1975 Series III 2.25 Diesel won't start when hot - Defender Source
Old January 11th, 2013, 12:09 AM
ROVERMAN1's Avatar
ROVERMAN1
Freddie
83 110 & 1993 NAS 110 1997 XD
Engine runs perfect; however, if I decide to drive and turn off the truck after any short drives it won't start again. When I turn the key to try to start the truck again it appears as if the battery was drained, the engine tries to turn once or twice, but there is no juice. After the engine cools down it will start right away. The battery is still fully charged. Any ideas???? Thanks
Old January 11th, 2013, 07:13 AM
giftshopduane
Chris luciano
72 Series 3 88"
Thoroughly inspect your battery cables, take a look at the connections at the starter itself. Sometimes wires and cables look great at the terminal ends but inside the sheathing it can be a real mess. Inspect all the wires in your starter circuit and block grounds. Sounds like a voltage drop somewhere.
Old January 11th, 2013, 05:26 PM
ROVERMAN1's Avatar
ROVERMAN1
Freddie
Thanks for the tips. Someone else also mentioned the starter going south? Could that be the case?
Old January 12th, 2013, 03:28 PM
gambrinus
Russ Wilson
1965 Dormobile
It could be when the starter cools down vs when the engine cools down. Voltmeter to be 100% certain on the batt. Then double check your ground. Then I'd opt for pulling the starter and go to your local rebuilder.
RW
Old January 12th, 2013, 05:31 PM
REDrum's Avatar
REDrum
Niall Johnson
1970 Series IIA 88 - Sandstone
Check all ground wiring. Battery to chassis is paramount. Hi friction washers help me with similar problem.
Toltec Coffee Team:
'99 UZJ 100 - for glamping and grocery getting
'94 FZJ80 - our Costa Rican coffee mule
'96 FZJ80 - 3XL, racked, shaved and dipped in Raptor coat
'70 Petrol SIIA 88 - a Costa Rican expat now with US citizenship!
'70 Petrol SIIA 88 - for Central America surf & coffee exploration
'56 Petrol S1 86 - a whole new kind of land rover hell...
Old January 12th, 2013, 05:45 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Give the starter a few love taps with a hammer when it does it; if it fires up right after then you have your answer
Old January 13th, 2013, 06:52 PM
ROVERMAN1's Avatar
ROVERMAN1
Freddie
Out of town right now. But will hammer it when I come back Thanks!!!
Old January 14th, 2013, 01:41 AM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Or after you drive it hot, park it on a hill, then try to start it normally, if it won't start then just bump start it, if it won't start then you know its not the starter.
Old January 14th, 2013, 11:39 PM
ROVERMAN1's Avatar
ROVERMAN1
Freddie
Will make sure I do that as soon as I return. Thanks
Old January 16th, 2013, 12:17 AM
ROVERMAN1's Avatar
ROVERMAN1
Freddie
Well, the starter has finally gone south...... Now the search begins for a new or use starter. Do you have one? Let me know.
Thanks to everyone for their tips
Old January 16th, 2013, 07:13 AM
Pm me.
Old January 16th, 2013, 08:54 PM
ROVERMAN1's Avatar
ROVERMAN1
Freddie
pm sent
Old January 16th, 2013, 11:24 PM
couga861900's Avatar
couga861900
Cougar, WM of Hiram 72
Land Rover Defender 90 2.5td
You might want to remove your starter and take it to someone who rebuild starters. I know where they are in NYC. It might be the bushings in your starter. Sometimes water gets trapped in the starter and freezes. If you hear several clicking noise, then that may be your problem.
Old January 17th, 2013, 03:43 AM
ROVERMAN1's Avatar
ROVERMAN1
Freddie
Thanks for the info.
97, diesel, series, series iii, start
My old 1975 Series III up for sale SeattleRRC The Flea Market 8 September 13th, 2011 05:25 PM
1974 Series III – Diesel 2.5L NA, RHD in Virginia Lriwater For Sale - Vehicles 11 April 20th, 2010 07:11 PM
Series III Diesel Drivetrain landrovered For Sale - Parts 9 July 14th, 2009 08:42 AM
Series III Salisbury landrovered Series Technical Discussions 8 December 20th, 2008 10:35 PM
Series III Cam Timing ... bossongs Series Technical Discussions 0 April 30th, 2006 05:11 PM
» Defender Registry
Queenie
Jedelmann
110
Mes788
Add your Defender
