Mr. Clean Auto Dry Carwash System. 2-pack - $9.99 - Defender Source
Go Back   Defender Source > Classifieds > The Flea Market
Old September 30th, 2009, 11:53 AM
Don't know if anyone uses this stuff, but if you want to, I just saw Buy.com is offering a 2-pack of this kit for $9.99 with free shipping. Usually retails for $60. Seems like a good buy.
Link:
http://www.buy.com/prod/mr-clean-aut...tml?adid=18007
Info:
Features-Free clean and shine with no need to hand dry
Motor Trend Approved Spot-free results guaranteed
Dry Rinse Polymer sheets water off your car for fast drying and leaves no residue behind
Pur water filter Removes water impurities which cause spots, even in hard water
Helps protect the clearcoat by cleaning dirt and water spots, leaving a shine on the surface
Ergonomic design to deliver Mr.Clean AutoDry results
Cleans without re-using dirty water
Thumb-Activated On-Off Switch
Power grip handle textured to prevent slippage
All grip selector knob designed for use with wet/soapy hands
Leak-Resistant Hose Hook-up
Durable ABS plastic housing
Soap reservoir with vacuum metering, always delivers a consistent soap mixture
Rubberized soap fill cap, attached so you never lose it
Safe For All Car Finishes
Also good for cleaning Motorcycles, RV’s, boats, Windows, siding, and lawn furniture
In the box:
2 Mr.Clean AutoDry Device
2 6.7 fl oz (200ml) Soap, With Dry Rinse Polymer
2 Starter Filter
Tech Specs
http://ak.buy.com/buy_assets/v6/july/dot2.gifMr. Clean AutoDry Soap:
http://ak.buy.com/buy_assets/v6/july/dot2.gifThe first part of the Mr.Clean AutoDry™ Carwash http://ak.buy.com/buy_assets/v6/july/dot2.gifDry Rinse Polymer™ sheets water off your car for fast drying http://ak.buy.com/buy_assets/v6/july/dot2.gifEasily removes dirt and grime http://ak.buy.com/buy_assets/v6/july/dot2.gifLeaves no film or residue http://ak.buy.com/buy_assets/v6/july/dot2.gifWorks with Mr.Clean AutoDry Filter to leave your car incredibly clean and shiny http://ak.buy.com/buy_assets/v6/july/dot2.gifMr. Clean AutoDry Filter:
http://ak.buy.com/buy_assets/v6/july/dot2.gifThe second part of the Mr.Clean AutoDry Carwash http://ak.buy.com/buy_assets/v6/july/dot2.gifRemoves water impurities which cause spots, even in hard water http://ak.buy.com/buy_assets/v6/july/dot2.gifIncludes a color-change indicator that changes from black to brown when it is exhausted http://ak.buy.com/buy_assets/v6/july/dot2.gifWorks with Mr.Clean AutoDry Soap to dry your car spot-free every time http://ak.buy.com/buy_assets/v6/july/dot2.gifNumber of uses varies on factors such as water hardness and usage http://ak.buy.com/buy_assets/v6/july/dot2.gif3 Independent Spray Nozzles:
http://ak.buy.com/buy_assets/v6/july/dot2.gifSprays soap solution http://ak.buy.com/buy_assets/v6/july/dot2.gifSprays filtered water http://ak.buy.com/buy_assets/v6/july/dot2.gifSprays rinse water http://ak.buy.com/buy_assets/v6/july/dot2.gifAlso for use on:
http://ak.buy.com/buy_assets/v6/july/dot2.gifWindows http://ak.buy.com/buy_assets/v6/july/dot2.gifBody & Mirrors http://ak.buy.com/buy_assets/v6/july/dot2.gifChrome http://ak.buy.com/buy_assets/v6/july/dot2.gifWheels & Tires http://ak.buy.com/buy_assets/v6/july/dot2.gifDoes not strip wax http://ak.buy.com/buy_assets/v6/july/dot2.gifHelps protect the clearcoat
Old September 30th, 2009, 02:29 PM
JBOD77
Jonathan
1995 D90 ST Beluga Black
It sucks. I bought mine. Used it twice. Took it off and threw it in the corner of the garage. 9.99 is a good deal, this way, when you throw it out, you'll only be out 10 bucks!!!
Just my opinion.
This is where I'm supposed to write something witty and funny; or something.
Old September 30th, 2009, 03:30 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
lol one of my tenants left one of those behind, he said I could have it, wonder why
Robert Deniro
ac
Help - Need 97 Auto tranny cover/console jbgunner Defender Technical Discussions 10 January 17th, 2006 08:09 AM
Anyone know where I can buy an OEM exhaust system for my 2.5 RHD NA Diesel in the USA solihul Defender Technical Discussions 5 October 7th, 2005 02:08 PM
Double "S" Stainless Steel Exhaust System edducati Defender Technical Discussions 11 July 23rd, 2004 10:43 AM
rail system hooks & anchor point mounts paulb Defender Technical Discussions 2 November 24th, 2003 01:16 PM
