X Deflex Anti Roll Bar - Defender Source
Old February 24th, 2015, 04:05 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
My refresh has hit a road block...has anyone here installed a X Deflex Anti Roll Bar on a "NASD90".
The tank on a NAS is lower than an 110 and a pre-TD5 ROW 90. Need some help on this...
I know Wolf did his 110 but the 90 appears to be different...significantly.
Old February 24th, 2015, 04:06 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Damnit M, just lift it more! That'll get that pesky fuel tank out of the way
Old February 24th, 2015, 04:14 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
It's been done. You have two options: mount directly to the skid plate or fabricate spacers for the mounts.
Semper Fi!
Old February 24th, 2015, 04:22 PM
Bill Larson
Bill Larson
If I lift it more I'll need a step stool!!
Old February 24th, 2015, 04:40 PM
Bill Larson
Bill Larson
True, but whats the travel near the exhaust going to be like...I know it will work anything can be fabed out, just getting ALL available info!
Old February 24th, 2015, 05:00 PM
drdread's Avatar
drdread
AL
'94 NAS 90 SW
Bill did you source this stateside or from the UK?
This was on their site----
"Anti-Roll or Anti-Sway bars are fitted to almost all production vehicles to enhance handling, cornering & stability - in short, to improve safety.
However, anti-roll bars are designed to reduce articulation - which is the opposite of what most Land Rover owners want!
Production Land Rovers compromise by fitting a weak anti-roll bar which improves the handling a bit and doesn`t limit the off road capability too much. The standard bars only allow the rear axle to droop by 9" (230mm) - so has to be removed on vehicles with extended travel.
We have designed X-DeFlex to be unlockable (known as anti roll bar disconnects in Jeep circles) - so it does not have be a compromise. Locked it has four times the torsional stiffness of a standard bar, but unlocked it allows 16" (410mm) of unrestricted articulation, selectable at the turn of a switch.
X-DeFlex dramatically improves the on road handling allowing safer high speed cornering. If you have a `daily driver` with uprated suspension, an overland or camper conversion, an uprated or high performance engine, and want your vehicle to give you the maximum on AND off road - this is for you!
Use the diagram on the right to determine which thickness of spacers you need. "
1994 Silver DEFENDER 90 NAS SW
Old February 24th, 2015, 05:07 PM
Bill Larson
Bill Larson
UK, yes I got all of that...the concern is travel as it relates to the exhaust. spacers will have to be fabricated as the "normal" spacers won't cut it...
Old February 24th, 2015, 05:37 PM
Have you asked x-eng first? I'm quite sure they will help you and know what they are doing.
Old February 24th, 2015, 05:43 PM
the rover shop
shayne young
I have it on my camel 110.. Great system.. When I bought it they sent the extra bracket but I think that was supposed to be for if I installed an oversized tank.. As mentioned before I think it may come down to dabbing up the oversized mounting points onto the fuel tank cradle bash plate.. Put a heavy duty one on it and good to go..
Old February 24th, 2015, 06:56 PM
Bill Larson
Bill Larson
Not yet, sending an email tomorrow...just throwing it out to the board first.
Old February 24th, 2015, 08:50 PM
myoverlandrover's Avatar
myoverlandrover
josh
109
Love mine on the 110, email Simon direct simon.rafferty@x-eng.co.uk
Defender 110
Old February 24th, 2015, 10:05 PM
Bill Larson
Bill Larson
Yep thats the email I have! We'll see how it goes, I really want this to work, trying to take turns at posted speeds is daunting...(especially with Briggs driving).
Old February 25th, 2015, 06:01 AM
myoverlandrover
josh
109
this will do the trick, my 110 loaded with RTT and tons of gear stays flat on highway turns etc. Engaged it's 3x stiffer than factory.
Defender 110
Old February 25th, 2015, 08:33 AM
ruggedalaskaman's Avatar
ruggedalaskaman
Frank
1995 NAS D-90 #375
Looks like a great product!
Old February 25th, 2015, 03:11 PM
drdread's Avatar
drdread
AL
'94 NAS 90 SW
in case you haven't heard back from Simon, he posts on a few UK based sites, this for example seemed to suggest 60mm for ROW, not sure how NAS compares to it.
X Deflex - Defender Forum - LR4x4 - The Land Rover Forum
Old February 25th, 2015, 04:17 PM
Bill Larson
Bill Larson
I have been slammed today and haven't even had a chance to email him yet...hopefully tonight.
Old March 9th, 2015, 03:23 PM
drdread's Avatar
drdread
AL
'94 NAS 90 SW
Bill
Did you ever find out the correct spacer?
Would love to do this one day as well.
al
Old March 9th, 2015, 03:40 PM
Bill Larson
Bill Larson
One will just be made when it gets here...the concern is the exhaust clearance. It's going on soon...(I hope...:') )
Old October 8th, 2015, 09:55 AM
Crash303's Avatar
Crash303
Josh Harris
97/ D90 ST #1190
Hey Bill, How did this turn out for you? I'm interested in doing this upgrade with my 97 NAS. Just not sure which kit to go with. As for the fabrication spacers, that will be no problem. I just don't want to re-engineer it if someone else has already gone through it. Any help would be appreciated!
When the F*%# did we get Ice cream!!!
"They are, in factory original condition, noisy, they leak water in from the top and oil out from underneath, you can never demist the windows in winter, they handle like scaffolding towers, and use more fuel than Beijing." Richard Hammond
Old October 8th, 2015, 10:30 AM
Bill Larson
Bill Larson
it's all good...mods needed for the NAS90 call Roadside Rob for details....
flex, roll bar
WTB rear anti roll bar rover26c Wanted 1 September 11th, 2013 10:08 PM
Rear Anti-Roll Bar brackets EGP1661L Chip Wanted 3 April 12th, 2013 04:47 PM
Disco I rear springs, anti-roll bar Gardner For Sale - Parts 0 September 26th, 2011 03:16 PM
anti-roll bar bracket # EGP1661L wanted davidr Wanted 0 July 23rd, 2009 03:59 PM
Anti Roll Bar Joints TDI Guy For Sale - Parts 3 December 17th, 2004 07:05 PM
