Fully Built 1994 D90 #1112 on eBay for $75k - Defender Source
Go Back   Defender Source > Classifieds > The Flea Market
Old September 13th, 2013, 10:13 AM
Wow now THIS is an advertisement. Well laid out, with tons of details, showing how much has gone into the build, and helping to justify the price. Opening bids start at $50k, or a Buy it Now at $75k. Its plaque number 1112 VIN SALDV2280RA941384 which was an Alpine White Soft Top, now converted to a 300 tdi SW. Odometer Rollback isssue on AutoCheck make it difficult to know the true mileage on the truck. Galvanized chassis and tons of other stuff like upgraded A/C system, etc. though.
http://cgi.ebay.com/ebaymotors/1994-...orcev4exp=true
sailboatgrant ( Feedback Score Of 12)
Item Location:Norwalk, Connecticut, United States
Time left:6d 09h (Sep 19, 201316:35:28 PDT)
Bid history:0 bids
Odometer Check:
Minor issue
1994 Land Rover Defender 90, 300Tdi galvanized frame off restomod
Up for auction is a one of a kind Land Rover Defender 90. This vehicle has been through a total frame off restoration with no expense spared. Vehicle was swapped to a factory new, NOT refurbished 300TDi engine with the correct factory brand new R380 transmission and the correct factory brand new LT230 Transfer case. The internal gears were swapped for the gas ratio to reduce engine RPM’s and increase cruising range. Typical MPG’s are in the mid 20’s. In addition to the 300TDi swap, the correct Euro engine and chassis harness were used as well as the gauge cluster. The harness was completely reworked with no expense spared to protect it. Raychem DR-25 was used through-out as well as Raychem splitter boots, weather-proof Deutsch connectors and adhesive lined heat shrink making the harness and connectors impervious to water. A factory supplied wiring diagram still remains correct as no wiring color codes were altered. Deutsch connectors were placed in lieu of the factory connectors so that the engine or the bulkhead could be removed without completely removing the entire harness. The same was applied to the fenders. Connectors were added underneath the fenders, on top of the powder-coated galvanized fender liners to aid in removal. Waterproofing did not stop there as weather-stripping and sealing were used on every panel upon reassembly, batter cables from the dual Optima batteries (one “red top” for starting and one “yellow top” for the winch) are enclosed in waterproof bulkhead connectors, custom panels for the galvanized bulkhead, dynamat on every panel and floorboard and stainless steel fasteners used through-out making this probably the driest and quietest D90 on the roads today.
The 300TDi was treated to a few improvements as well including an large Allard intercooler and fiberglass nose piece. Oiling for the diesel is aided by an electronically controlled Accu-Sump system which stores oil under pressure in the event that extreme drivetrain angles cause the pickup to loose it’s prime, the accu-sump will release the oil keeping pressure high. A separate benefit to this system comes in the way that it was installed. When the key is first turned to the on position and the glowplugs are heating, the accu-sump releases the stored pressure into the oil cooler lines priming the entire system and bringing oil to the head. The engine will never start dry and engine longevity is increased. Only Amsoil and Amsoil filters were used throughout this vehicles short life. Feeding the diesel fresh air is a custom snorkel mounted on the drivers side and plumbed directly into the air filter. This is a custom built one-off unit like so much else on this one of a kind Defender. Exhaust is handled by a stainless steel magnaflow muffler and custom stainless steel piping. Engine vitals are monitored through gauges mounted in the modified Iron Goat center console including oil pressure and temperature, boost pressure and EGT’s. A very accurate aftermarket water temp gauge was used to replace the factory one in the dash. All hoses are kept in place with superior stainless steel t-bolt clamps
An Auxiliary Electrical system was added to keep excessive loads off the factory components. This included adding a totally separate fuse block and relays along with battery cut off switches. This Aux system was added to provide power for the 3 Hella Black out lights, the factory headlights were re-wired through this system to increase amperage to the higher output bulbs. A rear wiper was added along with an ARB compressor mounted to the Brake Booster and hidden away. Air lines were routed underneath the rig and mounted to the frame on both sides. All controlled via the correct switch on the Iron Goat console which also houses an Alpine head unit with IPod USB interface. A new wiper motor replaced the old unit and new SIL blades as well. This Aux system also provides power for the 1500W inverter tucked neatly underneath the custom built center console which also houses an Alpine PDX-5 which powers a pair of 8” Vibe woofers in their own separate custom enclosures, Alpine 6.5” components in the doors, tweeters in the ceiling and a pair of Alpine 5.25” Co-Ax speakers in custom aluminum pods mounted up in the rear top corners. Also mounted on these pods are a pair of LED lights wired into the factory door light system to provide light in the rear. A separate toggle switch in the rear door allows the occupant to illuminate the interior of the rig without opening a door. A high wattage back-up light was added to the rear of the vehicle which will illuminate when the parking lights are active and the transmission is in reverse. There is also an override switch mounted in the Iron Goat console as well as the custom rear door panel to illuminate surroundings while camping.
