Adventure Trailers Drawer Systems for Defenders - Defender Source
Go Back   Defender Source > Classifieds > The Flea Market
Old December 15th, 2008, 12:31 PM
97D90's Avatar
97D90
Andrew Walcker
1997 Defender 90 LE
[font='Arial','sans-serif']I was very excited when I learned that Mario at Adventure Trailers was branching out from making trailers and was introducing a product line of drawers. If anyone has had an opportunity to check out an AT or better yet, meet Mario, than you will understand my excitement. I was not disappointed as he is making the entire line of drawers out of a composite material that is much lighter than plywood.[/font][font='Arial','sans-serif'] The D-90 drawer will weigh about 48 lbs. [/font][font='Arial','sans-serif'] The first prototype drawer I saw had a Toyota FJ80 parked on top of it with minimal deflection of the material! Read and see more here; [/font][font='Arial','sans-serif'][font='Arial','sans-serif']http://www.adventuretrailers.com/drawer.html[/font][font='Arial','sans-serif'] along with pictures of a test fit in my 90 (pics near the bottom).[/font][/font]
[font='Arial','sans-serif']Mario is willing to do an initial run of at least 5 of these drawers for $565[/font][font='Arial','sans-serif'] a piece[/font][font='Arial','sans-serif'] if I can put this together (a substantial savings from the one off price of $780). At this point I'm looking for people that will be interested in this drawer. Mario will be taking deposits once we have 5 (4 more beside me) and will have them built and shipped out 4 weeks after the close of the deal. I'm thinking that we should keep this running thru December 31 so we can have our drawers in late January.[/font][font='Arial','sans-serif'] [/font]
Name:	A D90 closed copy 800.jpg
ID:	16885   Click image for larger version
Name:	A D90 open copy 800.jpg
Old December 15th, 2008, 04:14 PM
tommyd's Avatar
tommyd
Tom
LR3
I'm interested, but I need to measure the interior cargo area dimensions of my 110 to see if the 90 drawer will work.
Old December 15th, 2008, 05:55 PM
I am not interested right now, but I am curious about this choice of composite material. Is it waterproof? At least for a soft top, I can't imagine going with anything other than stainless or aluminum for durability in the weather. But even for a wagon, I am sure driving rain and a host of other scenarios would result in them getting wet inside and out.
Old December 17th, 2008, 11:28 AM
97D90's Avatar
97D90
Andrew Walcker
1997 Defender 90 LE
The composite material that the drawer and box are made from is a closed cell polyurethane composite structural product that is used in the marine industry. It does not absorb water, rot or react with any metals. In addition it is sprayed with a two-part polyurethane coating with texture, similar to Line "X". The sliders are treated steel and the ball bearings are stainless steel. All hardware is plated steel. The latch is a combination of a polymer similar to HDPE and stainless steel. As you can see the box is extremely resistant to weather of any sort, perhaps even more than steel or aluminum when you consider the non-reactivity that plagues metals. In addition, I believe that this material is more resiliant to impacts than metal and as a bonus it weighs considerably less.
Old December 17th, 2008, 11:31 AM
Good to know, thanks!
Old December 17th, 2008, 12:48 PM
JRW's Avatar
JRW
94 D90 ST #1247
How is the box intended to mount into a Defender? Perhaps use the default forward facing rear seat mounts in the ST? Also, what about locks? Could one easily mount a tuffy lock keyed to match the rest?
Old December 17th, 2008, 01:36 PM
97D90's Avatar
97D90
Andrew Walcker
1997 Defender 90 LE
There is no prescribed way to mount it. I agree with you, for a ST I would use the existing seat bolt holes and am not sure myself on the SW. The proper way would be to drill some holes either thru the floor vertically or thru the wheel wells horizontally. The latch comes with a lock on it.
Did you measure the back of your 110? I'm assuming that the dimensions are the same b/t the 90 and 110.
Old December 17th, 2008, 10:02 PM
tommyd's Avatar
tommyd
Tom
LR3
Not yet; it's in the shop right now, about a 3 hour drive away. I'll have to do it after the New Year.
I imagine the dimensions are the same, but I want to be sure after installing my new cargo barrier.
Old December 17th, 2008, 10:55 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
Can you provide dimensions?
Thanks!
John Karlsson
Hope Valley, RI
Old December 18th, 2008, 11:01 AM
97D90's Avatar
97D90
Andrew Walcker
1997 Defender 90 LE
Thanks!
