Feeler complete 200tdi drivetrain - Defender Source
Go Back   Defender Source > Classifieds > The Flea Market
Old January 15th, 2014, 12:28 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
I am undertaking a new project so out with the Diesel and in with something cooler. I have a complete bolt in 200tdi drivetrain, with Lt77 and LT230. I will be including engine mounts, radiator, inter cooler, trans mounts, fuel separator turbo hoses/lined, air box and down tube for the exhaust. Pretty much everything needed to drop right in. It is currently in the vehicle right now so if you want to see it run I can shoot a video. Pm me questions and offers.
Old January 15th, 2014, 12:59 PM
The Dro
Dro
1988 Ninety
Contact Jason
Old January 15th, 2014, 01:27 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
pm sent
Old January 15th, 2014, 01:47 PM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
Damn you are killing me Brian! Wish this were mine... GLWS!
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old January 15th, 2014, 02:17 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
couldn't be better timing let's do it!!
Old January 15th, 2014, 02:18 PM
ontheway's Avatar
ontheway
Dave
I agree. Unfortunately, I busted budget about $1K ago. No joy
Old January 15th, 2014, 02:24 PM
You are putting a gas turbine engine in your truck!?
Old January 15th, 2014, 02:46 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
All pm's responded, any interested parties your welcome to come by and drive before I pull it. If your local and want to help pull I'll work on price with you.
Old January 16th, 2014, 10:31 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
It is a disco 200tdi with 300 intake and exhaust manifolds so you can run LHD steering. This will fit to a 2.5 engine mounts but you will need the radiator, inter cooler and all the lines! Feel free to contact me, bc I will be pulling it probably in the next two weeks or so. This is a package deal that will work out great for someone.
Old January 16th, 2014, 11:18 AM
What is the gearbox then? Disco or Defender? With a "custom" setup like this, it would be best to explain as much as possible.
Old January 16th, 2014, 11:41 AM
rovertrader's Avatar
rovertrader
Dale
The above description in post #9 is the right way to modify the Disco unit to fit a LHD Defender. The gearbox is the same, but the linkage varies, and obviously he has the correct setup as it is a running/driving LHD conversion. The Disco/Defender linkages are vastly different due to the shifter locations.
A defender 200 has the turbo mounted in such a way to facilitate LHD and RHD without modification...
Old January 16th, 2014, 11:42 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
Disco 200tdi with 300 intake and exhaust for LHD
Lt77 trans
1.4 LT230
Inter cooler/radiator all hoses and lines are included along with mounts if needed. Will include air box, radiator reservoir, you get everything needed to do a direct bolt in. No nickel and diming for all the parts you need to finish the build. This WILL come with everything!
Old January 17th, 2014, 01:53 PM
sounds nice and smooth, but boy does it stink
Old February 19th, 2014, 09:04 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
So I'm willing to separate now, asking $4500 for motor and a grand for the LT77/lt230 1.4. I also will have everything to with it extra ie radiator inter cooler and hoses/clutch still in the truck willing to take video or come test drive it before I pull!
200tdi feeler bossman429 Wanted 0 September 12th, 2011 09:12 PM
Complete 200tdi, hoses, cooling etc.. JPBrown Wanted 5 February 21st, 2010 11:46 AM
Frame Feeler 200tdi tomaco1 Wanted 0 April 22nd, 2009 09:23 AM
200tdi, lt77,lt230 complete conversion setup Uncle Douglas For Sale - Parts 4 July 26th, 2008 01:15 PM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
» Defender Registry
DRAB
speedpin
CT 25
CamelTM
Add your Defender
