ZF Tools - Defender Source
Old August 12th, 2015, 04:20 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
ZF Tools
Ich hatte mal gern ein Problem ...
Dank Carusos Hilfe, konnten etliche Hilfsmittel gebaut werden, die bei der De- bzw. Montage hilfreich sind!
Der Getriebehalter für die Werkbank:
Original
Nachbau
Dichtgummi Zieher
Untersetzer
Ständer
wg. unterschiedlicher Ausgangswellenlängen musste hier nachgearbeitet werden
Gleiches gilt auch für die Handhabung der Ausgangswelle
Auszieher
Niederhalter und Setzdorn mit Hülse für Sprengringe
Einstelllehre
Hope you don't need a translation.
I'm done for today.
It was hot and humid.
Not my conditions for translations.
Old August 12th, 2015, 04:39 PM
Wow Arlo...you put anything I do to shame. Nice work!
Old August 12th, 2015, 05:14 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Thanks Ed!
Needed the tools to get a look inside my friend's automatic.
Fitted the second one several days ago. This one doesn't shift!
First one shifted well, but there was a noise like forgotten tools inside the box when the car is shuffeling the engin.
Issues are located here:
Any ideas how this could happen?
I will exchange the hydraulic steering boxes of the both of the two tomorrow.
Hope it will help.
Any other options?
Old August 14th, 2015, 06:34 AM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
That makes sence, Jeff!
Changed the steering block yesterday.
Now the ZF shifts smooth and perfect at the right time!
Btw. it's no fun to do this in a pit, with the parts in hands, oil leaking from where you have to screw or unsrew bolts.
Some pics:
To reach the last bolt of the oil pan the gearbox support has to be removed a little bit.
When unscrewing the bolts of the steering box a huge pan has to be right in place because about half of a gallon of oil wants to drop down!
It took about an hour when we could remove the block save and sound.
None of the circlipps was set at its groove perfect.
A little bit tricky to adjust the block to the right position betwenn kick-down cam and valve pin.
But all went well!
Needed a shower after this procedure.
Tools/Parts you take? Rod Hayward Misc. Chit-Chat 17 February 2nd, 2005 11:08 AM
Dealer Service Tools scrover The Vendors Loft 0 August 16th, 2004 04:12 PM
Ebay tools Mike Hippert Misc. Chit-Chat 7 July 31st, 2004 11:47 AM
Home Depot Sale on Power Tools loykd Misc. Chit-Chat 3 December 20th, 2003 01:12 PM
Recommended Tools mgrgpg Misc. Chit-Chat 7 December 3rd, 2003 01:12 PM