Per Adeneture Trailer's website:
Outside Box 32" wide x 8.75" high x 36.0" deep
Inner Drawer 27.5" wide x 6.25" high x 33.5" deep
Old December 22nd, 2008, 11:49 AM
97D90's Avatar
97D90
Andrew Walcker
1997 Defender 90 LE
TTT for anyone else wanting to join in on this group buy.
Old December 22nd, 2008, 04:10 PM
rovertrader's Avatar
rovertrader
Dale
Andrew- Dale here- how have you been, well I hope. I am in for at least one, possibly a second for my Conquerer trailer. Do they all have to be said size ( I assume so, but hated not to ask)?
Also, the 110 tub is actually about 5" shorter ( less deep) than a 90, allowing for the seatbacks, but still plenty of room for a HiLift or ??? behind the drawer. Width and height are the same. What is the official order date, and when do you need funds? Dendy ( NashvilleRover) is also considering one, and if need be, we can post up on D-web to try to get a minimum order. Thanks.
Old December 23rd, 2008, 12:17 PM
97D90's Avatar
97D90
Andrew Walcker
1997 Defender 90 LE
Hey Dale, all is well and you are still my hero for having a rear heated window!
There is no hard date or timeline with the drawer order. Would be nice to get the first order in by the second week in January since I know we are all busy with the Holidays. AT is making a few different sizes (see their website) but the idea was to have one specific to the 90s and 110s since no one domestically fills that niche.
As far as the funds go I will point people directly to Mario at AT for payments. He has asked for 3-4 weeks once the orders are finalized to manufacturer and ship the drawers. Posting up on D-Web would be greatly appreciated. I'll also get this up on ExPo as a cross reference.
Old December 23rd, 2008, 03:31 PM
rovertrader
Dale
D-Web post made. ExPo is a great idea as well.
Old December 23rd, 2008, 04:47 PM
John_Karlsson
John Karlsson
I'll take one.
John Karlsson
Hope Valley, RI
Old December 26th, 2008, 01:05 AM
NashvilleRover's Avatar
NashvilleRover
Dendy Jarrett
2009 LR3- Well Built
Maybe this has been stated and I am just too full of Holiday food to read correctly, ... but does the discount offer extend ONLY to slide drawers specific to the rear 90 and 110 tub, ... or does it extend to any drawer they make or that someone would want to have them make?
Thanks in advance for clarifying.
Dendy
Old December 28th, 2008, 11:13 AM
97D90's Avatar
97D90
Andrew Walcker
1997 Defender 90 LE
Dendy
This would be for the drawer specific to the 90/110.
Going to be out of town and range until January 4 so will try and get this wrapped up when I return.
Old December 28th, 2008, 01:04 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
I'm in for one if the above dimensions are for the final product. (I have a custom seat arrangement so can't go over 36 inches depth.) I'm going to be off-line from Jan 3 to Jan 10th but please count me in.
DW
Old January 5th, 2009, 09:00 PM
97D90's Avatar
97D90
Andrew Walcker
1997 Defender 90 LE
Back in town from a wonderfull New Year's get-away in the desert! So far it looks like potentially there are five of us for an order.
1. 97D90 (Andrew)
2. John Karlsson
3. Rovertrader (Dale)
4. Doug Walker
5. Nashvillerover (Dendy) MAYBE?
TTT for anyone else wanting on the group buy. I think we give it another week so let's say Janyuary 12 will be the deadline. I'll talke to Mario and find out the details of how we should are to settle up with him.
Old January 5th, 2009, 09:16 PM
tommyd's Avatar
tommyd
Tom
LR3
I'm going to measure and I'll let you know before the 12th. Keep meaning to do it, but been busy.
Military Trailers, M101CDN Tom Fitzgerald For Sale - Vehicles 14 July 21st, 2010 01:33 PM
Custom storage drawer source pmd Defender Technical Discussions 21 December 16th, 2008 10:51 AM
Adventure Trailers updates their website trailerman The Vendors Loft 1 March 21st, 2007 09:48 PM
Fuel Can Holders from Adventure Trailers (AT) trailerman The Vendors Loft 5 August 31st, 2006 01:51 PM
New Chaser trailer from Adventure Trailers trailerman The Vendors Loft 2 April 20th, 2006 08:05 AM
» Defender Registry
TIT
SaltyDog
Defender 90
brud
Add your Defender
