Brand New Lincoln Electric 180 HD MIG Welder - Atlanta - $600 - Defender Source
Go Back   Defender Source > Classifieds > The Flea Market
Old June 8th, 2012, 10:18 AM
BRAND NEW IN BOX - Bought this from Lowe's 9/10 months ago to use on my Hybrid, been sitting in my basement. Willing to ship, at actual cost. I know I should keep it, but I sold the Hybrid, so it will probably sit for another year or more, before I will need to use it.
Lincoln Electric Pro Mig 180 Wire Feed Welder K2481-1 230V
Includes: Magnum 100L welding gun (K530-6), Six spare contact tips, Gas and gas-less nozzles, Work cable and work clamp, Adjustable gas regulator and hose (for argon & Ar-blend gases), .025-.030 and .035 smooth drive rolls, . 030-.045 knurled drive roll, .025-.035 and .045 wire guides, 2 lb. spool .025" Super Arc® L-56 wire, 1 lb. spool .035" Innershield® NR-211-MP self-shielded flux-cored wire, 8" spool spindle adapter, How to Use DVD, Work Clamp and 10 ft. (3.0 m) Cable, Handshield, Instruction Manual (IM891), Learn to Weld Manual (LTW1) No Hassle Tool-less Design - for wire spool mounting, wire drive service and polarity changes, Innovative contact tip, drive roll and nozzle storage - keeps all your consumables close at hand. It's a portable wire welder designed for use with industrial 230 volt input power, so you can weld on thicker material - up to 3/16" with MIG welding and 1/2" with gas-less flux-cored welding. Great arc starts make getting started easy. Wide voltage 'sweet spot' gives you a very forgiving arc, so setting controls is a snap. Wide 30-180 amp welding output range.
Precision full adjustment drive system reduces chance of wire tangling and crushing,
Brass-to-Brass gun connections for enhanced connectivity,
Large industrial closed-design drive motor for improved torque and trouble-free performance,
Spool Gun Ready
ID:	52664   Click image for larger version
Old June 8th, 2012, 11:37 AM
carlosz's Avatar
carlosz
Carlos
that is a very nice unit, I have two migs, one runs on 115 v the other on 230v silmilar to yours... the latter unit runs circles over the 115, able to mantain great welding bead pattern, excellent penetration just an overall great unit for medium projects, anything bigger than brackets and so forth and I break out the professional arch welder.
Old June 9th, 2012, 08:10 AM
winn442's Avatar
winn442
Winn Bearden
scott, call me
Winn Bearden
atlanta
Lincoln 225 AC Stick Welder For Sale (Non Rover) TDI Guy For Sale - Parts 13 May 30th, 2009 07:38 PM
I'm making a custom fiberglass electric fan shroud for D90, anyone interesed? jaherring Defender Technical Discussions 1 November 22nd, 2005 01:06 PM
Grand Prix of Atlanta gtg067i Misc. Chit-Chat 0 April 17th, 2005 11:57 PM
Did 1995 SW D90s come with an electric fan? arbik Defender Technical Discussions 8 March 1st, 2005 01:27 AM
Body Panels and Work- Atlanta gtg067i Defender Technical Discussions 1 February 14th, 2005 05:03 PM
