Winter and TDI - Defender Source
Old October 6th, 2009, 11:00 PM
Shearpin
Henry Stinson
'73 Series III SWB '84 110 tdi
Winter and TDI
I've run a search and wasn't able to locate a specific thread on winter and the TDI. I was fortunate enough to have my 300tdi sit out last winter - it may have to do some duty this year in Toronto, Canada.
Specifically, I am interested in what block heaters everyone is running. Does the install require removal of the manifold etc.? Any hints on the process would be appreciated? I am switching to Amsoil anti-freeze shortly so it would be the ideal time for the install.
Also, I am going to make the switch to synthetic motor oil for the winter months. I've read of increased motor leaks with synthetics. Is there a suggested winter weight and type?
Thanks again...
Henry
www.4x4freedom.com
Old October 7th, 2009, 12:30 AM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
just answering the first part of your question re: block heaters... technically no block heater but I run a Webasto and seriously would hate to go without it...
Old October 7th, 2009, 07:57 AM
It will start a bit more sluggishly in cold weather, but we have an Espar to save the wear and tear and provide immediate heat.
I've used synthetic since new in my tdi and its been great, I've never had a even with switching vehicles from dino to synthetic on other motors.
Old October 7th, 2009, 10:37 AM
Zerostart (aka Temro) 600W 'freeze plug heater' P/N 3100087 fits a 200TDI, I assume the 300TDI is the same.
http://www.landroveraddict.com/smf/i...topic=366580.0
I have a Webasto as well, with a wireless remote. Greatest purchase ever.
Old October 7th, 2009, 06:01 PM
moose's Avatar
moose
Brett
Ex-Mod Tdi 110 Hard Top
Yes, the Temro 3100087 fits the 300Tdi. That's what I have in mine Henry and it saw a LOT of use last winter. You can get it at Carquest. Little pricey at $94.87 though, but worth it. Put it on a timer for two hours and a nice easy start. I did't even need to use the glow plugs.
Mine was pretty easy to install but only because the engine was sitting on the bench at the time. Will be a little trickier with the engine sitting in the truck. I put mine in the centre freeze plug, but in retrospect, it that might not have been the best spot. Will be tough to change in the future is the need arises but I couldn't say for sure if the heater will fit in either of the other two freeze plugs locations.
Was thinking of going to synthetic oil as well this winter. Not sure which one yet.
Brett
Ex-Mod 110 Tdi
Series 3 88 Diesel Soft Top
Old October 8th, 2009, 03:14 PM
Shearpin
Henry Stinson
Brett
Thanks for the reply - I am hoping to get out to Carquest this afternoon. Did you use any Waxoyl or other rust treatment?
Henry
Old October 8th, 2009, 08:18 PM
moose's Avatar
moose
Brett
No Henry, I haven't done any Waxoyl or other rust treatment and it pains me all winter long driving on those flippin salted roads around the GTA. I need to do something about that.
Brett
Ex-Mod 110 Tdi
Old October 16th, 2009, 09:27 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Hey John,
You put a #310087 in your truck, which is a 600w 2.06" model
do you think a 400w 2.135" model would fit
its model#310088
Old October 16th, 2009, 12:37 PM
I have a Webasto...
We did install one of these in a friends 200TDI and it was a VERY tight fit in the frost plug hole, so, NO, a larger size won't fit. I should have measured, but I would not doubt it is a 2" hole.
Old October 16th, 2009, 05:18 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Which plug did you put it in? I just called and am able to exchange mine for the one you used.
Old October 16th, 2009, 07:54 PM
Middle one. Not sure if it matters.
Old October 16th, 2009, 09:39 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
tdi
Big Fat NAS 110 Registry Thread JimC Misc. Chit-Chat 359 August 30th, 2017 03:11 PM
Temperature Gague false reading trick? arbik Defender Technical Discussions 67 April 30th, 2017 09:45 PM
300 TDi Thermostat ronward Defender Technical Discussions 34 January 1st, 2013 12:09 AM
4.6 or 300 tdi NashvilleRedD90 Defender Technical Discussions 67 March 12th, 2009 01:03 PM
