Craigslist Finds - Page 7 - Defender Source
Go Back   Defender Source > Classifieds > The Flea Market
Old August 10th, 2015, 12:03 PM
Oxland
Salles
none at this moment
Originally Posted by rijosho View Post
Looks like a truck "built" by the company formerly known as landroversuk.co.uk (now known as Arkonik) who do not have the best reputation.
landroversuk.co.uk 's got bad reputation?
that's not what I've read !!
a friend of mine is about buying one of their 110!
Old August 10th, 2015, 12:06 PM
What have you read? Their eBay ads? Lots of info here if you search around...
I'll get you started though.
https://www.google.com/webhp?sourcei...e.com&safe=off
they may look "nice" for a little bit, but even the paint begins to bubble rather quickly because the proper prep work wasn't done beforehand.
and a quote to wet your appetite
Originally Posted by the rover shop View Post
I have had the "pleasure" of seeing 6 of their polished turds... But thank you, I have made good money from deturding them... I think we are yet to have one that has had a decent engine in it.. They are polished turds...new door catches are failing left right and centre, doors flying open because of shitpart latches, fires in wiring harnesses, shagged trans and transfer boxes, very poor quality bubbling lifting new paint, new engines installed...(13 years ago).. Rains more water inside than outside, damaged new paint covered with brushed on house paint, engines that consume more oil than gas.. Overheating issues.. Rust stains running down brand new paint..new headliners falling down, haphazard and spotty sound insulation installation..but they look pretty pulling into my shop on a flatbed..
------ Follow up post added February 19th, 2015 05:24 PM ------
And if anyone needs pics or videos I will be happy to back it up..
Old August 10th, 2015, 12:24 PM
R3D R0V3R's Avatar
R3D R0V3R
Joseph
'97 NAS 90
Josh
Your hyperlink isn't working for some reason. Might need to correct it.
Joe
Joe
In search of the next adventure!
____________________
1997 NAS D90
1957 LR Series 1 SW (107)
1995 RRC
1993 RRC
Ex-2003 Disco II SE7
Ex-2001 P38
Old August 10th, 2015, 12:29 PM
Originally Posted by R3D R0V3R View Post
Josh
Joe
probably because you're not using Chrome. Basically I just googled (in quotes) ["landroversuk.co.uk" and site:www.defendersource.com]
Old August 10th, 2015, 12:51 PM
Oxland
Salles
none at this moment
well!!
thanks!
Old August 10th, 2015, 12:59 PM
NADA
run away.... VERY fast indeed....
Old August 10th, 2015, 01:15 PM
Oxland
Salles
none at this moment
all that my friend told me about them!
I want a 110,but those are too expensive for me anyway!
Old August 10th, 2015, 01:45 PM
landroversuk.co.uk 's got bad reputation? that's not what I've read !! a friend of mine is about buying one of their 110!
About to buy is as close as you'll get.
Old August 10th, 2015, 08:17 PM
mmdcomm
Matt
1985 Ex MoD 110
Hi all - thoughts on this one? Takes a pretty (exterior) picture, but no pics of her potential problem areas... Or even the interior. I emailed asking for more pics but thought I'd see if anyone here had any thoughts too. Thanks!
1988 Land Rover Defender 110 Stationwagon 3.5 V8
ETA: It's probably obvious that I'm not the owner, but just to be clear. Also wanted to add at least one pic so it's here when the link dies.
Name:	rover 081015.jpg
Old August 10th, 2015, 09:25 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
LAND ROVER 110 DEFENDER
Already in NY...not mine! only 77K miles....$19K
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old August 10th, 2015, 09:32 PM
Originally Posted by icnsltmfg View Post
LAND ROVER 110 DEFENDER Already in NY...not mine! only 77K miles....$19K
$19k for a LHD with only 77k miles????...
Old August 10th, 2015, 09:38 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
That was my thoughts...could be a good project...
Old August 10th, 2015, 09:42 PM
Chowbird's Avatar
Chowbird
Tim
'84 D90
Good miles. Ad has been posted for a month though. (Talking about the White 110 mmdcomm was looking at.)
Old August 10th, 2015, 09:59 PM
it's leaking oil from places I've never seen before.
Old August 10th, 2015, 10:22 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
I tried contacting the seller for 2 weeks with no replies
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old August 11th, 2015, 01:05 AM
Brian H
Brian Hach
none
Thanks for the input truly!