An aux cigarette adapter was added to the goat as well as Garmin GPS connector and Lo-Jack. A separate mounted MAG-light was wired for constant charge when the vehicle is on and is wired for an Engle Fridge (which is not included). A detachable Cobra CB was added with an antenna mounted in the rear. An Anderson power pole dual connector was mounted underneath the hood so that the vehicle could be jumped, or the operator could jump a vehicle without removing the seat and taking a pair of clamps to the batteries in an enclosed space. A custom pair of cables for this connector are supplied. A solar panel with quick disconnect mounted under the hood was installed and wired to a charging system to keep both batteries topped off. The radio and the interior lights were wired separate of the battery shutoff switches so the memory is retained and the interior lights will illuminate whenever the door is opened. The entire interior lighting circuit was redesigned and relays added to provide the brightest and most reliable power source for the interior lights that were all changed out to LED’s.
The factory suspension was upgraded to a Scorpion Racing Evolution suspension kit which includes new trailing arms, spring retainers, new stainless steel brake lines, extended bump stops with Old Man Emu shocks and springs. Considerable time was spent measuring and weighing the rig to select the correct springs to give her a completely level and comfortable ride without sacrificing off-road flexibility. A factory rear sway bar was added back to reduce unwanted rolling giving the rig very nice on-road manners. An upgraded steering stabilizer was added along with a factory brand new steering box and outer tie rods. The front steering swivel pins and bearings were recently replaced along with brand new factory brake pads less than 3k miles ago. Tom Woods double cardon front driveshaft. Rear driveshaft has new Land Rover genuine u-joints. New HD Drag links from Rover Tracks. Galvanized Atlantic British front and rear diff protectors. The rig rolls on 33x12.5x15 mounted on black 15x7 Rock Crusher steel wheels. Proper backspacing allows the steering wheel to be turned lock to lock without the wheels contacting anything.
The rig is painted Alpine White and surrounded by a new Safety Devices full external roll cage with Safety Devices ladder. Shcrockworks deluxe full size tire carrier with Jerry can holder and Hi-Lift Jack holder. Full size spare with a cover and storage for filthy towing gear. Both the Hi-Lift jack and jerry cans come with the rig. Mounted up top is a low profile custom roof rack with a separately available pop up tent. Nothing but stainless steel fasteners used on the outside. The front bumper is a custom built unit made out of .185” and .25” steel that was powder-coated. Electrical wiring all routed inside the tubing. The custom bumper also houses a Warn M8000 winch. The relay block was relocated underneath the fender and the control connector mounted on the fiberglass nose piece. Safari Guard rock rails with hi-lift jack mounts. European rear taillights with brush guards. Hood pins were also added in lieu of the factory latch and black diamond plate wing top protectors were added to the fenders and the hood.
