Wolf Fab Rear Swivel/Clevis Tabs - Defender Source
Old April 11th, 2010, 12:18 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
This idea/project has been bouncing around inside my head for several years. I used .25 wall DOM tubing welded to 1" thick clevis tab. The tab was sectioned to allow more welding area. The whole thing slides into the rear jack holes in the cross member and is held in place by a DOM tube sleeve and grade 8 hardware. The bolt could be replaced with a hitch pin for easier removal. I greased it up before inserting (never mind the jokes) to keep rust out. Obviously this is only as strong as your rear crossmember!!
ID:	26503   Click image for larger version
ID:	26505   Click image for larger version
Semper Fi!
Old April 11th, 2010, 05:55 PM
Wolf Fabrication
Sterling Archer
'08 D3
Here's a shot of both installed.
Semper Fi!
Old April 11th, 2010, 08:08 PM
KKilo23's Avatar
KKilo23
Kenny
Nice idea, looks good.
Old April 11th, 2010, 08:12 PM
I think the bolt will want to pull through or deform the tube in the crossmember. Why don't you weld a cap on the end and thread it like a NAS rear bumper with a big 1/4in washer? At least I would think that you would want to put a washer behind the bolt.
Old April 11th, 2010, 08:25 PM
Wolf Fabrication
Sterling Archer
'08 D3
Not sure what you mean. On the back side of the crossmember there is a giant sleeve over the clevis tube that acts as the washer. It's held in place with a grade 8 bolt. The sleeve exerts the same amount of force on the back side of the tube in the crossmember as a washer would. These are designed by a Mech Engineer buddy of mine. The crossmember would fail before these do....
Semper Fi!
Old April 11th, 2010, 09:26 PM
Rugbier's Avatar
Rugbier
Gustavo
Jonathan, how about making that rear sleeve ( where the pin comes through and the blot locks in place ) like a mushroom type to disipate force? I mean what is the thickness of that sleeve, and the diameter is hollow as the actual clevis tab comes in ( I know lubed .. you sicko ,-) ) so in essence all is pushing is the edge of the sleeve now.
Am I correct? do I make sense?
NO SIGNATURE
Old April 12th, 2010, 05:53 AM
Wolf Fabrication
Sterling Archer
'08 D3
I know what everyone is saying - either do a washer or a mushroom, but due to the design of the back side of the crossmember, the swivel would no longer swivel. The washer would have to be notched. A washer or mushroom will not dissipate amy more force than the sleeve. The same about of force is placed at the same point as the sleeve. But I'll take a look and see what options there are. I don't plan of making these for sale either.
Semper Fi!
Old April 13th, 2010, 12:17 AM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Surprising.. They look like a very neat and original set up. I am sure there are quite a few people out there that were interested and patiently waiting for you to put a price to them.
My input would have been to look at replacing the bolt with the pin set up you mentioned as it's quicker to install/remove. You could then put them on when you hit the trails and remove them when you're done. Maybe look at other jacking point type mounting locations like those fitted to some sliders or on ARB and other Bumpers? Maybe use a selection of collars of different depths or different pieces to suit the different mounting locations/types. Then you could have a quick mount multi purpose recovery point.
Why wouldn't you make them for sale?
Old April 13th, 2010, 06:22 AM
Wolf Fabrication
Sterling Archer
'08 D3
Liability. But then I make roll cages for off road and race cars, go figure. I posted a posted a poll a while back and no one really seemed interested in them so I just made a set for me.
Semper Fi!
Old April 13th, 2010, 08:42 AM
Jonathan, I think it's an excellent idea and would sell well with a modification to satisfy all of us that don't like the bolt/sleeve setup. For me I'd like to see it done like the NAS bumper. Shouldn't be hard to get mushroom style washers machined if they are not already available. Otherwise a quick release pin to allow putting on as needed quickly (not that one nut is a huge issue, but it's all about perception).
Old April 13th, 2010, 08:51 AM
Wolf Fabrication
Sterling Archer
'08 D3
Charles, I think you need to take a look at them this Friday.
Semper Fi!
Old April 13th, 2010, 09:36 AM
Will do.
Old April 13th, 2010, 02:39 PM
What is that outdoor grill looking grid under your spare but above the skid plate ?
Old April 13th, 2010, 02:49 PM
Step
Old April 13th, 2010, 03:03 PM
Wolf Fabrication
Sterling Archer
'08 D3
Or a grill
Semper Fi!
Old April 13th, 2010, 03:07 PM
Ugh, I wouldn't grill on my step. Besides it would mess up the paint. LOL
Old April 13th, 2010, 03:13 PM
Wolf Fabrication
Sterling Archer
'08 D3
Yeah, but haven't we all had fire in, on, or around our Rovers at some point???
Semper Fi!
Old April 13th, 2010, 03:16 PM
Not intentionally!
Old April 13th, 2010, 03:49 PM
Rugbier's Avatar
Rugbier
Gustavo
Frankie looks really HOT in person ( much better than the pics )
HOWEVER ( yeah yeah I know I am an a-hole )
Can't wait to see how much shit you are going to get on the trip if you toss some burgers in there
How do I know you may ask? Well I will be the one starting *LOL*
NO SIGNATURE
Old April 13th, 2010, 04:27 PM
Mmmh. I thought he was just kidding around about the grill.... Nothing like starting a fire right behind the fuel tank to get the adrenaline flowing. Maybe the plan is to back over it once it's just coals?
"Can I get extra diesel on my mud burger please?"
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
Barnett Childress chrisvonc Defender Owners 0 February 29th, 2004 12:47 PM
Rear A-arm Ball Joint ronward Defender Technical Discussions 4 February 25th, 2004 08:53 AM