I will have to ask tomorrow about any association. The add says AEON exotics is the company.
Yes the doors have been repaired and some other items have been repaired and then the paint has been applied along with many bolts and parts of the exhaust pipe, hose clamps, etc. I did see bubbling under the paint on the exterior of parts of the doors and it is freshly painted. There are some rivets that look new behind the rear doors on the exterior panels and I didn't realize those are exposed normally?
The engine looks and runs with turbo and sounds smooth through all gears. How do I know the turbo is in good order? Oil pan has not a drop of oil on it and the owner does do car repairs but it seems different than the main case. It is a 19J.
I am a bit concerned as the speedometer was not turning though. Is this a simple connection that has come apart and easy to fix or would it be something that would have to be taken of intentionally? So the engine has 100K but the truck is not technically recording the miles it is doing. Lots to think about for sure. Another thing I noticed is the roof pop up sun panel has been caulked so as not to leak. Is this common?
Tires look good (General brand) and the rims are newer discovery types with spacers. How can I know these are safe spacers and not crap and will roll off the axle someday? They are aluminum I believe. The rims are powder-coated too and look good.
Cosmetically, the rig looks nice and is pretty clean. The frame looks to have a heck of a lot LESS rust than some I have seen and very few areas that seem to have issues even though it has been coated within a year. Let me say that I have seen a couple that were for sale and the owner's have said minor or surface rust and I can see entire layers peeling off or actual disintegration in many areas. There are some other spots like the rear door frame (minor) and around the bumper connects. All bolts on rear door hinges are replaced too. Rubber has been replace around doors and windows and seals look replaced. Interior looks good and would only need some clean up. Headliner and carpets are redone too. Majority of work was done in England through owners connection and then brought over for other repairs I guess less than a year ago.
Seems to have put some money into the repairs for sure but as I believe Josh said I would rather have a mechanically solid rig than a sexy beast!
So that is the question I face. To mechanically evaluate a 25 year old rig to become my DD........Drop a few bucks on trust. Would love to learn from anyone that has failed so I don't have to travel that road.
Old August 11th, 2015, 02:59 AM
Found a Facebook page for a company matching that description started 13 months ago. Couldn't find a corporation with that name at Secretary of State's office.
Someone saying it's their operation did register here. http://www.defendersource.com/forum/...0-a-57530.html
Old August 11th, 2015, 07:50 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by mmdcomm View Post
Hi all - thoughts on this one? Takes a pretty (exterior) picture, but no pics of her potential problem areas... Or even the interior. I emailed asking for more pics but thought I'd see if anyone here had any thoughts too. Thanks! 1988 Land Rover Defender 110 Stationwagon 3.5 V8 ETA: It's probably obvious that I'm not the owner, but just to be clear. Also wanted to add at least one pic so it's here when the link dies.
3.5v8 with a timing belt is interesting.
Old August 12th, 2015, 11:11 AM
MM3846's Avatar
MM3846
95 D1
Land Rover Defender..
1980 Stage 1 3.5 with LPG in NY.. but maybe Florida? $$11k.
Old August 12th, 2015, 05:36 PM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
Originally Posted by MM3846 View Post
Land Rover Defender.. 1980 Stage 1 3.5 with LPG in NY.. but maybe Florida? $$11k.
That truck has really shiny paint.
I can not tell about the springs. The photos do not show up well on my phone.
The steering wheel could be defender - the grill is definitely defender. The claimed age is Stage One S3 109. The windshield says Series. Probably a typical bitzer.
$11k may not be bad if the motor and frame are good enough.
Firemanshort
1980 Stage One 109
Sterling, VA
DC/NoVa Craigslist finds... o2batsea For Sale - Vehicles 16 June 23rd, 2016 02:17 PM
Some sweet CL finds themaxx Misc. Chit-Chat 4 September 19th, 2007 04:19 PM
1994 Rear Bench Seat For Sale•••••••MAKE OFFER wife no longer finds proposal to turn JAD For Sale - Parts 3 February 13th, 2007 05:05 PM
D90 finds death in Val Borbera (Jan outing) Cube II Trips, Trails and Events 4 February 22nd, 2006 02:59 AM
More aftermarket parts finds, crank scrapers and windage trays! Hans Misc. Chit-Chat 0 February 28th, 2005 03:49 PM
