Clutch pedal towers - Defender Source
Go Back   Defender Source > Classifieds > The Flea Market
Old March 3rd, 2009, 12:37 PM
Clutch pedal towers
Ebay item # 260364069572
These are supposed to be a nice conversion if you have an older vehicle with the early style pedal. I have two on the shelf waiting for install. The over center spring is supposed to decrease pedal effort substantially. Haven't tried it yet but looking forward to easing the stress on my weak left knee. And a good price too from our friend down south.
Old March 3rd, 2009, 02:07 PM
You are supposed to run those with an additional spring. On my 95 the additional spring broke and while it still works, it does not release quickly as it should. (I ordered a new spring which has not arrived yet).
Old March 3rd, 2009, 02:40 PM
hmmm, I'll have to look at that. Where does the add'l spring go?
edit:
just looked at the auction again, if you mean the return spring that goes between the little eye on the pedal arm and a bracket or tab held down by one of the 6 mounting bolts, then yes, that part should be there. As it has been on every series land rover I have ever owned. The over center spring provides pedal assist which was my point, these are supposed to be easier to push down.
Old March 3rd, 2009, 04:42 PM
See this post:
http://www.defendersource.com/forum/...ead.php?t=5808
Old March 3rd, 2009, 05:50 PM
gotcha. so are you saying this spring is not normally fitted? it seems as though it should be since there is a tab for it on the pedal arm. anyway, thanks for the heads up dude.
PS no junky cardboard trim in my rig. all business here...bad enough we gots all that plastic.
Old March 3rd, 2009, 09:44 PM
We put these new style ones in Cabells 110 when we did the lhd conversion. Huge difference in pedal pressure. Get caught in traffic with my truck and your legs will look like Hershel Walkers by the time you reach your destination.
Old March 3rd, 2009, 10:32 PM
See this is what I dislike about the new style. I use the new style with the addition of the old style spring, otherwise the clutch does not release quick enough.
"so are you saying this spring is not normally fitted?"
some have them, some don't in my experience. Those without could have broken/fallen off though.
Old March 4th, 2009, 12:48 PM
cabell's Avatar
cabell
Cabell Crowther
Mine seems to be fine without an additional spring. Add the spring and you have stiff pedal again, correct?
Old March 4th, 2009, 02:08 PM
stiffer.
Old March 4th, 2009, 02:53 PM
doesn't make sense. my old style pedal has the return spring too. all the return spring does is take up the pedal free travel so that the weight of the pedal doesn't push the M/C pushrod against the M/C piston. In my experience, if the pedal is not returning to the end point of free travel without the aid of the upper return spring, then there is a problem in the hydraulic circuit.
stiffer.
Old March 4th, 2009, 03:28 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
My pedal is a series pedal I guess that isn't normal.
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old March 6th, 2009, 04:52 PM
I had to check and my brake and clutch both have a series style square pedal pad. and the clutch tower is the old series type not the nice fancy new one.
Old March 6th, 2009, 08:06 PM
yeah same as mine-early 110's used the same stuff as series 3's
Old March 7th, 2009, 08:23 PM
As did NAS 110s.
Old March 9th, 2009, 03:31 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
As did NAS 110s.
COOL So I have the same pedals as one of those 70K trucks my trucks value just went up
Eric Riston
Old April 2nd, 2009, 12:35 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Am I missing a spring here? Where exactly does the second spring go to? Does it attach to the eye that i circled in blue?
I've been having an issue with my clutch for a while now where the pedal will get "stuck" at the very bottom of it's travel. It only happens sometimes and it's difficult to pinpoint a cause, but when it would get stuck it seemed that the friction point on the clutch would be much lower too. Anyway, I bleed the system last night and the clutch seems better now. It has very nice even travel and the friction is solidly where it is supposed to be. However i am still having the pedal stick at the very bottom on occasion.
I tend to think this a spring issue since once the pedal gets past the stuck point it engages and swings like normal.
Ron, which spring was it that you recently bought?
Old April 2nd, 2009, 01:35 PM
Mike, that is why I recommend using the second spring.
Mine has a tab welded on the middle of the pedal shaft (maybe not the "middle" exactly, probably more like where you circled) and the spring runs up to a mount on the top of the six bolts where it goes.
I bought this spring. http://www.roversdownsouth.com/series-brakes.htm
569701, which is the fat one on the top of the picture. (Due to be being an idiot, I have five spares which I will pass out at MAR or I can ship you one now).
Ron
Old April 2nd, 2009, 02:25 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Thanks for confirming that Ron. Where does your spring attach to on the top end? Is there a preexisting mount or did you fabricate something?
Old April 2nd, 2009, 02:30 PM
ON my 1994 I cut down the mount from a series truck (see linked thread), on my 1995 and my NAS 110 remains, there was a mount already there. It is hiding behind the trim so I am not sure what it looks like, but an oversized washed that is bent with a hole in it would likley work.
Ron
Old April 2nd, 2009, 02:49 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Well I'll be... i found the little mount sticking out from behind one of those bolts. I never noticed that before and I didn't realize how big this spring has to be. I'm gonna give RDS a call and get a spring in the mail asap. I just want to make sure this is going to do the trick so that if it doesn't work I've still got enough time to order new master/slave cylinders etc in time to get them in for the uwharrie safari.
May also check at lowes (or other hardware store) to see if they have somthing similar
clutch
is there a clutch pedal adjustment for 95 d 90? rickauf Defender Technical Discussions 6 May 21st, 2008 02:56 PM
Clutch Pedal Sticking whitelandy Defender Technical Discussions 8 October 8th, 2004 10:23 AM
Clutch Pedal Rubber Dfndr90 Defender Technical Discussions 9 September 2nd, 2004 12:00 AM
Sticky Clutch Pedal JimC Defender Technical Discussions 11 March 11th, 2004 01:44 PM
