Headman Headers from Summit Racing - Defender Source
Go Back   Defender Source > Classifieds > The Flea Market
Old February 12th, 2008, 09:15 PM
CDeWan
Clay DeWan
5.3L beastie
FYI Not sure if this the proper place but I just bought a set of Headman headers for the 3.9 on the 94 D 90. They were $170 for a set and really have a nice sound to them.
Old February 14th, 2008, 07:41 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
What part number were they? All I could ever find was ones for the 3.5L
Semper Fi!
Old February 14th, 2008, 08:24 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Did they line up with the Y pipe well? Any need to clearance the DS for the steering shaft?
Old February 14th, 2008, 11:19 AM
JBOD77
Jonathan
1995 D90 ST Beluga Black
Question
how can either of these products fit my 95 D90??
Headers??
This is where I'm supposed to write something witty and funny; or something.
Old February 14th, 2008, 03:15 PM
GYM's Avatar
GYM
Gary
97 SW
Jonathan:
You might check in to Janspeed headers. They are in the UK, but I think JohnC on this board can get them through Scorpion.
Old February 14th, 2008, 09:11 PM
JBOD77
Jonathan
Can't seem to find any pricing or ordering info on the site just pictures...hmmmm maybe I'll shoot them an email??
Old February 15th, 2008, 12:36 PM
CDeWan
Clay DeWan
5.3L beastie
Sorry guys for not getting back to you. I was floating around at Summits site and came across the headers. The applicated listed per talking with the sales rep said for the d90 or 110. I was looking to replace my cats and o2 sensors as they had not been done in over 250,000 on the vehicle. So I had a local shop install them and build a Y pipe with new cats. Did it make much difference, well I think that is arguable and I am no tech, I ended up about even betten doing the headers and Y pipe compared to buying new (that is not taking in to consideration just buying an NRP Y pipe as far as cost goes) My goal were to see if I can get a little more mpgs (which I know if futile to begin with or else why would I buy a 12mpg vehicle). If I drive it not too much on the gas I can get about 14 mpg.
Hope this helps.
Old February 15th, 2008, 02:17 PM
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Ya the ones from Janspeed are also made to fit the 3.5L engine, but match up with the 3.9L. I actually use the header gaskets for the hedman headers on my 94. I have a set of knock off headers that look just like the hedmans. With the hedmans you will need to weld in 02 bungs and dent one of the driver's side pipes to get the steering shaft to fit. Or you can buy and older non-collapsable steering shaft from a Disco and fit it instead
of denting the pipe.
Only problem with headers and this is with all headers, is that you need to watch the header bolts. They tend to loosen and with the amount of vibration our trucks give out and the aluminum block engine they loosen pretty quickly. You can get some lock washers for the bolts and that seems to help some.
Additionally if you are going to go this route you may think about getting them Jet Hot coated. I have had this done on my 90 headers and on my Corvette headers and it really does keep the engine compartment heat down.
B
Old February 18th, 2008, 04:21 AM
D90DRC
D Cantrell
1997 D90SW
Get the ARP headr bolts and safety wire them. Does anybody make headers for the 4.0 Gems?
Old August 27th, 2008, 01:22 AM
CDeWan
Clay DeWan
5.3L beastie
Are the exhuast ports that much different on the 4.0 GEMS?
ac, header
Who wants headers for their 90? RedRhinoProducts The Vendors Loft 15 September 2nd, 2005 11:15 AM
headers for '97 D90 mdmccallum Defender Technical Discussions 43 April 25th, 2005 10:23 AM
1997 D-90 British Racing Green SeanD-90 Misc. Chit-Chat 26 February 28th, 2005 10:33 AM
Summit Racing Cats JimC Defender Technical Discussions 5 June 2nd, 2004 11:36 AM
Walker Evans Racing Beadlocks available tbmcneill The Vendors Loft 0 May 22nd, 2004 10:02 PM
