Merc 300TD powered Disco 1 on ebay (not mine) - Defender Source
Go Back   Defender Source > Classifieds > The Flea Market
Old October 12th, 2011, 10:23 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Interesting conversion
http://bringatrailer.com/2011/10/09/...ver-discovery/
http://cgi.ebay.com/ebaymotors/ws/eB...095+&viewitem=
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old October 12th, 2011, 10:27 AM
The Dro
Dro
1988 Ninety
At $6.3k he should take and run.
Old October 12th, 2011, 10:48 AM
Rugbier's Avatar
Rugbier
Gustavo
I think he wants like 12k
NO SIGNATURE
Old October 12th, 2011, 08:35 PM
kjva
Ken Jackson
1985 110 Wagon
Somebody at the MAR told me he was working on a kit to install the 300 Merc engine in a Defender the cost was going to be around $6k
Old October 13th, 2011, 02:03 AM
Robert Davis
Old October 14th, 2011, 11:43 AM
diff to oil pan clearance much?
Old October 16th, 2011, 05:12 AM
LtFuzz's Avatar
LtFuzz
Felix
'95 6.2L DI, '04 DII
I swear I'm not affiliated with the owner -- but I'm very familiar with this motor as my last obsession was '70s Benz W123s so I'd like to stick up for it and write you an essay.
As far as alternative diesels swaps the OM617 is a great option. Power is right there with the 300tdi. Reliability is absolutely epic. Not "sweet bro! a diesel! it'll run forever!" epic, but literally epic, as in tens of thousands of 617s across the world chattering away long past 300,000 miles as the rest of the car rots away around it. Drive more than an hour on any given day in a population center in the U.S. and I guarantee you'll see at least one or two 300TDs chugging down the road. Probably on its 6th owner whose dad gave it to his college daughter who sold it to her now ex-boyfriend and it hasn't seen fresh oil in 25,000 miles. That kind of epic. (You can say the same about Rovers, except that the MBs you're looking at are probably at least 10 years older.)
This truck here has been posted all over the American LR universe -- most people are trying to say it's "underpowered" and "too slow" and probably won't even hit 20 mpg. First point is that the OM617 isn't a turbo-charged OM616. Lotta people think that's the case but let's remember that when MB made the 617 they added a cylinder. It's a turbo'd inline 5, not just a 616 (4 cyl) with a turbocharger.
Slow? Yes. You folks here have probably driven more 300tdis than most. The 300tdi isn't "quick" by any means. I have a very hard time believing the 300TD in a Disco would be appreciably slower off the line than a 300tdi, in stock or built form (truck wise). The HP/lb ft numbers are pretty darned close.
MPGs? Well, most Americans think the OM61x motors are magic 35 mpg machines and hold the motors to that standard no matter the application. The reality is they are incredibly overbuilt small diesels put in incredibly overbuilt luxury cars (in that era) developed when the market was just beginning to see increases in crude oil prices. Most W123 wagons were pushing 4,000 pounds. I never got below 24 mpg in my last OM616, and got 25mpg at 70mph (much too fast for OE 4-speed). When I drove relatively carefully 27-29mpg was easy. Knock out a few for the 617 turbo and extra cylinder, the Disco weight/aerodynamic reduction, and then add a few for the taller R380 ratio and I think his claims are accurate. My best guess would 16-18ish pure city, 22+ pure highway, but 25mpg doesn't sound crazy if he sat at 55-60mph on flat interstate.
If I were looking at this truck my first question would be how he mounted the motor. My '95 DI 6.2L Detroit diesel uses stock (DII) motor mounts, a nice peace-of-mind when the opposite is wildly fabbed brackets and other creative solutions of dubious durability. The OM617 is a relatively small motor, smaller than a 300tdi (I think, I don't know 300tdis so well) and both are definitely smaller than my Detroit (which fits into the D1 engine bay like a stock V8), but I'd still like to see some pictures of the mounts. Someone mentioned oil pan clearance -- that's just the angle of the photo. The OM61x pan isn't deep and your diff will never touch it unless you're doing something very wrong.
Adapter plate he used is no issue -- anyone doing a swap can find a commercial piece or a template to make anything bolt to an R380 at this point. My 6.2 has been dropping 330 ft lbs to my R380 for 12,000 miles and I don't even have the 2nd gear grind that a lot of you V8/tdi folks have.
Tachometer is a common issue with these swaps -- there's no way to hook it up to the OEM gauge without getting seriously creative. Easiest way is to get a TinyTach or equivalent and splice the transducer into fuel line (easy peasy.) You'll still have a dead OE tach gauge but I have yet to see a way around that. Taking apart a TinyTach, soldering the circuit board to talk to a small 'lectric motor and using that to drive the OE tach? Now we're talking creative!
A/C? Easy to retrofit he says? HmmMMmMMMMMMmmmmmmm....
