$4, $3, $2, $1 Wholesaler Closeout Wipers at RockAuto.com - Defender Source
Go Back   Defender Source > Classifieds > The Flea Market
Old April 5th, 2013, 11:59 AM
RockAuto's Avatar
RockAuto
RockAuto, LLC
A competitor switched suppliers for their private label wiper line and created one of the best Wholesaler Closeout bargains for RockAuto customers ever! First-quality wiper blades and refills made by Trico, including the latest "beam-style" blades and specialty products like Winter and Teflon blades, are now available priced under $4.
Examples:
$1 or less for OE Metal Refills and Twin Rail Metal Refills
$2 or less for AeroVantage
$3 or less for Heavy Duty Blade, Winter Blade, Exact Fit, and Winter Teflon Blade
$4 or less for Teflon Blade, Classic Blade, Teflon Shield, Innovision, Contour BB, and Neoform
Some of these wipers made by Trico originally cost more than $20! It is the perfect time to replace the wipers on your vehicles or stock up on the wipers your customers will need if you're a professional mechanic. As with all Wholesaler Closeouts, quantities are limited so get them while you can! Find wipers for your vehicle under "Wiper & Washer" in the RockAuto catalog.
www.RockAuto.com
Need help?
Old April 5th, 2013, 01:05 PM
BEIS's Avatar
BEIS
RYAN BEIS
D110 Soft Top with full rollcage
Examples:
www.RockAuto.com
Which option is the best for defenders?
-Ryan
Old April 5th, 2013, 01:35 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
There is only one listed for the Defender, take your pick
Ordered two sets of each for my fleet
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old April 5th, 2013, 01:43 PM
RockAuto's Avatar
RockAuto
RockAuto, LLC
Wiper blades are very much a personal preference type of part. When there are a lot of options (there are quite as many options for the defender) we have the wiper blades broken up into groups (such as winter, traditional, improved traditional, beam, etc) so you can quickly narrow down the best option for your needs.
Thank you,
www.RockAuto.com
Need help?
Old April 5th, 2013, 02:27 PM
I'm not finding anything on your website for my 87 D-90.
Old April 5th, 2013, 02:29 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Edit
Semper Fi!
Old April 5th, 2013, 02:49 PM
BEIS's Avatar
BEIS
RYAN BEIS
Thank you,
www.RockAuto.com
Thanks, man. Was just seeing if anybody out there had better luck, or liked one blade in particular out of these options. I live where it rains ALOT, and was trying to get member input. Thanks!
-Ryan
Old April 5th, 2013, 03:28 PM
As stated above, the search on your site only brings up "BALKAMP Part # 7622137 13" StormVision Premium Metal Blade" as a choice under the Defender....
Old April 5th, 2013, 03:43 PM
BEIS's Avatar
BEIS
RYAN BEIS
You need to search (as always at Rock Auto and others to include AutoZone) for parts associated with pertinent import years such as '93 D110, '94 D90, '95 D90, and '97 D90. Our older trucks will match the new truck specs, if you have similar fittings, etc. installed.
Engine stuff is alot different, and you have to match up your engine size that of other older models (ie. Range Rovers with 3.5L V8's etc.) or other similar makes that use the same engine. Hope that helps.
-Ryan
RockAuto Wholesaler Closeout Feeds RockAuto The Flea Market 0 November 9th, 2012 10:05 AM
Rovers North Front Headlight Guards $180 Wolf Fabrication For Sale - Parts 2 November 2nd, 2011 08:41 PM
RockAuto.com Closeout Sale Weldon The Flea Market 1 December 9th, 2010 03:35 PM
Windscreen wipers TDI Guy Defender Technical Discussions 22 December 2nd, 2004 12:41 PM
Windshield wipers not functioning properly cdnpaul Defender Technical Discussions 1 November 10th, 2003 02:52 PM
