2.25 Issues - Page 3 - Defender Source
Old February 8th, 2016, 08:15 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I would pull the plugs and get a compression check.
Hard starting when warm is sometimes a result of low compression.
When tying to start, does it ever want to slow way down or "jump backwards"?
RDavisinVA
Old February 9th, 2016, 04:39 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
If you want to spend a little and have a really neat wear eliminating distributor see this:
http://www.123ignitionusa.com/123gb4rv.pdf
The "Official" USA Site for 123Ignition Perfect Timing Every Time
Most "carburetor problems" really turn out to be ignition problems in my experience.
I've had good luck running a Rochester carb with a smaller main jet as well. I've also seen some very sweet running 2.25 engines using a side draft SU carb conversion.
Lashcap issues/valve cap issues trybul Defender Technical Discussions 6 January 9th, 2012 12:46 PM
battery/ electrical issues steve_brooks Defender Technical Discussions 1 April 23rd, 2004 04:05 PM
Chris, Verizon Email Issues Resolved!!! Glenn_Guinto Support & Suggestions 1 March 5th, 2004 09:44 AM
Front speaker wiring issues Hans Defender Technical Discussions 4 February 13th, 2004 11:38 PM
Electrical relay issues???? PMHAH Defender Technical Discussions 1 November 20th, 2003 02:32 PM
