M116A2 Trailer - Defender Source
Go Back   Defender Source > Classifieds > The Flea Market
Old January 18th, 2012, 09:34 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
M116A2 Trailer
Today (as captured in the Sightings thread) I zipped down to New Jersey to pick up a trailer. The M116A2 is one of those military trailers designed to carry a diesel generator. I towed it back to Rhode Island, and it tows like it's not even there. If anybody in the area is looking for a flatbed trailer to use as the basis for a project (or to use as is), this could be an opportunity. The guy has a couple left, and I got the feeling that there could be more to come.
<http://cgi.ebay.com/ebaymotors/Military-trailer-/190629332772?pt=Motors_Trailers&hash=item2c6264c72 4>
John Karlsson
Hope Valley, RI
Old January 19th, 2012, 09:01 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
Another place to check would be here: http://www.govliquidation.com/
This is direct from the government. Those trailers and other trailers come up all the time at various places around the country.
Here is a current example
http://www.govliquidation.com/auctio...tionId=5009133
Old January 19th, 2012, 10:16 AM
John_Karlsson
John Karlsson
I've followed the gov't auctions for a long time, but I never found one within striking distance. With this seller I was able to drive to NJ, pick a trailer, hand over the cash, and be home in less than eight hours.
John Karlsson
Hope Valley, RI
Old January 19th, 2012, 11:44 AM
red64chevelle
Daniel Smith
86 110 300TDI,16 Disco Sport
I will have to take a look at one of these sometime.
Old January 19th, 2012, 11:46 AM
John_Karlsson
John Karlsson
Looks like you're right up the road. Come on down.
John Karlsson
Hope Valley, RI
Old January 19th, 2012, 12:37 PM
87 D110 (Ruby)
it seems kind of big - esp when compared to the M416 - but is only rated at 3/4? Do you have the dimensions of it?
No worries - BELAY that...i found the ebay listing.
Do they need to be rewired to 12V?
Can that guy supply the pintle hitch - if not where did you get one?
Old January 19th, 2012, 12:43 PM
Any pictures of underneath? I'm curious about the construction. Is there a subframe under the platform or is the platform integral?
Originally Posted by pendy
I'm here for the D's
Old January 19th, 2012, 12:57 PM
John_Karlsson
John Karlsson
Here's some info about the various iterations of the basic trailer.
<http://olive-drab.com/idphoto/id_photos_m116_trailer.php>
As far as the voltage is concerned, if they are 24V (I haven't checked), I would guess that you would only have to change the bulbs.
As far as the pintle hitch is concerned, you would have to provide that yourself. If you have a Reese hitch, you could just get a pintle adapter. Otherwise, I got the hitch from a trailer shop. Of course, you could look on eBay. The bolt pattern seems to be standard.
------ Follow up post added January 19th, 2012 01:01 PM ------
This particular model has a dumping bed. The subframe is a basic rectangle with five cross members (counting the front and rear ones).
John Karlsson
Hope Valley, RI
Old January 19th, 2012, 02:41 PM
slorocco
Dan Prasada-Rao
I understand completely. And $400 is not a bad price at all.
Old January 19th, 2012, 06:07 PM
John_Karlsson
John Karlsson
To put it in perspective, I had to pay more than twice that for a tank of oil today. The oil guy said he was going to start to carry a defibrillator in the truck.
John Karlsson
Hope Valley, RI
Old January 22nd, 2012, 09:37 PM
texrover's Avatar
texrover
Jason
Smile
Thanks great find
I've been looking for a trailer to build a dog rig and that might just fit the bill!!
Old January 23rd, 2012, 12:44 PM
edh
Ex mod 90
That is a great find, maybe my wife would approve one for our remodel. It doesn't look like it could carry full sheets of plywood or sheetrock flat between the wheelwells though. I just couldn't omit that little detail could I? I am close to you would you mind if I checked it out?
