BMW Scan/Reset Tool - Peake - Defender Source
Go Back   Defender Source > Classifieds > The Flea Market
Old July 9th, 2015, 03:02 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
This is the one you want for your 87'- 02' (to 07' with optional adapter) BMW. Info here:
R5-FCX-3 Scan and Reset Tool for BMWs
Cheapest I could find is $140 shipped:
http://www.amazon.com/Peake-Research.../dp/B003N27636
$85/ OBO shipped.
Additional info from Turner Motorsports:
BMW owners should have a great interest in the R5 FCX-III tool. The BMW's Check-Engine light can mean any number of things. Sometimes it's alerting you to the real need for a repair, but very often it is merely indicating one of the many, simple (top off your coolant) type problems. Tool resets the Check Engine, Service and Oil Change indicator dashboard lights. Easy to use and includes a booklet containing the fault code chart and instructions for use.
Will not work on the following vehicles: E30 M3, E28 M5, E24 M6, E30 325e, 2000 750iL. This unit plugs into the round port under the hood on cars up to 2000. You can use this on 2001 and later cars with the AB03 Adapter. See below.
ID:	124640   Click image for larger version
ID:	124642   Click image for larger version
Old July 23rd, 2015, 01:56 PM
down_shift's Avatar
down_shift
Russell
$75 shipped.
Scan Gauge 2 97XD For Sale - Parts 4 July 18th, 2013 06:42 PM
Service Engine Light Reset? Help!! N1ck B Defender Technical Discussions 9 May 11th, 2011 06:43 PM
110 Service Engine Light Reset newfD90 Defender Technical Discussions 4 August 18th, 2008 11:12 AM
digital odometer reset Overlander Defender Technical Discussions 5 May 15th, 2007 10:03 AM
Is it true? Service engine light reset? thelandroverguy Defender Technical Discussions 18 April 16th, 2007 07:54 PM
