WVO Conversion one step at a time. - Page 2 - Defender Source
Old December 28th, 2014, 07:22 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I will show pictures as the conversion progresses, but here are some general comments related to the posts:
There will be 2 separate fuel systems for diesel & WVO.
The WVO will be heated via coolant and 12V glow plugs (for auxillary heat).
There will be a separate closed loop coolant system complete with a separate overflow tank.
The circulation pump will circulate the closed loop coolant through a FPHE in one direction with engine coolant going in the other direction.
The closed loop coolant will heat the WVO in the tank warm enough to keep it moving up through the heated sedimenter and filter.
Will show some pictures when I get this portion installed, but am not there yet.
A holly blue fuel pump will pump the WVO out of the tank and up to the engine compartment.
There will be 3 X 3-way solenoids:
for the engine feed WVO or diesel
for the return line WVO or diesel
for the engine lift pump which will pump diesel only - one port will send diesel to the engine via the engine feed 3-way and the other will send the diesel to the diesel return line.
In that way the lift pump will only be used for diesel.
RDavisinVA
Old January 2nd, 2015, 09:21 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Originally Posted by LuisC View Post
I had actually outsourced the rebuilt to Pendy up in Wichita. By my understanding, he is one of the best.
Pendy is outstanding and I think the general consensus here is he in fact is among the best.
RDavisinVA
Old January 2nd, 2015, 09:44 AM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
Glad to hear that. Maybe it will run better than new out the factory. 😄
Black Rhino Lives Matter
Old January 2nd, 2015, 10:00 AM
Glad to hear that. Maybe it will run better than new out the factory. ��
Please share all you learned from pendy's diagnosis. is it with him now? sounds like it.
for the fuel to get into the timing housing, it would have to be the O ring on the IP driveshaft i would imagine. that's the only part going into the timing case. and for leaking fuel to make it to the belt, it would have to be squirting out under pressure pretty well, which would be a huge failure. A normal breech would probably just leak down the case wall and diligent inspections would view the fuel leak coming out of the wading plug hole.
Mark Kellgren
KM4BOR
Old January 2nd, 2015, 07:58 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Installed the relay panel for the 4 switches that control the WVO/Diesel selections.
Also installed the Glow Plug Controller Relay (large one in the picture).
ID:	110023   Click image for larger version
RDavisinVA
Old January 19th, 2015, 11:15 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Relay Panel is in.
Large one is the automatic glow plug controller.
The rest control the fuel solenoids, 12V WVO fuel pump, and 12V heaters.
RDavisinVA
Old March 29th, 2015, 05:53 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Fitting WVO Fuel Tank
This weekend finally got a few hours to complete a trial install of the WVO fuel tank and the fitting went very well.
Bending tubing is always a challenge.
That's the freshly rebuilt engine for our daughters Jetta TDI in the back of the 110.
ID:	117140   Click image for larger version
ID:	117142   Click image for larger version
ID:	117144   Click image for larger version
RDavisinVA
Old March 29th, 2015, 08:48 PM
Looks fantastic Robert! Very professional looking and lots of progress since 4 years ago
Old April 1st, 2015, 04:14 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Thanks, Ed.
When you do a second conversion it's easy to improve the quality.
Each time you evaluate the setup and note lessons learned that you can improve on.
Will post results next time a few hours are available to spend on this new conversion.
RDavisinVA
conversion
~10 gallons or so of wvo (for bio) - free hillstrubl For Sale - Parts 0 May 20th, 2013 08:21 PM
Updated thread for SVO, WVO in our engines. JFD Defender Technical Discussions 0 December 19th, 2012 09:23 AM
Time Zones and Time? whitelandy33 Support & Suggestions 6 December 8th, 2009 04:31 PM
Misc D-90 Parts - step bumper, work light, side step, etc. Joe P For Sale - Parts 29 August 9th, 2006 03:27 PM
Time time has come to name my Defender Hans Misc. Chit-Chat 14 February 8th, 2005 08:54 PM
