You can never have enough gages - Defender Source
Old July 19th, 2008, 07:24 PM
LenB's Avatar
LenB
Len Bruffett
NAS '97 ST /SW-POE Config
During one of my trips to my metal supply house i nosed around through a box of vintage aircraft cockpit gages some one had brought in for recycling and found a 1942 aircarft airspeed indicator made for the US Army Air corp. It is a very simple device that works via air pressure differentials. I bought it, tested it to see if it worked, built a pitot tube (attached it to my ARB bumper) and ran flexible tubing up to the driverside of my truck. I just built a mounting bracket to hold the gage that is easily removed from the truck. It works pretty cool... and is pretty accurate as long as you have clean air in front of you. When you have a head wind you get higher airspeed readings than your actual ground speed - so you can determine head winds while traveling down the road. As you can tell it doen't take much to keep me amused.
ID:	14384   Click image for larger version
Old July 20th, 2008, 12:47 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Very nicely done, I also copied your LED license plate light right up and it worked great.
Cheers
Old July 22nd, 2008, 07:48 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I like the little s/s bracket that hold the thing, you should sell those... It will be helpfull fo hang stuff like a GPS or a handheld radio without drilling the dashboard.
Sorry, just saw on your website that you have that already . Will it work on a 2005 dashboard ?
- Charles Eames
Old July 22nd, 2008, 09:23 PM
LenB's Avatar
LenB
Len Bruffett
Hi Julien,
It likely will, send me a pic and measure the width of the plastic capping. I can make the clamping device any dimension you need.
Old July 24th, 2008, 12:10 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Originally Posted by LenB
Hi Julien,
Good, I will check it this week end and let you know.
- Charles Eames
Murph's D90? HeloBubba Smaller Projects 13 July 8th, 2009 04:37 PM
About to do a flex-a-lite.... got some questions Hans Defender Technical Discussions 15 July 29th, 2005 10:51 AM