The interior was given a full dynamat treatment and the exterior windows sealed and reinforced to prevent rattles. There is a LaSalle fiberglass headliner eliminating worries about sagging and is water friendly. There is a sunroof. Custom leather steering wheel wrap. Badger seat covers to protect the factory seats mounted on custom rails to aid taller drivers. Custom panels mounted to the doors for the speakers. The storage boxes were dynamated and hinged to make life a little easier. The rear bench seat was removed and a custom deck was built that houses a pair of storage boxes and one storage area accessible with the rear door open. The entire unit can be removed and the bench seat reinstalled with 4 bolts. Exterior friendly yet still comfortable carpet was used. Black headed stainless steel fasteners were used throughout the interior.
The vehicle was stored in doors.
As you can clearly see, no amount of money, blood, sweat, tears or time was spared to create this one of a kind rig. I’m certain there are many many little details that were forgotten. Questions are always welcomed as well as reasonably requested additional photos in addition to the link to photobucket (coming soon) containing many more photos. We kindly ask that only those buyers who are very serious about purchasing this rig contact us @ Clean94Defender@hotmail.com
Auto Check:
1 Problem(s) Reported:
Mileage Date Reported
28 09/08/1994
87,000 11/07/1995
26,000 10/08/1996 not included in rollback calculation
42,000 08/05/1997 not included in rollback calculation
92,592 04/25/2002
7,228 11/16/2007 Possible Odometer Rollback/Rollover
Event dateLocationOdometer readingData SourceDetails09/08/1994 FL 28
Motor Vehicle Dept. ODOMETER READING FROM DMV 09/14/1994 MIAMI, FL
Motor Vehicle Dept. TITLE (Title #:0067423439) 11/07/1995 MIAMI, FL
Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 11/07/1995 FL 87,000
State Agency PASSED EMISSION INSPECTION 10/08/1996 FL 26,000
State Agency PASSED EMISSION INSPECTION 10/15/1996 MIAMI, FL
Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 08/05/1997 FL 42,000
State Agency PASSED EMISSION INSPECTION 08/15/1997 MIAMI, FL
Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 08/24/1998 MIAMI, FL
Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 09/24/1999 MIAMI, FL
Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 07/12/2001 MIAMI, FL
Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 04/25/2002 MIAMI, FL 92,592
DUPLICATE TITLE 06/03/2002 DENVER, CO
Motor Vehicle Dept. TITLE (Title #:01B223259) 06/03/2002 DENVER, CO
Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 06/03/2002 CO
Motor Vehicle Dept. PASSED EMISSION INSPECTION 12/29/2005 BEAUMONT, TX
Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 01/13/2006 BEAUMONT, TX
Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 01/31/2006 BEAUMONT, TX
Motor Vehicle Dept. TITLE (Title #:12330638735130723) (Lien Reported)
EXCLUDED/EXEMPT 12/15/2006 BEAUMONT, TX
Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 11/16/2007 NORWALK, CT 7,228
Motor Vehicle Dept. TITLE (Title #:030862079) 11/16/2007 NORWALK, CT
Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 10/05/2009 NORWALK, CT
Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 06/28/2012 NORWALK, CT
ID:	79740   Click image for larger version
ID:	79742   Click image for larger version
ID:	79744   Click image for larger version
ID:	79746   Click image for larger version
ID:	79748   Click image for larger version
ID:	79750   Click image for larger version
ID:	79752   Click image for larger version
ID:	79754   Click image for larger version
ID:	79756   Click image for larger version
Name:	SALDV2280RA941384 9-9-1.jpg
ID:	79758   Click image for larger version
Name:	SALDV2280RA941384 9-9-2.jpg
Name:	SALDV2280RA941384 9-9-3.jpg
ID:	79760   Click image for larger version
Name:	SALDV2280RA941384 9-9-4.jpg
Name:	SALDV2280RA941384 9-9-5.jpg
ID:	79762   Click image for larger version
Name:	SALDV2280RA941384 9-9-6.jpg
Old September 13th, 2013, 10:19 AM
it's had a soul-ectomy.
Old September 13th, 2013, 10:36 AM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
And then there is this one a couple adds down.
