200tdi intercooler opinion - Defender Source
Old March 18th, 2011, 04:39 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I'm mid swap on putting a defender 200tdi (thanks Tony) in my series 1. Motor is mounted and now I'm dealing with fitting all the bits in. Lots of small fitment issues....
Would running a 200tdi without a intercooler be a bad idea, even if I detuned it a bit?
What about longevity? If I make sure the EGT's stay good will there be there be any down side except a power loss?
I can make the stock radiator and engine driven fan fit if I dont run an intercooler (or run a small one). But with an intercooler it is really tight, and I would have to run a small electric fan. My thoughts on detuning are that I really dont need the full power of the 200, it will pull that little truck fine, and a little less power woudl be good on the transmission. It is an 86" soft top with a high ratio transfercase.
I'm trying to keep it as stock looking as possible from the outside, so no moving of the breakfast. thanks..
Old March 18th, 2011, 04:48 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I'd think with a little creative tube routing you could mount an IC in front of the radiator. I have a Saab IC between my grill and radiator in my Series III with the radiator in the usual spot.
Old March 18th, 2011, 05:17 PM
D90user's Avatar
D90user
steve
I have been looking at the saab intercoolers, and I can do that if I dont use the engine driven fan.
I think I can use a 300tdi intercooler if I go electric.
Are you running an electric fan?
But the simplicity of the fan clutch if appealing.
Old March 18th, 2011, 06:27 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
The Land Rover turbo diesel engine didn't last long and that didn't run an intercooler
I'd try and get one in somehow. surely there's space between the grill and the radiator.
Mike Hammond
Old March 18th, 2011, 06:51 PM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
You're stuffing a 200tdi in an 86 and you want simplicity?
I'd very much like to see some pictures of what you have going on, since I might try to do the same thing at some point in the future. I'm running a 2.5 NA in my 86 now, and I found that there isn't an abundance of room in there to run an engine driven fan. I'm sure it could be done, but I'm using an electric pusher on mine.
One problem seems to be that if you push the radiator too far forward to make room for a puller fan, you end up with it interfering with the front crossmember and the steering relay. But the intercooler is smaller and could probably fit in over top of the front crossmember and between the radiator and the grill.
It seems most logical to put the intercooler in front, hang a relatively thin but efficient aluminum radiator behind that, and then use a high cfm but low clearance Spal puller fan.
Figuring out all the plumbing will be fun!
Old March 18th, 2011, 07:19 PM
D90user's Avatar
D90user
steve
After a few hours of measuring, I think this might fit between the headlights up against the grill:
http://cgi.ebay.com/ebaymotors/ws/eB...m=170538328840
It will be close but I think I'll be able to keep the engine driven fan. Piping will be a pain, but no too bad.
I'm going to switch to power steering as the steering box barely fowls on the turbo. Could maybe shim it but....
I'll post some pictures.
Old March 18th, 2011, 08:19 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I can't get your ebay link to open. I have just enough room for the engine fan but run an electric puller fan now, noticeable difference in power believe it or not.
Old March 18th, 2011, 09:15 PM
D90user's Avatar
D90user
steve
try this:
http://cgi.ebay.com/ebaymotors/Turbo...Q5fAccessories
Old March 18th, 2011, 10:03 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
That would certainly be more than adequate.
Old March 19th, 2011, 04:02 AM
mikeslandrover
Mike Hammond
That's about twice the size of the standard one. Tyre smokin
------ Follow up post added March 19th, 2011 08:43 AM ------
I ran a series transmission behind a Rover 3.5 V8 for years with no problems, Torque out puts are similar but with much lower revs from the tdi.
A friend ran a disco tdi in a series 2 with 3.54:1 diffs for a long while just fine, it was a little rocket.
Mike Hammond
Old March 19th, 2011, 08:59 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
I have toyed with the idea of replacing my 2.25 with a diesel. I sometimes wonder if a front mounted intercooler is really the best option in this application.
Old March 19th, 2011, 10:02 AM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
Silly boy ... http://www.lrsoc.com/forum/index.php...48601#msg48601
Old March 19th, 2011, 01:30 PM
D90user's Avatar
D90user
steve
Originally Posted by UnfrozenCaveman View Post
I am an avid lurker on LRSOC.... but a LHD swap has a few issues that RHD does not, this being one, the steering being the other. That is a great forum
------ Follow up post added March 19th, 2011 12:36 PM ------
?? I'm all ears...
Old March 19th, 2011, 03:02 PM
UnfrozenCaveman
Keith Armstrong
Various
Oh rats, I forgot you were LHD.
Sorry.
KAA
Old March 19th, 2011, 03:51 PM
D90user's Avatar
D90user
steve
No worries... If I did not know about LRSOC I would be dead in the water!
Old March 19th, 2011, 05:33 PM
kevkon's Avatar
kevkon
kevin
Well, some car makers and race cars locate the intercooler in the fender area (smic) or even on top of the engine (tmic). Of course, these locations require proper ducting and even fans to work effciently. But there are options besides the front.
Old March 20th, 2011, 11:39 AM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Another option though it probably goes against everything a Series owner believes in; is an air to water unit pulled out of another vehicle. Then they can be mounted just about anywhere though the less air pipe the better.
Old March 20th, 2011, 01:48 PM
D90user's Avatar
D90user
steve
no pride here.
I looked at the air to water intercoolers but the addition of another waterpump made me stop looking.
I just pulled the 300tdi inter cooler out and it looks like it may be easier to fit.
any thoughts on these?
http://www.siliconeintakes.com/produ...890ca24716ca7d
completely useless?
Old March 20th, 2011, 03:34 PM
kevkon's Avatar
kevkon
kevin
Personally that looks like it would just take up space and collect heat from the proximity to the engine/exhaust. Not to mention that it looks like a good dirt collector.
Old March 20th, 2011, 09:10 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
It's not the most ideal setup, but here's what I currently have on my lhd 200tdi series. It fits in the cut-out pretty well. The truck currently has the original non power steering box. Here's where I mounted my intercooler, off a defender I think. I made some custom intercooler tubing with a couple 90 bends on each side to connect it. The pipes do have to go between the engine and the radiator (original series). So there are a few extra bends and I would bet there's a small amount of heat soak from the radiator at idle and slow speeds, but I think it's better than not running an intercooler at all.
Name:	Screen shot 2011-03-20 at 5.50.15 PM.png
200tdi, tdi
Larger intercooler on 200tdi DieselDef Defender Technical Discussions 6 October 23rd, 2010 12:05 AM
WTB 200tdi Radiator and Intercooler tomaco1 Wanted 2 February 12th, 2009 01:45 PM
Allisport Intercooler Santiago Defender Technical Discussions 5 June 10th, 2008 11:16 AM
1993 LR90 200tdi. globallandrovers The Vendors Loft 1 October 11th, 2006 07:16 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
