2.6 alternator - Defender Source
Old January 12th, 2014, 04:40 AM
greenmountainrover's Avatar
greenmountainrover
Derek Chace
84 Lightweight FFR
2.6 alternator
Im looking to upgrade my stock 2.6L alternator on the Shorland. Current one will not keep up with the systems that have been added (cameras and espar heater). Thus espar heater is now in lockout mode from a series of low voltage starts.
Any know of a good upgrade. I have heard it may be possible to use a 3.5L alternator.
Any ideas?
Green Mountain Rovers your Defender/Series sales and importation specialist.
802-655-4874
Old January 12th, 2014, 06:31 AM
What did those 2.6 have? 45 amp Lucas?
Old January 12th, 2014, 09:02 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Assuming the alternator is working fine, even if low amps, a low voltage fault makes me think you may have a wiring fault.
Have you tested the heater circuit resistance and calculated if it meets the requirement for the amp draw of the heater?
You may have two issues going on.
Can't help you on the alternator conversion, never looked in to it. I bet people on the UK forums have done them fairly often.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old January 12th, 2014, 09:26 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
The 2.6 generally had a 35 amp alternator.
It is possible to fit a 65 amp alternator from a different vehicle without any modifications.
While the delco can be rigged to fit a 2.25 engine, it needs custom brackets to fit the 2.6.
RDavisinVA
Old January 12th, 2014, 12:08 PM
greenmountainrover
Derek Chace
84 Lightweight FFR
any idea on what vehicle? May wind up going with a delco and just making a custom mount.
802-655-4874
Old January 12th, 2014, 12:45 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Been a while, best to check the lucas or bosch book for a unit with the same ears as yours. Also be careful with wanting to switch brackets so fast. Some of the top 2.6 brackets bolted on from the top to the block and were installed before the head went on.
In this case you have to remove the head to replace the brackets, but don't recall if it was the alternator or generator bracket as it has been 20+ years since I drove a 2.6.
RDavisinVA
alternator
MG Alternator and Starter Qs Hollywood Defender Technical Discussions 2 April 17th, 2005 06:31 AM
Alternator wiring tmore Defender Technical Discussions 5 April 11th, 2005 06:17 PM
Help With Alternator for a 97 UpnOver Defender Technical Discussions 5 March 20th, 2005 09:43 PM
Alternator Abrooks Defender Technical Discussions 8 March 15th, 2005 10:59 AM
Dual Batts and HO Alternator jamesriding Defender Technical Discussions 42 January 9th, 2005 04:27 PM
