Aspect Solar EP-55. 55 Watt foldable Solar Panel - Defender Source
Go Back   Defender Source > Classifieds > The Flea Market
Old April 19th, 2016, 02:37 AM
ndamico
nick
1995 rrc
ASPECT Solar EP55 Portable - TBS Solar
I've had this for a couple years but only used a few times. it has about 50 hours of actual deployed time on it. it measures 15.4 x 21.3 x 2.0 in. and is 8.6 lbs. Folds up nicely, has an adjustable stand to adjust angle plus it has a cloth cover than separates the panels when they are folded. i started out with tiny 7w panels, then 14w, then 20w and then the 55 watt. once nice feature is it has a MPPT controller which is detachable (it wasn't originally but i added weatherpack connectors) in case you have a stand alone controller. if you don't you can use the MPPT one. last time i used it was death valley. given its size and power it is hard to beat. i am going with a bigger (35lb) solar setup now, although not near as portable.
i added a harness to connect it to standard battery tender jacks as well as a harness to charge via your vehicle's cigarette/12v accessory plug.
i paid $299. would like $215.
They have a newer version out now which is rated at 60w instead of 55w. its $400.
ID:	147617   Click image for larger version
ID:	147619   Click image for larger version
ID:	147621   Click image for larger version
ID:	147623   Click image for larger version
Old May 7th, 2016, 12:35 AM
ndamico
nick
1995 rrc
Sold
Nick KK6TBF
1995 RRC LWB. 3" RTE Lift/Bumpers, 7100SB Shocks, 255x85R16 Toyo MT's, Mantec Snorkel, Ashcroft Lockers/Axles/CV's/4.12 Gears, GBR Driveshafts & Thrust Bolts, LT230, QT Diff Guards, Voyager Rack, Winch, Sliders, Dual Batteries, ARB Twin Compressor, Kenwood D710G HAM Radio, Xantrex Inverter, Swing Away & Sliders.
2010 LR4
New Powerfilm 30 Watt Flexible Solar Panel & Charge Controller Dogpilot For Sale - Parts 3 January 30th, 2016 05:31 PM
1.2 watt dash warning light bulbs Chris Velardi Defender Technical Discussions 11 May 21st, 2014 08:32 PM
DIY Solar Panel building... rdavisinva Misc. Chit-Chat 11 October 17th, 2013 03:45 PM
2000 watt portable generator.. Like new.. the rover shop For Sale - Parts 20 March 10th, 2013 11:07 AM
Solar Power kellymoe Misc. Chit-Chat 9 March 11th, 2004 07:38 PM