Old September 13th, 2013, 10:46 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Sweet lord.. do want.
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
I sent a message to the seller but he hasn't responded. Had a couple questions on who did the work on his rig. He was obsessed with the wiring work done to it. Over the top but I'd do it if I did a complete restoration one day. I'm sure he had his reasons looking at the background Picts near the water.
------ Follow up post added September 13th, 2013 10:48 AM ------
Oh yeah, if I win the lottery I'd click that buy it now button... :-)
Old September 13th, 2013, 10:49 AM
Haha. I wonder how many of us have sent him that question already.
Old September 13th, 2013, 11:50 AM
Been drooling over this all morning....
Old September 13th, 2013, 12:49 PM
KKilo23's Avatar
KKilo23
Kenny
If you don't mind post when you find out... hate to bother the guy even more.. but looks like a very clean build.
Old September 13th, 2013, 01:28 PM
It might look pretty but seeing the winch is connected to the side post of the battery I am immediately leery.
Originally Posted by pendy
I'm here for the D's
Old September 13th, 2013, 01:31 PM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
Sure will
Looking at the AutoCheck, noticed it was once in Beaumont TX. One of the members here is from there (lrnasd90). I'd bet he owned it at one time. Trying to be sluethy like Josh
Old September 13th, 2013, 01:48 PM
Sure will
Good eye there, Gery. When I was looking at the eBay ad I thought for sure I had seen that combo of options on an avatar here but couldn't think of whose it was. It looks like lrnasd90 has since changed his avatar (which used to be this truck going over a log in a yard or something) and his signature (which used to include all of the Defenders he's sold over the years). lrnasd90 sold this in 2007 to the guy in CT - it looks like somewhere around $50k back then.
http://www.defendersource.com/forum/...t=12027&page=2
Old September 13th, 2013, 01:51 PM
Well, not to be picky, but there are a lot of open positive hot connections in that battery compartment. All one need do is have a tool ground between one of those posts and the Dynamat and you'll get a wakey-uppey. And one really should have the batteries under some sort of hold down.
Old January 8th, 2014, 06:58 AM
snowpup's Avatar
snowpup
Jeff Snow
1997 D90
did anyone figure out who built this truck, specifically the bumper? looks like and ECR ROX or Safari Gard with the outboard brush guards lowered.
Old January 8th, 2014, 08:01 AM
Not ECR. That's old SafariGard with custom brush guards.
Old January 8th, 2014, 09:54 AM
lrnasd90's Avatar
lrnasd90
J. Landers
1983 110 LHD Galvanized Everything
The truck originally came from Chris Cox (member from way back). I bought it from him in a thousand pieces and built it. Then I sold it to Grant Rawding and he "refined" it. Very nice truck for sure.
And the bumper is a Safari Gard bumper that had the brush bar chopped.
93 NAS D110 #137 Sold
1-94 NAS D90 #702 Sold
2-94 NAS D90s (#1112, #1586)tdi Sold
95 NAS D90 #262 Sold
1-97 NAS D90 #642 Sold
2-97 NAS D90s LE (#82,#222)Sold
110 Crew Cab Td5 Sold
Hybrid Series 3 Sold
3-D1 Sold
1- D2 Sold
4- RRC Sold
83 110 5dr Diesel (current)
97 Disco XD tdi (current)
I can quit at any time I am not an addict!!
Old January 8th, 2014, 02:54 PM
snowpup's Avatar
snowpup
Jeff Snow
1997 D90
thanks!
1994, 90, d90, ebay
1994 Beluga Black on EBay Brewie212 For Sale - Vehicles 28 April 4th, 2013 01:05 PM
1994 Land Rover D90 Soft Top Green JAD For Sale - Vehicles 15 September 22nd, 2008 11:22 PM
Help - 1994 D90 Purchase Questions - NC uzj100 Defender Technical Discussions 6 November 1st, 2005 01:31 PM
95 d90 ebay ron Misc. Chit-Chat 0 March 25th, 2004 01:01 PM