Old January 23rd, 2012, 09:18 PM
John_Karlsson
John Karlsson
I measured about 45.5" between the footwells, so you couldn't lay a sheet of plywood flat. You could build a couple of boxes to support front and rear. I didn't measure the height of the footwells, but maybe you could just use a couple of 8x8 beams or such. You're welcome to come and have a look.
John Karlsson
Hope Valley, RI
Old January 24th, 2012, 11:05 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
FYI
At auction right now about 10 of these trailers at www.govliquidation.com
M105A2 1.5ton Cargo Trailer, equipped with lunette ring for coupling to pintle hook, With Side Rails And cover
Close Time: 01/26/2012 05:00PM
sitting at
2105 15th St
Bldg. 4195
San Antonio, TX 78234
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old January 24th, 2012, 11:31 AM
John_Karlsson
John Karlsson
Originally Posted by roverman2010 View Post
FYI
sitting at
2105 15th St
Bldg. 4195
That's a much larger trailer. It's meant to be towed by a 2 1/2 ton truck.
There are some M116A2 trailers up for auction: <http://www.govliquidation.com/auction/endecaSearch?Ntt=m116a2&Ntk=Keyword&Ntx=mode+match all&N=0&Nty=1&Ns=P_Lot_Number|0&words=m116a2&cmd=k eyword>
John Karlsson
Hope Valley, RI
Old January 4th, 2013, 02:04 PM
Larry-M
Larry
How about M1102
I need to tow M1102 back about 35 miles. But I do not know if I need a title/tag. Also how to convert the lights, 24v-12v and rise pintle level using my GX470. Any idea? Thanks,
Old January 4th, 2013, 02:41 PM
psykokid
Jake
1997 Disco
Get a set of cheapo magnetic trailer lights and figure out a way to attach them since the M1102's are aluminium. Zip ties should work. For 35 mile's id just rock out with your bill of sale from the seller. In the chance you get pulled over you show the bill of sale to the cop and move on, same way if you just bought a car. You look at the spec sheet for the M1102 and it will show the height of the pintle off the ground. You can adjust your hitch with a plate or a drop/raise bar for the correct amount..
Old January 4th, 2013, 05:54 PM
Larry-M
Larry
Smile Thanks
Thank you for the answers.
I did look the height, around 29 inch from eye ring (specification) to the ground. But my car hitch is only 14 inch hight. I have searched market for pintle mount plate, one of them, only can be raised 12 inch height max. It is close but not even. I wonder if I can do some change or adjust on eye ring. Or some uneven level will not cause much issue at all.
Larry
Old January 4th, 2013, 08:09 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
I pull my 3/4 T trailer with my disco. The trailer has HMV wheels and tries on it an sits higher than my truck...trailer nose down a bit. Have pulled to SC, and to NJ. Don't even know its back there...unless of course you slow down....then THUMP! You will get use to that.
Here in VA, you can get a transport tag on line from DMV. Costs $5.00. Then your legally covered.
When I picked mine up, I used a set of trailer lamps, a couple of self tapping screws, and ran the wire over the bed to the trailer connector, with a couple of zip ties to keep the wires from flopping around.
Name:	trailer - Copy.jpg
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old January 4th, 2013, 08:20 PM
The Dro
Dro
1988 Ninety
I used that 3-Day temp tag. VA is awesome.
M101 - A3 Dump Trailer - $2000 (Salt Lake City) themaxx The Flea Market 5 March 19th, 2010 07:49 AM
Stolen Adventure Trailer!! trailerman Misc. Chit-Chat 14 July 11th, 2008 11:52 PM
7000lb Trailer Roadsiderob Defender Technical Discussions 18 January 20th, 2006 11:29 PM
Trailer Idea gtg067i Misc. Chit-Chat 1 April 6th, 2005 06:29 AM
Bush Trailer Zimbo76 For Sale - Parts 7 October 8th, 2004 12:01 PM