I have the same issue in my 6.2. Room to mount the compressor, etc, isn't an issue, and I have all the fittings, etc. ---- it's finding the belt to drive it! When he pulled the V8 and dropped the 617 in, what did he do with the 617 A/C pulley? He might've used it for the vacuum pump or something. The same case of too many systems to power/replicate but not enough pulley availability with the ultra-basic diesel motor that I'm dealing with. And you can't just add pulleys real quick. In order for me to free up a belt I'd have to convert my vacuum pump to a mechanical/gear driven unit. Not that hard, but it means moving other things, etc etc. and you know how that goes. Not a full-on hardcore job but I'd be skeptical about "Oh so easy just hook up original parts!" Although to be fair maybe the pulley is there and just waiting to be converted to serpentine. And another nice benefit of the relatively vacant Disco front clip is being able to mount an intercooler...
I'd want to know more about this if A/C was a requirement for me.
Mileage at 100,000 shouldn't throw anyone off. That's nothing. My 616 had 246,000mi and when my MB mechanic and I took the top end off for funizes it looked barely used, no sludge, nothing -- and that motor was built 5 years before I was born. Parts? Puh-leeze. MB build ten billion OM61x motors. The lack of fresh motors available shouldn't be an indicator of a lack of a parts market but an indicator that these freakin' things run forever if given even rudimentary maintenance. There's little demand for crate motors because you can't break these things.
What's the point of this ridiculously protracted essay? If the conversion has been done right that is a steal at $12k (if that's his suspected reserve, as someone said), considering a good 300tdi conversion will last you literally half as long and cost almost exactly twice as much. Hell I'd say even at $15k it'd be a pretty good deal assuming the rest of the truck was straight.
I really love this truck, wish I could go check it out.
Old October 16th, 2011, 09:15 AM
agreed on all points except the oil pan aspect of this conversion. The fellow in Virginia has spent 5 figures on design work,castings etc to rectify this. First thing he did was take a 110, fit the engine, then fully compress the suspension with ratchet straps and he found there would be interference. His solution has been a different two part oil pan, custom oil pump with different pickup tube and custom mounts and adapter plate that tilt the engine slightly. He's trying to make it such that when someone orders one of these kits you tell him which application ie disco with hp22 or Defender with r380, or series 109 and he can take the items needed off the shelf. Kind of a visionary project in my opinion.
Isn't the 617 engine highly tunable for more power ? I have read some of the Gwagen guys going with pump and injector mods with 200+hp and incredible torque figures. This seems like possibly the only non-rover engine I'd transplant and I have had a few defenders with different engines.
Old October 16th, 2011, 02:12 PM
LtFuzz's Avatar
LtFuzz
Felix
He really had oil pan interference? Or was it preventative?
Indeed the 61x boys can be go wild with tuning -- MB made many turbochargers that people like to retrofit, and some guys even run giant Holset turbos from the Dodge 5.9L. One you start boosting of course you'll lose economy -- but the guys over superturbodiesel.com (the Pirate4x4 of crazy MB diesel tuning) definitely bring the awesome:
Here's an Hy35 in a W116 (617):
Here's his 0-70 mph clip:
Old October 16th, 2011, 02:28 PM
cool clips. yeah the pan was 1/4 inch from front diff with no compression of the bumpstops so any signifigant compression was going to be oil pan on diff and the oil pickup on those engines is right in that part of the pan.given how cheaply these engines are in pick and pull yards and how tunable they are I'm kind of on the edge of my seat to drive one. Unfortunately his first will be a 109, then the 110, and then an automatic disco. He's already got these trucks sitting there waiting for the swaps. For the diesels he's going to use 300 tdi torque converters and trans governors from BMW 524 td autos (also 4hp22 cars). The flywheels are again some pretty cool custom milled parts as are the hd flex plates. Should be interesting.
Old October 16th, 2011, 02:49 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Hasn't he already put one into a LWB?
Old October 16th, 2011, 03:21 PM
nope thats an isuzu tdi.
Old October 16th, 2011, 03:29 PM
LtFuzz's Avatar
LtFuzz
Felix
Very cool -- who is this fellow and does he have a website or build thread or anything?
I'd love to know if he's played around with larger domestic turbos + intercoolers.
Check out this setup: http://www.oliverdiesel.com/friends/sakd110.htm
Old October 16th, 2011, 10:35 PM
yeah-owned the roof basket off of Ryans 110. He pulled the 6.5 about 5yrs ago due to the extreme weight and went with a 2.8 international with auto. He was paying with tcase ratio's last I heard.
Robert doesn't modify injection systems-he's kind of a wimp that way. He's never even played with the tuning of his 300tdi 110. So no bigger turbo's etc.
disco, ebay
04 Disco, off road equiped, low mileage on Ebay Capt Milks The Flea Market 0 October 11th, 2011 06:44 AM
'96 Disco I TReK on Ebay Stmpede Misc. Chit-Chat 0 April 18th, 2007 12:50 AM
Help empty my garage! Ton's of parts.. RedRhinoProducts For Sale - Parts 12 June 1st, 2005 09:24 AM
eBay auction policy changes chrisvonc Community News & Announcements 0 October 13th, 2004 09:45 AM
97 trans/xfer into 95 Disco boxerhips Defender Technical Discussions 4 June 10th, 2004 01:08 AM
