CNC Cut Defeneder Engraving - Defender Source
Go Back   Defender Source > Classifieds > The Flea Market
Old April 4th, 2014, 11:26 PM
C391HAT's Avatar
C391HAT
Zach
86 110
A little while back I wrote a CNC program to cut an image of a Defender. At the time the CNC mills were being rebuilt but I was finally able use one this week to cut out a sample on some scrap plywood. This upcoming week I'm going to cut another one out of some oak and maybe some other materials, acrylic being the first that comes to mind. Would anybody be interested in one? All it would cost would be the cost of the material used and shipping if it needs it. I can cut a wide range of materials and am open to making some tweaks to the design if everyone can agree on something. Some things that we can play with are pockets, surface heights, cut depths and border cuts.
The picture is the test piece I cut. Because it was scrap plywood and had a slight bow to it some of the finer details got messed up but that won't happen with the final versions.
Big thanks to jjstahl3 for letting me use his design
Old April 5th, 2014, 12:21 AM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
I'd be interested in one, acrylic or aluminium would probably be cool.
Unknown Author
716-898-8153
Old April 5th, 2014, 03:26 AM
defender1844
Amit Likhyani
aluminum for me
Old April 7th, 2014, 10:25 PM
C391HAT's Avatar
C391HAT
Zach
86 110
Here's a test piece in clear acrylic. I'm going to try to get some aluminum for Thursday and cut it on that. If anyone wants acrylic, would they want clear,colored transparent or colored opaque?
Additionally how about doing something like this:
The second picture is just from pointing a single cheap laser at it. With a LED strip under it it should work really well. Could even use color changing LEDs too. I'll try to start working on a LED sign design/prototype.
Name:	engraving Acrylic.jpg
ID:	92615   Click image for larger version
Name:	engraving Acrylic Laser.jpg
Old April 8th, 2014, 08:58 PM
C391HAT's Avatar
C391HAT
Zach
86 110
Doing a rough estimate on the cost of all the parts, it looks like I can make the LED lit ones happen for between $30 to $40. That cost would include everything: engraved acrylic, base, dimmable remote controlled color changing LEDs, and the various electronics.
Just waiting on aluminum then I'll cut some on that. I should have a working prototype for the LED sign one by this weekend.
Old April 8th, 2014, 09:56 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
Looks pretty cool
Unknown Author
716-898-8153
Old April 8th, 2014, 10:03 PM
cbfritz_03
Carmen
none
Do you think you might ever put this on a t-shirt?
Old April 8th, 2014, 10:05 PM
genie90's Avatar
genie90
Jay Geaney
1994 D-90 ST #282
Sounds great- I'm in
Jay
Old April 8th, 2014, 10:18 PM
C391HAT's Avatar
C391HAT
Zach
86 110
The design that I based this on was created by jjstahl3 with the idea of using it as sticker. At the same time he was making some shirts too. You should check with him, he does some great stuff. See the thread here: http://www.defendersource.com/forum/...ad.php?t=49749
Old April 8th, 2014, 10:34 PM
cbfritz_03
Carmen
none
Oh I see and thanks. I'm liking the aluminum. How big are they going to be?
Old April 8th, 2014, 10:42 PM
C391HAT's Avatar
C391HAT
Zach
86 110
The aluminum stock is .25" think and 6" wide. The engraving itself is 5" wide by 4" high and then there will be some space around it. For the test piece I had it at half an inch but that can be changed easily and the engraving size could be scaled too(within limits)
Old April 8th, 2014, 10:54 PM
cbfritz_03
Carmen
none
Just asking cause I'm thinking either back lit sconce or candle holder or ...I could paint inside the grooves and tack weld it somewhere.
So yes I'm in for one of the aluminum
Old April 8th, 2014, 11:07 PM
C391HAT's Avatar
C391HAT
Zach
86 110
If you want some special tweaks made or additional things done to it just let me know, if it's feasible we can work something out.
The same goes for everybody
Old April 8th, 2014, 11:51 PM
C391HAT's Avatar
C391HAT
Zach
86 110
You mentioned using it for a candle holder, here's a quick idea I modeled up in a few minutes
Name:	holder w o candles.jpg
ID:	92722   Click image for larger version
Name:	holder w candles.jpg
Old April 9th, 2014, 08:01 AM
Prayer candles for the Rover gods? Great idea!
Old April 9th, 2014, 08:05 PM
C391HAT's Avatar
C391HAT
Zach
86 110
I think you're on to something.
Engine won't start? Electrical problems? Try the new Rover Shrine! Purchase now in the next 15 minutes and get your choice of 90wt, electrical smoke, or diesel fume scented incense absolutely free.
Old April 9th, 2014, 09:52 PM
cbfritz_03
Carmen
none
That is awesome! I like it
------ Follow up post added April 9th, 2014 08:56 PM ------
Yes.. I've been crunching numbers and starting a list of things I'm going to need for the re-build and prayer vigil and meditation are going to be necessary ..along with maybe a variant form of rain dance ..
Old April 12th, 2014, 07:36 PM
C391HAT's Avatar
C391HAT
Zach
86 110
Got the prototype for the LED one done. It looks really good and there's a ton of brightness settings, colors, and transitions. I attached some of the ones that photographed better but they look even better in person. Waiting on a few more electrical components for these but I should have a few finalized ones done by Friday.
Also finally got a hold of some aluminum, those will be cut and ready to be sent out on Tuesday. They'll be $10 + shipping for one cut on 1/4" thick aluminum. Carmen, do you want a plain aluminum one or do want to do something a little more custom?
ID:	92884   Click image for larger version
ID:	92886   Click image for larger version
Old April 12th, 2014, 07:38 PM
C391HAT's Avatar
C391HAT
Zach
86 110
Here's a video of the color transition
Old April 12th, 2014, 08:48 PM
cbfritz_03
Carmen
none
Omg ..that is neat! I'm getting one of those!! CooOL..I'd like one of the aluminum too please. I'm going to fill in that groove with a colored resin. I like very much and thank you
vin
anyone here have access to a CNC machine ? Uncle Douglas Defender Technical Discussions 13 August 31st, 2009 12:37 PM
Attaching a cut winch line Sam_rover Defender Technical Discussions 9 April 17th, 2007 05:00 PM
D110 Battery Cut-Off Switch mattarm Defender Technical Discussions 5 October 12th, 2006 05:02 PM
Cut to size aluminium chequer plates... JFD Defender Technical Discussions 2 June 3rd, 2006 04:29 PM
Total Cut Out, No Power gtg067i Defender Technical Discussions 8 May 22nd, 2006 02:18 PM
» Defender Registry
130
kellymoe
blondy
01CRF10
Add your Defender
