complete Puma body - Defender Source
Go Back   Defender Source > Classifieds > The Flea Market
Old March 11th, 2012, 08:12 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
complete Puma body
Not mine(obviously) Ebay Uk find
http://www.ebay.co.uk/itm/Land-Rover...0#ht_500wt_951
Old March 12th, 2012, 08:46 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Wow, converting over the wiring harness would be interesting. Of course yo could get the Puma motor.....
Land Rover 110
Old March 12th, 2012, 12:22 PM
If you used a tdi you could basically ignore most of the harness.
Old March 12th, 2012, 04:56 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
I think the gauges in the instrument cluster index off the ECM and harness. You could obviously come up with a different instrument pack.
I also think the AC does the same so would need a work around for that too. Otherwise don't need much for the 300tdi/2.8PS.
Old March 12th, 2012, 08:50 PM
Capt Milks's Avatar
Capt Milks
Yea, the security system would be a bit tricky too as it ties into a lot. It wouldn't be too hard to just re-wire everything and use VDO gauges or something. You know they must be doing something like that in the UK.
Land Rover 110
Old March 12th, 2012, 08:51 PM
CDeWan
Clay DeWan
5.3L beastie
I thought this one was the one Stephen was looking at?
Old March 12th, 2012, 08:54 PM
Wouldn't surprise me - looks like there's some money to be made there if over here.
The puma engine is just a ford transit engine .. there are probably hundreds of them in breakers ... easiest thing to do with this is find a rolled late puma and body swap it.
body
series 109 complete body parts Capt Milks For Sale - Parts 14 December 15th, 2011 04:26 PM
NTO Defender 110 (PUMA) Rear Body FS SafariHP The Vendors Loft 5 September 23rd, 2011 08:17 AM
Rimmer Supercharger, complete. Also side fuel tank. Tom Fitzgerald For Sale - Parts 14 December 12th, 2005 08:09 PM
lifting the body (not plastic surgery :-) cbass Defender Technical Discussions 11 April 25th, 2005 12:14 PM
body work on aluminum mattdh Defender Technical Discussions 11 July 4th, 2004 02:47 PM
