Mk2 X-Eng X-Brake - Defender Source
Go Back   Defender Source > Classifieds > The Flea Market
Old February 10th, 2011, 01:03 PM
rondo
Rondo B
Defender 100
Mk2 X-Eng X-Brake
I have a brand new, never installed X-Brake from X-Eng.
Details:
http://www.x-eng.co.uk/X-BrakeDef.asp
If you drive off-road, you know how useless the standard Land Rover transmission brake can be. The brake itself is fine, its just that it traps muddy water inside which rapidly grinds down the shoes and bungs up the mechanism.
Our Disk Transmission Brake uses a state of the art monster size mechanical caliper designed for agricultural vehicles and earth moving equipment - so use on a Land Rover is a walk in the park for it! The mechanism is sealed so it will not seize up due to ingress of mud or water and it uses special 'sintered' pads which are resistant to abrasion from mud as well as providing greater friction against the disk than a standard pad.
Replacement pads are readily available from us. We doubt however that you will need any for many years.
The disk has been specially designed for Land Rovers. It is made from tough 10mm thick steel. It has a smaller diameter than a standard drum and does not dangle below the transfer box to help protect it from whatever you are driving over. The caliper mechanism sits in a well protected area at the top, away from most of the mud and water.
This is the Mk 2 X-Brake which is improved but now only fits the Defender 90/110. The older style (http://lucky8llc.com/Products.asp?ProductID=2089) fit the RR/D1/D2 as well. This one will not.
Took the drum brake apart, decided it was in good enough shape, and won't be using this one.
$400 takes it home. Located in San Diego (92124), can ship, but this thing is heavy. Expect about $40 shipping.
Old February 10th, 2011, 06:33 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Out of curiosity, why won't it fit a Disco or RR? If you can be more flexible on price I may be interested.
Semper Fi!
Old February 10th, 2011, 07:05 PM
rondo
Rondo B
Defender 100
No idea actually, just going off of what X-Eng has said about their product.
Old February 11th, 2011, 04:12 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
I love mine. This is a good deal
Old February 11th, 2011, 04:25 PM
rondo
Rondo B
Defender 100
Thanks, yeah it looks great. Really quality construction.
Just sitting in my garage!
Old February 11th, 2011, 04:29 PM
Wolf Fabrication
Sterling Archer
'08 D3
Check your PMs
Semper Fi!
Old February 11th, 2011, 08:27 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Originally Posted by Wolf Fabrication View Post
Check your PMs
Hope you got them Jonathan.........it's an easy install and I think a great upgrade. Post up the install if you do it.
Old February 11th, 2011, 08:44 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Is this to suit an LT95 or the LT230?
Old February 11th, 2011, 09:18 PM
rondo
Rondo B
Defender 100
Lt230.
Old February 12th, 2011, 04:21 PM
rondo
Rondo B
Defender 100
If you're local, save a hundred bucks off new!
Extreme low ball offers are ignored.
Old February 12th, 2011, 07:54 PM
Wolf Fabrication
Sterling Archer
'08 D3
Maybe if you responded to those offers you might be able to negotiate and get it sold. Good luck with your sale.
Semper Fi!
Old February 13th, 2011, 12:36 PM
dogbite's Avatar
dogbite
Paul D
95 D90 ST & SW
I'm interested.... Do you think this would fit in a USPS "if it fits it ships" box? PM sent
Well
My iPad won't let me pm you so I'll have to do it on Monday when I get back to CO......
Old February 13th, 2011, 03:34 PM
rondo
Rondo B
Defender 100
I suppose it probably would. That'd make shipping much more affordable, probably about 15 bucks. I'll swing by the post office, pick up a box and make sure.
Old February 19th, 2011, 11:54 AM
dogbite's Avatar
dogbite
Paul D
95 D90 ST & SW
this still around? PM sent....
Old February 23rd, 2011, 11:12 AM
rondo
Rondo B
Defender 100
Sold!
brake
Clogged brake lines? Heath Defender Technical Discussions 11 February 24th, 2006 08:39 AM
Emergency Brake Issues Ragland Defender Technical Discussions 10 April 7th, 2005 07:09 PM
Brake light on after brake install wicks Defender Technical Discussions 6 October 13th, 2003 07:01 PM
