wiper motor - park - Defender Source
Old May 20th, 2009, 08:21 AM
kevorkjan
George Z Marootian
2003 HSE
wiper motor - park
Hi all,
I am trying to fix the known problem of the wiper motor not "parking", and the intermittent feature not working. The motor was noisy to start, so picked up a new one, but the new one does not park as well.
Any ideas?
Thanks!
1991 RRC
Old May 21st, 2009, 09:05 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Did you replace the park switch on the wiper motor?
If your wipers do not park and only move a few inches when on "inter" then the park switch is the fault.
Easy fix with parts from your favorite Rover parts source.
Email:
Old May 21st, 2009, 04:04 PM
kevorkjan
George Z Marootian
2003 HSE
Changed the park switch
Intermittent does not work at all, and they stop whenever I set the stalk to "stop"
Thanks.
1991 RRC
Old May 21st, 2009, 05:43 PM
ECR's Avatar
ECR
Thanks.
Looks like you have other issues then.
Email:
Old May 21st, 2009, 10:45 PM
surf110's Avatar
surf110
Ze
130 Project
Might be worth checking the wiper relay. It could be unplugged or bad. It is behind the fuse metal plate.
Old May 22nd, 2009, 09:59 AM
kevorkjan
George Z Marootian
2003 HSE
fuse metal plate?
where is that located?
1991 RRC
Old May 22nd, 2009, 11:45 AM
surf110's Avatar
surf110
Ze
130 Project
Behind fuse cover which is forward of the shifter.
motor
What makes the Rear Wiper park? COSteve Defender Technical Discussions 10 March 6th, 2007 04:40 PM
Rear Wiper - Anyone Please Kimos Defender Technical Discussions 14 November 8th, 2005 02:10 PM
Locating the rear wiper pepstein Defender Technical Discussions 0 April 2nd, 2005 09:56 AM
Wiper Blades going haywire... arbik Defender Technical Discussions 4 February 22nd, 2005 11:07 PM
bulkhead and wiper stud fitting problem mattdh Defender Technical Discussions 3 April 2nd, 2004 09:42 AM
