering shaft from a RRC, is it not?
Old January 4th, 2016, 10:08 PM
LRover's Avatar
LRover
J. Michael McCaig
Yes, it is from a RRC. I cut the worm gear portion of the Series shaft off and welded the lower half of the RRC shaft to the Series shaft. The bottom portion of the RRC housing with the bearing is mated to the outer portion of the Series housing. I fabbed up a simple plate to bolt the lower housing to the bulkhead. It would be easy enough to use a pillow block bearing if you wanted to instead of the RRC lower bearing.
Old January 5th, 2016, 10:11 AM
east high's Avatar
east high
Gerad Davis
1967/s2a 88 200Tdi
Perfect! TYVM!
200tdi, ac, bracket, engine, rack, series, tdi
WTB: Series 24v generator engine brackets LR Max Wanted 0 August 24th, 2015 10:56 AM
Anyone here done a 200tdi swap into Series? nathanwind Series Technical Discussions 46 December 29th, 2013 05:17 PM
swapping a 200TDI into a Series vehicle using the stock transmission cdb Series Technical Discussions 19 October 22nd, 2013 05:08 AM
200tdi Swap into a 88 UK d-90 bossman429 Smaller Projects 21 May 26th, 2012 03:43 AM
200Tdi into 109 Ren Ching Smaller Projects 39 December 30th, 2011 05:45 PM
