200tdi crank pulley, same for discovery and defender? - Defender Source
Old March 17th, 2016, 05:26 PM
Robbiekb
Robbie Booth
2004 Discovery V8
Heh all,
So the crank pulley in my 200tdi just got remodeled by the front dif in my 109. Mental note, need military bump stops.
Does anyone know if the defender and discovery 200tdis use the same crank pulley? Should do, right?
Old March 17th, 2016, 05:55 PM
Robbiekb
Robbie Booth
2004 Discovery V8
Follow up question.
Does anyone have the dimensions (or a part number) for the v belt on the 200tdi?
I'm broken down by an oreilleys. If I could get a v belt to work that might get me home I'd be extremely grateful.
Old March 17th, 2016, 06:50 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Crank pulley the same but not if aircon
Belt on disco 200Tdi gates 6281 Z 7270, 9.5/10mm x 700mm
LR or Def 200Tdi 15405BZ 11AV1030
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old March 17th, 2016, 07:06 PM
Robbiekb
Robbie Booth
2004 Discovery V8
Thank you!
Rovers north is about 10 days out on stock.
Anyone know of a stateside source for parts that might be a little quicker?
Old March 17th, 2016, 07:13 PM
roverman2010
1985 LR 90 200Tdi
What are you needing??
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old March 17th, 2016, 07:22 PM
Robbiekb
Robbie Booth
2004 Discovery V8
Ideally I need a new crank pulley, and at least one replacement vee belt (crank-alternator-water pump) for the disco 200tdi in my 109.
Old March 17th, 2016, 07:33 PM
roverman2010
1985 LR 90 200Tdi
Crank pulley? Damper or the pulley that bolts to the damper for the belt drive?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old March 17th, 2016, 07:56 PM
Robbiekb
Robbie Booth
2004 Discovery V8
its the pulley that bolts to the damper for the belt drive. Just got home so I can follow up posts with pics now.
Old March 17th, 2016, 08:10 PM
roverman2010
1985 LR 90 200Tdi
If this the correct one I can loan till you get one
ID:	145280   Click image for larger version
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old March 17th, 2016, 08:53 PM
Robbiekb
Robbie Booth
2004 Discovery V8
thats mighty nice of you, but in this case it's my own fault i broke my truck so it can sit idle while I wait for parts It's my own fault for not checking that the bump stops had been replaced by the previous owner with the military ones. Terri Ann's article on 200tdi conversion totally calls this out as an issue to avoid.
That does look like the correct one. Is that originally off of a Defender 200TDI ? From my google-ing it appears that the discovery 200tdi originally came with a separate belt setup and that the pulley off of the crank had 2-3 grooves depending on whether the car had AC on not.
Old March 17th, 2016, 09:42 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
When I build an engine conversion, one of the QA tests is to take a come-along or chain and connect the end to the bottom support of a cable ramp lift with the other end connected to the front frame section.
Then I raise the lift until it fully compresses the diff onto the bump stops in order to simulate full rebound.
Then you can see if any of the engine and attachments will potentially make contact with the front differential.
If it does, dear Watson you have a situation of the application of simple physics, as matter, anything that takes up space and has mass or weight cannot occupy the same space as a different body of matter that also takes up space and has mass or weight.
Such a collision of the two opposing bodies of matter will result in damage to one or both of the objects involved.
In other words don't allow the engine or any part attached to it strike the front differential or anything attached.
Limiting the front differential travel is more of a work around than real solution.
The real question is, can the engine be raised from it's current location and avoid a front differential collision without limiting the travel with military style bump stops???
Limiting your diff travel with Military bump stops will only mean that under "easy and unnatural" circumstances your front diff will "bottom out" by making a premature full travel that is actually much shorter than originally designed.
WHAM!!!
Not the optimal solution...
RDavisinVA
Old March 17th, 2016, 10:45 PM
Robbiekb
Robbie Booth
2004 Discovery V8
Hi Robert, thanks for your reply. I'll need to take a long look at how the 200tdi fits and whether there's any room to move it. However, none of the material I've seen on series 200tdi conversions that I've read has the engine mounts any differently.
Suspension is already impeded by the previous owner running the stock leaf springs but having added the significantly heavier diesel. Stock springs look way too flat. In a fairly mild first off-road test, the suspension proved itself to be shockingly bad as currently set up. I could probably run that heavily pot holed fire road in relative comfort in both my d2 or the classic.
First order of business is to repair what I broke. Then, I'll start looking at setting the suspension up correctly and try some mild off-road again. I want to explore what a properly setup leaf sprung truck can do before I start getting radical with a coil conversion (or taking the body off and putting it on my lwb )
Old March 17th, 2016, 11:32 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Originally Posted by Robbiekb View Post
Thank you!
Should have one we can pull from an engine for you - same PN as the 2.5NA Also have an air order ready to leave the UK if you wanted to add one on.
If it was a 300tdi I'd have one in stock for you.
Old March 18th, 2016, 12:38 AM
Robbiekb
Robbie Booth
2004 Discovery V8
Gig harbor? Not too far from me. I'll give you a holler in the morning.
200tdi, cover, defender, disco, discovery, pulley, tdi
Wtb: 200tdi crank pulley... RX6RCROL Wanted 4 February 6th, 2016 11:02 PM
WTB-200tdi crank pulley D90user Wanted 11 June 25th, 2012 01:44 AM
Changing timing chain, TDC, and the crank pulley assembly question flananuts Defender Technical Discussions 4 May 14th, 2012 10:16 PM
200tdi PS pump , Rad, and Crank pulley tomaco1 Wanted 3 April 17th, 2011 04:06 PM
Crank shaft pulley Mike Hippert Defender Technical Discussions 13 April 3rd, 2005 01:13 AM
