Air tanks - Defender Source
Go Back   Defender Source > Classifieds > The Flea Market
Old August 15th, 2015, 11:40 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Air tanks
Picked two dive tanks at the local garage sale, any good to somebody as an air tank for your rover. Last tested 1977 on one other n/k.
No good to me (I got compressor)
Would assome the valve would have to be removed for shipping?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old August 15th, 2015, 11:43 AM
roverman2010
1985 LR 90 200Tdi
Air tank
Added pictures
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old August 17th, 2015, 12:35 AM
Lots of those old aluminum scuba tanks are not easy to get re-certified. And I don't think you can fill them with CO2 because I think the CO2 valve doesn't fit the top. But I could be wrong about that.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old August 19th, 2015, 11:35 AM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
There maybe a way to make it work I don't know about but I looked into converting a still certified tank over to use a powertank 2nd stage regulator and you would have to re-tap the tank to screw in a CO2 first stage regulator. That didn't seem very cost effective to me and either way you still had to spend a boat load on the powertank 2nd stage.
The one with the blue old school BC would be cool just to hang on the wall.
Old August 19th, 2015, 01:14 PM
Plenty of cheap CO2 bottles on Craigslist from guys who got board brewing their own beer.
GLWTS sale of the scuba tanks.
Old August 19th, 2015, 01:34 PM
roverman2010
1985 LR 90 200Tdi
they where free to any takers (bar shipping), but I will turn them into yard art now, will make good wood chimes.
Or maybe weigh them in with all the freestyle wheels I got.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old August 19th, 2015, 01:47 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
they where free to any takers (bar shipping), but I will turn them into yard art now, will make good wood chimes. Or maybe weigh them in with all the freestyle wheels I got.
My comment wasn't meant to cast a shadow on your offering, just a commentary on how I had the same thought but nothing is ever as easy as it should be!
------ Follow up post added August 19th, 2015 01:49 PM ------
If you want, I just a plasma cutter and could cut a shark bite outline in the tank!
------ Follow up post added August 19th, 2015 01:53 PM ------
Originally Posted by javelinadave View Post
Plenty of cheap CO2 bottles on Craigslist from guys who got board brewing their own beer. GLWTS sale of the scuba tanks.
Sorry to get off the topic of really cool free vintage scuba tanks but do you know if the flow rate on a regular CO2 first stage regulator is the same as one of the power tanks? The guy I asked at the company didn't really answer my question and just went through the obligatory speech about how their tanks were better and safer than a steel tank.
Old August 19th, 2015, 02:05 PM
The regulator is what dictates the flow not the tank. I'm sure the PT version is better but for 99% of the PT users they are filling up tires and not running high CFM air tools.
Old August 19th, 2015, 02:10 PM
There is no first and second stage regulator. There is a valve, and then a regulator that is attached to the valve.
when you get your tank filled, you take off the regulator and the tank gets filled through the valve.
The valves offered by powertank are just regular Co2 valves near as I can tell. A good all-brass valve will cost you about 40 bucks most places which is about what PT charges.
The regulators offered by PT are touted as having a higher flow rate and pressure range than the typical regulators used for beverage service or other common applications, and claim to be more resistant to freezing up.
------ Follow up post added August 19th, 2015 02:14 PM ------
its really nice to have the high flow rate and pressure of the PT regulator. Fills tires fast, and makes more pressure than any 12v compressor.
Not sure why the PT people say an alu tank is safer than steel? Lighter, for sure! I like my Luxfer tanks. Just upgraded one of them to a 15lb.
Present:
1987 RRC- "Chewy 2"
Past:
Old August 19th, 2015, 02:55 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
Sorry it has been a long time since I took my scuba certification and I got my parts mixed up.
So the valve on a PT is the same as the valve on a regular CO2 tank? Meaning, if you put a PT regulator on a non-PT tank it would have the same flow rate as with a PT tank?
Old August 19th, 2015, 03:00 PM
Si Senor.
F&R ARB Air Lockers with 4.75 GBR R&P, Switches, Air Compressor, Air Line, Etc LRFlip For Sale - Parts 36 September 4th, 2014 12:35 AM
Series Military Fuel Tanks in CT jac04 For Sale - Parts 4 December 3rd, 2010 04:17 PM
Tire Inflation Systems - use my current scuba tanks?? advnirvana Defender Technical Discussions 2 September 10th, 2009 03:51 PM
Saddle tanks running foul of the toe panel S3 SW 109 airbornrover Defender Technical Discussions 1 June 6th, 2009 11:18 AM
Power Tanks and warn winch TDI Guy Misc. Chit-Chat 10 April 29th, 2005 12:57 AM
